Why wont the 8.0 uhf pro work with a bell 5900 receiver
5 Suggested Answers
  • 374 Answers
SOURCE: uhf pro 8.0
Problem has been resolved per customer.
Posted on Oct 06, 2008
  • 56 Answers
SOURCE: bought a dish identical remote to Bell Expressvu.
You may need to program to your equipment, go to dishnetwork.com/tech and that will show you how to address your remote.
Posted on Nov 12, 2009
SOURCE: How to program 9242 remote to work with my Bell
The following instructions will enable the Bell 9242 remote to operate a Bell 5900 receiver. Remove back battery cover. Just below the "Bell" lettering on the front of the remote, there is a half moon shaped plastic insert "key" that slids out downward. Turn over the plastic key and reinsert back into postion and replace the battery cover. Success!
Posted on Oct 17, 2010
raycalo
  • 358 Answers
SOURCE: my old Bell receiver 's
mikecrans175
I have provided the instructions on how to program your remote to your TV and addressing the remote to your receiver below. I hope this helps.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and Hold the TV Power button for three seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote:
  1. Go to System Info screen.
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button.
  5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Ray Calo
DISH Network
Posted on Mar 15, 2011
Can't get my 21 1 ir/uhf pro remote to work with dish network dvr 625
If you are attempting to program it to tv-2 on a 625 receiver it has to be set to a odd number for example number 7 instead of 2 or 6.
The reason for this is that the 625 receiver only supports band A frequencies for UHF and on a 21.x remote odd numbers are A band and even numbers are B band.
Sep 25, 2013 | DISH Network DVR-625 DTV Receiver /...
I need a code for a Prima Q328 Television
It may not be possible as that remote has a limited number of codes and even if it programs may only do a few things.
Try all the possible codes and look to see if that remote has a search feature which would allow you to try each and every code it has.
Nov 07, 2012 | Televison & Video
Will dish network 510 receiver work in uhf with dish 21.1 remote
No, the 510 receiver does not have a UHF input. http://manuals.solidsignal.com/DVR510.pdf You can upgrade to a 512, 612, 625, but would need your installation upgraded to be compatable (Dish Pro to Dish Pro Plus).
Sep 03, 2012 | DISH Network 322 DTV Receiver
HOW CAN i RESET SAT CODE FOR DIH REMOTE CONTROL FOR DIFFERENT DISH BOX
nmg55
Not all remote are compatible with all our receivers. Depending on the receiver and remote model numbers, if they are compatible you can readdress the remote to the receiver. I have provided a link for readdressing the remote to the receiver. I hope this helps.
Instructions on how to readdress the remote to the receiver:
http://www.dishnetwork.com/SupportSection/remote-setup
Remotes and receivers models:
222 -
21.0 IR / UHF Pro
222k - 21.0 IR / UHF Pro
301 -
3.4 IR
311 -
3.4 IR
322 -
4.4 IR / UHF Pro
381 -
6.4 IR / UHF Pro
411 -
20.0 IR
501 -
6.4 IR / UHF Pro
508 -
6.4 IR / UHF Pro
510 -
6.4 IR / UHF Pro
512 -
6.4 IR / UHF Pro
522 -
6.4 IR / UHF Pro
612 -
21.0 IR / UHF Pro
622 -
21.0 IR / UHF Pro
625 -
6.4 IR / UHF Pro
722 -
21.0 IR / UHF Pro
722k - 21.0 IR / UHF Pro
Ray Calo
DISH Network
Nov 06, 2010 | DISH Network IR Remote Control
My remote is not working. On the back it says 6.2 IR/UHF PRO Canada: 1707A-DKNFSK03 139779 It used to work fine, then I had to change the batteries and it no longer works. The lights work but nothing...
The switch that selects what type of remote style (UHF or IR) is probably the culpret.
pull the battery cover and take out the blue tab
Play with the switch unitl it works and put the tab back in (the tab is supposed to select the right value for you but it may not be properly aligned.
i was about to toss mine but this worked.
Dec 24, 2009 | Bell SH50102 Remote Control
Bought a dish identical remote to Bell Expressvu.
Nov 06, 2009 | DISH Network IR Remote Control
Oct 13, 2009 | Bell Televison & Video
Uhf pro 8.0
Sep 21, 2008 | DISH Network IR Remote Control
Dish network remote
i would suggest trying power scan again...
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
Jul 06, 2008 | DISH Network IR Remote Control
Receiver wont produce sound
This model is a real "beast" to repair and keep repaired! Best left to the "experts"!
Oct 28, 2007 | Kenwood VR-5900 Receiver
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
