Question about Arrow No.ETF50PBN Extra Heavy Duty Professional, , Electric Staple Gun/Brad Nailer
Instruction manual is lost and I can't figure out and need help on how to load the brads and use the brad nailer feature for the ETF50PBN electric staple & nail gun
SOURCE: does the ET200 nail the 1.25 Brad all the way, the
Sorry no answer for solving, But my ET200 does the same as you are describing. What's the purpose of using this tool if I have to go back and set each nail if the ET200 is suppose to do it for me? I will check back, but if you have found the solution, I would like to hear it. bwthompso@gmail.com
Posted on Dec 14, 2009
  • 4 Answers
SOURCE: instruction book for Arrow ETF50P staple gun
Look at the rear of the stapler. Push in then down on the stapler tensioner to release it from the rear of the gun. Slide the tensioner out. Next slide the new staples over the rail and into the gun with points down. Slide the spring tensioner back in and connect it to the stapler by maneuvering its clip down and then up.
Posted on Jul 10, 2010
woobie dog
  • 1273 Answers
SOURCE: a 1 1/4" brad nail only penetrates 1/2 inch
Hi, There should be a power adjustment on the top of the driving head. Make adjustments there, and the penetration should improve.
--W/D--
Posted on Feb 24, 2011
al_kupchella
  • 843 Answers
SOURCE: brad nail only goes 1/2" into wood. there is no
You might get better penetration if you use your other hand to press the gun down firmly onto the surface before you pull the trigger. (This will help if the gun tends to jump a little when you fire it.) Or, if the surface you are firing into might not be rigid enough (like a thin board that is not supported) - in that case you might improve the penetration by better supporting the surface you are nailing into, perhaps by placing it on the floor. On the other hand, this may simply be a case that the gun is not powerful enough to do what you want it to do. To test that theory, try it into a piece of soft wood (like a 2X4) or find a soft thick material as a first layer over the wood you are using. Perhaps you can use shorter nails - thin brads in wood don't gain much strength beyond 1/2 inch penetration anyway. The length of the brad only needs to be about 1/2 inch longer than the thickness of the first layer of material. I hope this helps, good luck Al K
htm6934
  • 4 Answers
SOURCE: The nail gun will not shoot
I don't have that same model but my gun started doing something similar a while back. I was able to disassemble the head of the gun and found that the hammer or piston that drives the nail had rounded itself off and wasn't able to make good contact with the nail head. Instead it pushed itself on top of the nail and got wedged. It's nearly impossible to see the stuck nail or dulled piston head without taking it apart. Hopefully this will help.
Posted on Oct 19, 2012
HOW TO LOAD BRADS IN STANLEY TRE500
Please download the instruction sheet from the following link which explains how to load the brads. Make sure you have the correct size of brads mentioned at the bottom of the instruction sheet.
TRE500 Sharpshooter Stapler Instruction Manual
Aug 13, 2014 | Electric Stanley Tre500 Staple Gun /...
How to load brads into stanley tre 550 electric staple/brad nail gun
HOW TO USE YOUR ELECTRIC STAPLER/NAILER
TO LOAD STAPLES
1. Unplug tool, (fig. 1)...(place on/off switch in "off" position, (fig. 2).)
2. Place on/off switch in "off' position.
3. Select proper staple length.
4. Use only staples identified by stock numbers on next page. Substitute staples may cause jamming.
5. Hold tool upside down. (Squeeze latch and pull, (fig.3).)
6. Drop staples in channel, legs facing upward. Push latch back in to lock in place, (fig. 4).
TO LOAD BRADS
2. Use only brads identified by stock numbers on next page. Substitute brads will cause jamming.
3. Look for the image of a brad nail on the front side of the tool (fig. 5). Load brads into this side only.
4. Hold tool upside down (Squeeze latch and pull, (fig. 3).)
5. Drop brads into the channel, tilt the tool so the brads lay against the channel wall, (fig. 5).
Push the latch back in watching that the brad strip does not fall over.
6. Use High/Low power when driving brads.
TO STAPLE OR NAIL
1. Make sure the on/off switch is in the "off" position, plug stapling tacker in.
2. Turn tool on by switching to position 1 which is the "on" position and hold firmly against work surface to
engage safety mechanism.
3. Apply adequate pressure on the top of the knob (fig. 6.) while the trigger is pulled.
You can find the figures mentioned above at the following link:
http://bdk.force.com/FAQ/servlet/fileField?retURL=%2Fapex%2FPKB_Article%3Fid%3DkA0C0000000CdtPKAS%26brand%3DStanley%26returl%3D%252Fapex%252Fpkb_search%253Fbrand%253DStanley%2526mode%253D0%2526model%253D%2526sortby%253D0%2526terms%253DTRE550&entityId=ka0C0000000CdqqIAC&field=File_1__Body__s
Jun 20, 2011 | Stanley Tools TRE550 Electric Staple/Brad...
I have a DC608 cordless nailer that will not fire the driver the driver does not move at all but everything else seems to be functioning properly Thanks Tim
You can go to this webpage and download the owner's manual which gives instructions: http://servicenet.dewalt.com/Products/Detail?productNumber=DC608K
You can also download a parts diagram and order parts here.
I looked through the manual and found that DeWalt's Brad Nailer does not require tools to remove jammed nails from the nose piece. I believe this is the problem with your nailer, unless it's empty. Some of these nailers will not fire if there's less than 6 nails in them.
Another feature on this nailer is the trip lock. It is a safety feature that prevents accidental firing. Any time you adjustments made to the nailer will automatically turn the trip lock to lock position. You'll find this lock on the right side, under the Dewalt label.
The instruction manual will explain all this.
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | Dewalt DC608K 18 Gauge 2-inch Cordless...
My Task Force electric brad nailer is jammed.
Brad nailers typically jam for one of two reasons, a misaligned or bent brad on the brad strip or a defect in the brad strip itself. Remove the brad strip in the nailer and replace with a new one. Examine the striker head first for any signs of residue keft from the jammed strip.
Oct 31, 2010 | Garden
Instruction book for Arrow ETF50P staple gun . lost the instructions and can't figure out how to insert the staples in the gun
Apr 19, 2010 | Arrow No.ETF50PBN Extra Heavy Duty...
How do I load staples? I can not find my manual!
On the back bottom of the stapler there is a rod you need to lift up and then pull out on it should come out
Nov 15, 2009 | Arrow No.ETF50PBN Extra Heavy Duty...
I cant get the rod out to put new staples in
These things are weird. What you gotta do is push on the end and lift it up and then pull. Jiggle it around like you would trying to get a key to work. Good luck!
Sep 19, 2009 | Arrow No.ETF50PBN Extra Heavy Duty...
The door at the back of the staple gun won't close
You may have too many staples loaded in the magazine.
Jun 05, 2009 | Arrow No.ETF50PBN Extra Heavy Duty...
The staple holder weld breaks. Can you get a new part ?
If you go to this link on the Arrow website, you can order parts. They do not have the parts diagram available for this tool, so hopefully you still have yours (if you could scan it onto your computer, that would be a good way to store it) http://www.arrowfastener.com/FMPro?-db=web.fp5&-format=product.html&-lay=Entry&-Op=Equals&item=ETF50PBN&-find=
Feb 01, 2009 | Arrow No.ETF50PBN Extra Heavy Duty...
Arrow No.ETF50PBN Extra Heavy Duty Professional, , Electric Staple Gun/Brad Nailer Logo
94 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
