Question about HP DeskJet 3520 InkJet Printer
Hp 3520 black ink wont print - HP DeskJet 3520 InkJet Printer
  • HP Master
  • 2,045 Answers
Replace cartridge.
Posted on Jun 23, 2015
  • 4 Answers
SOURCE: HP 3210 black ink problem
I just posted my problem and found the solution on a different web page. It is this and it WORKS
All you have to do is HOLD DOWN FOUR BUTTONS AT THE SAME TIME: ( OK, Cancel, Black , Color ) and turn the power off. Do this at least twice and the unit will power up and go to maintenance. Then it was back to normal.
HP gives you a procedure that doesn't work! They just want to sell you a new one. They must know the solution if and old woman like me can figure it out with help from other people with the same problem
Posted on Jun 26, 2008
  • 133 Answers
SOURCE: Black ink not working on HP C5180 Photosmart
Try a hard restart, which simply means unplugging the power cord of the printer, and replugging it after one minute has passed. If that does not work, then rerun the CD used to install the printer. Both techniques reprogram the electronics, to a certain extent.
You can also visit the HP website, to see what solutions are being offered for various printer problems. They probably have a number to call, in case you need to talk to a technician.
Hope these suggestions help you out.
Posted on Jul 04, 2008
SOURCE: HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
Posted on Jun 16, 2009
  • 5 Answers
SOURCE: installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Posted on Jan 22, 2010
wings_it
  • 141 Answers
SOURCE: Hp officejet k550 wont print black ink
I guess you tried a new cartridge with the same problem.. so try to run the utility tools from the HP soft, you can download it here :
http://h10025.www1.hp.com/ewfrf/wc/product?product=501369&lc=en&cc=us&dlc=en&submit.y=7&submit.x=11&lang=en&cc=us
It has also a "Solve a problem" section who might help you.
Then if the problem remain check the contacts in the printer, sometimes ink goes in, dry and stop the contact. Clean it with a hear tip and water (disconnect power and allow to dry before testing)...
Good luck and don't forget to rate.
Cheers
Posted on Jan 23, 2010
Black ink won't print. All other colors working fine.
Soak the head in printer head cleaner. Then try blotting it on paper towel until the clog opens up; Repeat until it works or buy a new printer head.
Apr 17, 2015 | HP Deskjet 3520 e-All-in-One -...
I have a hp desk jet 3520 it wont print it keeps saying intall setup cartridges but i have them installed correctly.
Are these the ink cartridges that came with the unit?
Are you sure they're in the correct positions?
Possible that one of the chips is defective. Try replacing with a new cartridge.
Jul 21, 2014 | HP Deskjet 3520 e-All-in-One -...
Clean printhead and breather hoses hp 3520
try to reset the the black printhead , and clean the it
Mar 23, 2013 | HP DeskJet 3520 InkJet Printer
Hp deskjet 3520 wont print. why?
update the driver or go to service centre
Aug 12, 2010 | HP DeskJet 3520 InkJet Printer
Help w/ h/p deskjet 3520
hi/....
this is because of the low ink in the catridge. normally the colour catridge contains three colour in it. yellow ,blue and i think one more is pink. so in your case the other colours might have finished. so because of that you are getting only yellow. so please replace the catridge with new one and the problem wil be solved
Jul 15, 2010 | HP DeskJet 3520 InkJet Printer
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
Black ink wont print hp
Make certain it is not out of ink.
Aug 11, 2009 | HP Photosmart D7160 InkJet Printer
HP DeskJet 3520 InkJet Printer Logo
1,705 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
