Question about Honeywell Triangle Tube Prestige Solo 110 Ng Wall Boiler Ps110 Ng
Blown 24v Slow Blow Fuse
Came home from vacation to discover boiler not working. Display was showing U1.25 (software version). Took cover off control module and discovered that 4 amp slow blow fuse was blown. Replaced fuse and restarted, fuse blew immediately and display again showed U1.25, no error code. I read mfr's maintenance and troubleshooting guides, but found no answers there. How can I determine what's causing the fuse to blow?
Scott, I have the exact same problem. What ended up fixing this? Thanks! - Paul
Posted on Feb 14, 2015
    Sergeant:
  • 317 Answers
Check wall socket to see if there is a short. Did you have an electrical storm while you were away?? Install surge suppressor on this system.
Posted on May 19, 2013
  • bob m
    bob m Nov 24, 2013
    same exact problem, today -- did you ever figure out a solution? (no electrical storms here, strong winds last night)
I had an issue with turning off the fill valve on my alpha boiler and the pressure went to 1.5 bar when cold and rises to 2.75 when the heating comes on is this ok.
You need to check with the boiler/system specifications to discover the correct pressure.
An overpressure condition should be dealt with by a safety valve that usually vents to the outside of the building - if it is working correctly. There have been incidents of this external vent freezing causing dangerous pressure to build in the system. I understand a modification is simple and inexpensive but I don't know any details.
Our pressurised system runs at about 2.5 bar hot, or at least it used to do when it was younger...
Jan 25, 2017 | Water Water Heaters
Hello i have problem with my boiler mate 2000,when heating is swithch on , boiler on the kitchen still flashing with green lights (reset) im not sure how they fixted this problem all radiators ok ,hot
Hello Wojtek!
Over here in the colonies, we don't know from Boiler Mates, and I'm sure you have already discovered the same documents I foumd. The word "fiddly" came up in the second link and while we don't use that term often on this side of the pond, it definitely sounds pejorative.
Unfortunately, as we say over here, you may be "in for it".
Other than a reset, have you tried a "hard" reset by pulling the power? How about control/alt/delete ???
OK, now I'm getting silly.
All the best
http://www.gasapplianceguide.co.uk/Gledhill%20Boilermate%20explained.htm
http://www.gledhill-response.net/documents/boilermater2000switch_user.pdf
Dec 06, 2014 | Water Water Heaters
Vokera mynute 28 se, plumber has replaced fan and swithch as the burner would not cut in, was beeter for a year or so, in trying to find the problem again, he has discovered that if the front plate closing...
It sounds to me like the outside air intake (your boiler requires outside air for combustion) is plugged. Bird's nest, maybe? Leaves? Spider webs? Have the plumber check outside AND where the intake air connects to the boiler.
Nov 05, 2013 | Water Heaters
Which contacts do I connect the boiler to? I thought it was the TT, but I am not getting any voltage on them.
Here is a link, that includes the wiring diagram:
http://www.forwardthinking.honeywell.com/related_links/water/aq2000/install/69_1974.pdf
It looks like the 'T-T' terminals match up with 'T-T' terminals on the Boiler Aquastat-- Do you see that control?-- and do you have wires between those controls.
Power to this Control Module is all the way to the left on the connector terminal board-- the ones that say:
R (1) C (2) - Power In
Also: Did you realize that this control is a modulating control-- Not just an 'On-Off' control?
This control has outdoor sensors, that modulate the temperature of the water temperature-- The warmer it is outside, the lower it sets the Hot Water Temperature-- thus saving fuel-- yet assuring that on very cold days, you still get Hot enough water to be comfortable in your occupied space.
Oct 12, 2013 | Honeywell AQ25142B Aquatrol Boiler Reset...
New Vaillant 360 eco plus boiler, takes almost 3/4s an hour for rads to come up to a decent temp. Hot water is fine. Called out install Engineer who is an excellent tradesman but he says everything
We have just had our old system boiler replaced with a vaillant ecotec plus 837 and sounds like a similar working operation to ours. At first I was a little concerned,but I was told by our installer that he was told by vaillant that these very latest boilers size the system on start up for about 10 mins, then take temperature to target flow which you set boiler at. So even by setting target flow temperature very high you still get the initial sizing cycle, which ours was about 30-35c temp. These boilers seem to run biased for efficiency as after a while they modulate the boiler burner down and the radiators run more on the side of warm than really hot like the old type boilers. You also get better efficiency as at lower temperature the boiler condenses better. You will also find you get a more constant temperature in your home rather than over shoots. I was concerned at first, shame there was no info/explanation in user manual as people do need to know that this is normal operation. We are used to ours now, took a month and by the way these boilers can make a creaking noise but was told this normal expansion/ contraction but annoying when sited in bedroom cupboard. Best of luck!
Oct 27, 2012 | Water Heaters
Why get a P1 error code on my Rheem tankless RTG-64xp?
1) I cannot find Rheem error code P1
http://www.palomatankless.com/owners/homeowner+trouble.lasso
http://www.palomastore.com/paloma_error_codes.html
2) BOSCH does not show P1 either:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
3) Best I could find is that folks with P1 error code report tankless fires for short period, and then turns off.
This implies air, fuel or vent problem, and can be internal, external or combination.
4) P1 appears frequently on control board descriptors, which might imply the error is control board malfunction.
5) Call Rheem 1-800-432-8373, and then add a comment to this thread and let folks know what you discover.
6) I will also call Rheem when time permits, and post what I discover.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Rheem Water Heaters
Hot water boiler will not ignite
Check all your limit switches on this unit. One of them is either tripped or bad.
Apr 07, 2009 | Water Heaters
Brand new valiant condensing boiler installed will not work
Valliant boilers have software that can be used to diagnose the unit. The software can be purchased at the plumbing supply house that the boiler was purchased from. You can also get tech. service by email as well. It sound like there is an issue with the electrical controls with it. Or the controls were wired wrong.
Technical enquiries 01634 292392 or technical@vaillant.co.uk
Apr 01, 2009 | Water Heaters
No hot water.
Please get an expert in - this is either the breaker is faulty or you have an electric fault int he boiler. You can try and replace the breaker - but match the current rating. But this could be dangerous if you keep trying to reset.
Jan 25, 2009 | Rheem Tankless Hot Water Heater...
Thermocoupling on a Honeywell Economy Plus EP50B Boiler
the thermocouple most likely plugs into the gas valve, the box with the gas control on it.
Jan 10, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Honeywell Triangle Tube Prestige Solo 110 Ng Wall Boiler Ps110 Ng Logo
521 people viewed this question
Top Honeywell Water Heaters Experts
Paul Carew
Lawrence Oravetz
Are you a Honeywell Water Heater Expert? Answer questions, earn points and help others
