Question about Danby DPAC8099 Air Conditioner
Replacement parts I have a Danby DPAC9006 AC unit, and the flesible exhaust hoses need to be replaced. However, they have been discontinued for this model. Any suggestions for alternates I could use, or where to find discontinued parts?
Illeagle
  • 525 Answers
SOURCE: installation
This is apparently a new product, and not having provided me with a model number, I was only able to ascertain that this is a dual hose model? If so, then I would assume that since there is no direct correlation between 1 hose and the other, that it probably doesn't matter, since both hoses are utilized for proper operation. Click the link below for more information.
http://www.rainbowappliance.com/Air-Conditioners-1/Danby-DPAC90061-9000BTU-115V-PORT-AC-DANBY-3340.html?utm_medium=shoppingengine&utm_source=yahooshopping&cvsfa=673&cvsfe=3&cvsfp=DPAC90061
Posted on Jun 03, 2008
SOURCE: Hose and connecting parts - schematic available?
need a Manual for this airconditioner if any one can email me a copy, that would be great . my dad passed away last year my mom moved out of the house into a apartment ,But I dont know how to set this up any info would be great.....Manuel
Posted on Jun 26, 2008
checkitright
  • 1362 Answers
SOURCE: Missing the drain hose connector
A drain hose is a drain hose, go to home depot and get the dimension and lenght you need.
Posted on Jul 22, 2008
  • 233 Answers
SOURCE: unit does not cool with the exhaust pipe connection covered
you need to get the exhaust air out if the structure or it will never work, you can use regular duct from a supply house as a temp fix
Posted on Jul 12, 2009
co7196
  • 3433 Answers
SOURCE: I am purchasing the DPAC 13009 Danby 2009 portable A/C, but....
Mae; I'm sorry to hear another good deal went bad. Door to door wholesale is a way to sell items that can't be sold in stores.. If you take a picture of what the hose connecta to and send it to me, I'll see what I can do. Explain the purpose of this hose andthe measurement of the connector outside diameter. The picture will say alot, I would appreciate it. e-mail the picture to co7196@yahoo.com and we'll figure out something.
Posted on Jul 20, 2009
Where can in get a set of exhaust/intake hoses for a danby dpac120068 air conditioner
Is there a reason not to just go to the Danby site? Support Danby includes phone support, email and "Find Parts" Even if their source is out you should at least be able to find the correct part number, then Google Danby (part number).
You could also look to see if generic flexible vinyl tubing/hose can be substituted. It's doubtful that Danby created their own hoses.
Jun 09, 2016 | Danby Heating & Cooling
I am in need of a fan motor for my Danby Frig. Paret #JG50.DQ-10. Cannot find it anywhere. Suggestions?
The problem with the factory fan is that it is a sleeve-bearing fan. On average, a fan should operate for about 50,000 hours, which if it runs continuously would be over five years. However when the operating temperature rises or the fan is installed "not exactly" vertically, it will have shorter life.
I had to replace my fan two times withing two years since we bought the unit! Plus the stock fan becomes quite noisy after a couple of months of work.
With all of these problems I did some research for better fans and decided to purchase a ball-bearing fan to install it into the cooler by myself.
Ball-bearing fans on average outlast sleeve-bearing fans by 50 percent and produce less noise.
It's very important to purchase the right AC 115 Volts fan for this Danby wine cooler.
The original fan is Rullian Science RAL 1225S2 (120x120x25 mm in size, 100-125V AC, 0.09A)
The replacement model is Orion OA12AP-11-3TB which I got for $16.75 from Mouser Electronics (mouser.com). The replacement model is ball-bearing cooling fan with slightly higher/better parameters, which will help to cool down the wine cooler coil faster.
To replace the fan you need to tilt the wine cooler on the side and unscrew two small screws at the bottom that keep the original fan in place, remove one screw to the black box where the fan wires are attached and unplug these wires. Then you just need to replace it with the new fan and test that it works properly. If you never used Soldering Tool before you probably will be better off with getting some help from certified electrician - it still will be less expensive than getting this fan ordered every year from Danby.
Nov 06, 2012 | Danby DWC513BLS Wine Cooler
Can you extend the exhaust hose on these danby air conditioners?
Generally, no. These units only have just so much fan pressure to exhaust the heat & moisture out of the house. Extending the hose could cause a draining & exhaust problem.
Jul 07, 2011 | Danby DPAC8020 Air Conditioner
I got a danby ,and i not no how to use it. there is hole at the back of it, but i do not a hose,what do i do
Unfortunately, the model have has been discontinued. The hole on the back is for an exhaust hole for an exhaust hose that goes out a window. However, there is more to it than just the hose. You need the hose couplings/connectors and the window termination kit. Even though your model has been discontinued, Danby may be able to help you. 800-496-6049
Hope this helps you solve the problem. Please let me know. Thanks.
Jun 08, 2011 | Danby DPAC8099 Air Conditioner
In Dry and Air Condition mode, my Danby dpac 7597 is leaking from the bottom; not from the drain hose.
It is leaking water correct? Check your hose for clogs or a crack, follow it up and find where it is exactly coming from. If you need a part replaced, let me know and I can find you a replacement. If you have questions about accessing parts, let me know but the outer panel should be held together with simple screws.
Aug 13, 2008 | Danby Heating & Cooling
Jul 14, 2008 | Danby DPAC8399 Air Conditioner
Installation
Jun 03, 2008 | Danby 7,000 BTU Portable Air Conditioner -...
Danby DPAC8099 Air Conditioner Logo
49 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
