Question about Gatco Charlotte 20 Inches Glass Bathroom Shelf 4356C Chrome
Gatco Charlotte, Glass Shelf, Chrome - Gatco Charlotte 20 Inches Glass Bathroom Shelf 4356C Chrome
  • Uriel Velasco May 12, 2013
    It is simple to get that figure...just somebody measure the distance between the fixing screws and post that information...the manufacturer must have that data..and with it I can determine whether to buy the unit or not
How to remove the glass shelf for better cleaning PSC25MSSC
if the glass has plastict trim like pieces across the front and rear edges try pushing up on the glass close to the plastic trimat th rear end, the trim should swivel up and the glass pop out of the groove
May 03, 2015 | GE Refrigerators
The shelf uses two attachment bolts to fix it to the wall, so I need to know whats is the measure between this bolts in order to clarify whether this device matches the space I have available on my ba
This depends on which model you have, but here are two solutions for you.
1. Your model should have come with instructions. Read the instructions to the point where they tell you the distance between the screws. As far as if your bathroom wall will be long enough measure it. If the space is wider than your model, you are GTG.
2. If you have a tape measure, just measure between the screws making sure you are in the center of each hole. That will be the width you will put the holes in your bathroom wall.
***WARNING*** IF YOU ARE WANTING TO PLACE ON A TILE WALL, YOU MUST HAVE A CERTAIN TYPE OF DRILL BIT.***
May 10, 2013 | Gatco Charlotte,Glass Shelf,Chrome
I need to know what is the distance between the fixing bolts to the wall due I already have the perforations holes done on the wall...others dimensions fit very well
The peroration holes should be the holes for the bolts. If you followed the instructions, the two perforation holes are nothing more than a pilot hole for the bolts or screws.
If you are not sure of this answer, just measure the perforation holes (write down the distance, being sure to measure between center to center of the holes). Do the same on the unit itself. I bet they are exactly the same.***WARNING*** IF YOU ARE AFIXING ON A TILED WALL YOU MUST USE A CERTAIN DRILL BIT.***
May 08, 2013 | Gatco Charlotte,Glass Shelf,Chrome
I need a glass shelf for the crisper drawers 22 5/8
The glass shelf is no longer available but having someone cut glass to size will work, Thanks Sea Breeze
Nov 19, 2012 | Refrigerators
Trying to hang gatco channel towel bar. there are no studs what size hole should I drill? I lost my directions.
Go to Home Depot, hardware or Plumbing isle,, tell them you want to hang a towel bar and you want some self drilling wall studs rated larger than or equal to 10 pounds. bring one of the screws from your Towel bar kit.
Nov 28, 2010 | Gatco & Channel& Satin Nickel Towel Bar
HOLDER SEPARATED FROM WALL. DON'T KNOW HOW TO GET
There is probably a hex-head set screw on the bottom. If so, unscrew and that should allow access to mounting screws.
Nov 06, 2009 | Gatco LATITUDE?² TISSUE HOLDER - EURO...
Wi-fi wacs700
The Philips software doesn't allow copying from the WACS700.
Jan 12, 2008 | Philips WACS700 Shelf System
Repair broken glass
West Marine
13000 York Rd Suite #K
Charlotte, NC
28278
PHONE: 704-588-1020
Oct 08, 2007 | Garmin nuvi 350 GPS Receiver
Gatco Charlotte 20 Inches Glass Bathroom Shelf 4356C Chrome Logo
73 people viewed this question
Top Gatco Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Gatco Furniture Expert? Answer questions, earn points and help others
