Question about Salton WM4 Waffle Maker
How to clean roller grill - Salton WM4 Waffle Maker
I have a hot dog roller grill model#hdr565 the receptacle is broken.
Then you are stuck with it, either that or you search for a replacement receptacle online & then take it back
Nov 11, 2014 | Nostalgia Electrics Hot Dog Grill Roller...
I bought my son an old fashioned hot dog roller for Christmas. It worked great the first time and the second time he went to use it, the rollers wouldn't roll. I've read several reviews on this product...
The 5 rollers are operated by 9 small gears that a run by the center gear which is turned by the motor on your machine. The gears in between the rollers help drive the next roller as you move outward from the center. The gears are made of what looks like pot metal, (cheap junk). The teeth break on the gears easily and either stick or won't operate the next roller. You can take the unite apart using a thin screw driver an pry the 6 flange on the drive side and straigten the flange with needle nose plyers. It then prys apart. If any teeth are broken, you can only buy a whole new grill part from Nostalgia Electrics. Cost is 20.00. They won't just sell the junk gears
Jan 06, 2011 | Nostalgia Electrics Hot Dog Grill Roller...
My weber grill is not putting out enough heat--both burners ignite, but I can't turn them up to get a higher flame/higher temparature. The grill is about 5 years old. How can I clean the burners to get a...
follow the below procedures on how to clean the burners for your grill:
Shut off the gas. It is very important that you turn off the gas valve to your BBQ before you can begin to clean it. This is found on the hose that attaches to your propane tank, simply turn the valve all the way to the right.
Escape any remaining gas. Next turn all the burner knobs to the highest setting and allow the remaining gas, if any, to escape. Make sure you have the grill hood in the open position before doing this.
Let the Grill vent for five minute: In order to ensure that the remaining propane has ventilated properly, leave your grill open and do not begin to clean it for at least five minutes.
Brush grill bars. Using your grill cleaning brush, firmly brush the surface of the grill bars in a forwards-backwards motion with the steel from the brush sweeping across the surface. Once you have brushed the surface flip each grill bar over and brush the other side.
Saturate with grill cleaner spray and repeat. Using your grill cleaner spray thoroughly saturate the surface of the grill bars and brush both sides. Set the grill bars aside after you finish so you can access the interior of the BBQ to clean it.
Remove burner plates and clean. All gas grills have metal plates which cover and protect the flame pilots during cooking. These will typically become covered with ash, and burnt grease and sauce over time. Simply remove them from the grill and brush them down. After you have brushed them once, saturate them with the cleaner spray and brush them down again. Set the plates aside so you can finish cleaning the rest of your grill.
Clean interior of grill. The plates will only catch so much, still sauce and grease will fall to the bottom of the grill and turn to ash. Using your grill brush, jar all of this ash free. Douse it in cleaner spray so it condenses and scoop it up with the paper towels.
Clean grease catch. Many newer gas grills will come with a grease catching plate. You can usually access these through the rear of the BBQ. They generally have a small metal handle and will easily slide out. Remove this grease catch, and brush and clean it thoroughly.
Clean exterior of grill. Using your grill cleaner spray, saturate the exterior of the grill and wipe it down with the paper towels. Repeat this process until the exterior is entirely clean.
Reassemble the grill. Now you can put all the pieces back together in your grill and turn the gas valve on again.
I hope the above helps to solve your problem.
Good luck.
Aug 18, 2010 | Weber Grilling
What is the best way to clean the grill?
use a good wire brush on the burners each time you use it before and after cooking. every season take the grill grates and flare reducers out and clean them well with a wire brush and or steel wool and clean out any residue in side the grill. make sure the grease catcher gets cleaned often as needed. blow out the gas manifolds with air in the spring to remove spider webs or insect webs etc. this should keep your grill working well for 10-15 years. replace the grates or flare plates when needed.also lightly clean the burners when you have the grill taken apart with steel woll then blow them out as well to keep all the openings clear. happy grilling.
May 29, 2010 | Weber Genesis E-320 Propane Grill
How long do you put hot dogs on the roller grill?
Once you have the rollers hot (10 min.) it should only take about ten minutes for the dogs to heat up... they are fully cooked so you anly have to get them hot, but you can let them on for a much longer time if you want too, like if you are selling them at a stand...
heatman101
Apr 29, 2010 | Nostalgia Electrics Hot Dog Grill Roller...
Using rollers to pull fridge out for cleaning
Hi: Simple. Every Amana refrigerator I've seen in the last 15-20 years have brakes. In front of your wheels is a rubber disc that screws down to stop the fridge from rolling forward when you open it. You have to screw them back up a little to make it roll. If you look at your grill you will see that it is flat all the way across except for the ends they protrude forward at the ends. They usually cover the brakes. Work at the grill to find the clips that hold it in place. It will snap off. The reason for putting you through that; is the energy efficiecy, The seals work so well that you would pull the fridge forward when opening. That should work, Jeff
Nov 26, 2008 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Salton WM4 Waffle Maker Logo
43 people viewed this question
Top Salton Kitchen Appliances - Others Experts
fixzum
Level 1 Expert
Robert Plante
Kolbrun...
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
