Question about First Alert Home Security
Baby monitor The camera works with (4) AAA 1.5v batteries but does not work with the 6v power adapter. The power adapter is putting out 6vdc as measured on a multimeter
joecoolvette
  • 5660 Answers
SOURCE: dv6000 443775-001 power issue
At the risk of subjecting myself to your possible wrath, I suggest you replace the motherboard. I don't know your computer repair prowess, and am not doubting it for a minute, but I 'stand' here to tell you, that it's just not that simple.
The hardware components are installed down into a bare motherboard. The leads for the hardware components are in their 'raw' state, where they hang down past the motherboard. Then the motherboard is heated up using a hot air soldering method, and the solder flows over the leads making a precise, pretty little solder joint. This is done with robotics. Once this is accomplished, the extra length of lead is snipped off.
Some components are installed by hand. Very few of them. The operator uses a soldering station, and an instrument that magnifies the area by a great amount. Looks like a binocular microscope. One, two ,three, and the next motherboard comes up, and the same part, by the same operator is installed once more.
Again, not doubting your expertise in this area, but if you have use much heat, or linger too long, you stand the chance of making the copper circuit trace, lift right off of the motherboard, when you go to remove a component. Not enough heat, and you can't remove enough solder, nor get the lead to come out of the hole. (I use solder wick. Also known as Desoldering Braid. Solder ****** tools are for the bird's! (Desoldering Tool)
Same thing with soldering a new component in place. Too much heat or linger too long,....well you know what happens. Not enough heat, or staying in position long enough, plus using the right technique, you get a cold solder joint. It's a lot of fun, when you reassemble the laptop all the way, and find this! Guess what happens next? Yep! Do it all over again!
I'm not a saleman for Ebay, but I find a lot of my motherboards for laptops on there. I would also suggest looking at -> Laptops for Parts.
Posted on Apr 14, 2009
kb8dns
  • 494 Answers
SOURCE: No 6V power via power adapter to Sony ICF-SW7600GR
Could be a diode or a capacitor. Where are you located?
Posted on Feb 09, 2010
  • 13 Answers
SOURCE: Belkin F6C1500-TW-RK discharged new batteries, won't recharge
This sounds like a battery issue...I would have the unit and batteries tested at your nearest batteriesplus store... www.batteriesplus.com
Posted on Aug 04, 2010
n5kb
  • 349 Answers
SOURCE: Model: Acer Aspire 3680 symtom:Unable to
It sounds like the connector where power is plugged in. Take to a shop to check this.
Posted on Aug 16, 2010
Terry Corrow
  • 10875 Answers
SOURCE: Why doesn't it work?
its broke,You will receive an answer like this if,you did not include the make or model or serial number or
date of manufacture or complete problem and what needs to be done.
Posted on Jun 08, 2015
Why won't our Lorex Care and Share monitor work with the camera?
Make sure you have the proper power adapter plugged into the camera. It should be a 5V~1A power adapter.
Visit the Lorex Support website: Welcome to Lorex Support
or lookup the Trouble shooting section in the manual:
https://www.lorextechnology.com/downloads/video-baby-monitors/BB4321T/CARE-N-SHARE_MANUAL_TRILINGUAL_R2_web.pdf
Jun 16, 2014 | Lorex Live Snap Video Baby Monitor
I want to buy a battery charger. Where do I purchase?
Hello
The external power adapter for your device is for [6VDC - 1 Ampere]. You can use any adapter with this capacity to charge the battery inside the your Philips Da1000. Brand is not matter, but the voltage and current is. Just check the DC socket polarity. It is the main thing that ahs to be checked. Some sets will have outer (+ve), and some others have (Outer (--ve). This will be marked at the DC in terminal of your radio. It is best to be the set in hand, when you go to buy a new one. This adapter can be bought from most of the electronic spare parts selling shops at your town. Philips has designated as [6V direct current, positive pole to current pin] as pin confuguration for the AC adapter. If so outer ring connection will be (--ve). Anyway, make sure about it before buying a new one. OK.
Aug 30, 2011 | Philips DA1000 FM Radio
We've got a santa fe and the sound button is working but the train doesnt move
sounds is run by 3 aaa batteries under the smoke stack and train is run by 6v battery under the seat, 6v battery probably need to be connected or recharged
Jun 06, 2011 | Peg Perego Santa Fe Express Ride On Train
My graco monitor has one red light and a row of green, instead of all green, and it is not making any sound anymore
Try pairing the parent and nursery units again. First, turn off all of the units. Place the broken parent unit within 5 feet of the nursery unit. Turn on the parent unit. Turn on the nursery unit. Within a few seconds, the top 4 green LEDs should shut off. Then you'll hear a few beeps and the connection LED should turn from red to green. If this doesn't work, power off and try again using the AC adapters instead of battery power. I did it without plugging in the parent unit but the battery died as soon as the units paired up again. It's working fine from the docking station though.
Dec 15, 2010 | Graco Imonitor Digital Baby Monitor
I have an old Brandt, Bodi-Tek pulse monitor and new batteries aren't working... what ac plug will work on it?
I HAVE THE SAME UNIT AND IT USES A 6VDC/300MA REGULATED PLUG IN THE POWER ADAPTER.
Hope this helps
Deane.
Panama City Florida
dtrompeter@gmail.com
Nov 16, 2010 | Health & Beauty
Replaced the 4 AAA batteries still does not work
There may be a button battery on the bottom side of the camera. Look for a circle about 3/4 of an inch in diameter with a screwslot in the middle. This battery number is "usually" CR2032.
Jan 06, 2010 | Minolta Maxxum 7000 35mm SLR Camera
Vivitar 2000 with canon xs
Trigger voltage doesn't have anything to do with the power source. Even though you're only giving it 6V (4 1.5V batteries), it ramps it up internally for the photo tube.
Old cameras used a mechanical switch to fire the flash, so the voltage didn't matter.
New cameras, like your XT, have an electronic switch and eventually will burn out, like Anonymous said. They want 6V at the hotshoe. You're giving it 56V... I know it works now, but it'll fry it eventually. You can get a hotshoe adapter that will isolate the voltage from the camera.
Dec 25, 2008 | Vivitar 2000 Flash
Doesnt stay on
This camera eats the batteries. I have had the same problem. I would suggest buying rechargeable batteries and keeping them fresh. It will work fine with a new set of batteries. The 30 day battery life is a lie. More like a couple days if that. I use this for paranormal research and since I don't need it in a field or trail, I have a conversion from D cell to 110 volt below.
BE-4AA adapter, four AA to D size shell adapters along with a 110VAC to 12VDC adapter . This will give you 4 D size cells and an output voltage of 6VDC @ 500mA, from a 110VAC source.
But if this in on a game trail, there will not be a use for the 110 volt. Bushnell needs to review this camera alittle better and fix it's energy drain.
Nov 03, 2008 | Bushnell Trail Sentry 11-9200 Digital...
Home Security Logo
18 people viewed this question
Top First Alert Home Security Experts
charlie rodriguez
charlie rodriguez
Ronny Bennett Sr.
Ronny Bennett Sr.
woodzowl307
Are you a First Alert Home Security Expert? Answer questions, earn points and help others
