Question about Sony Ericsson XPERIA X10 Unlocked QuadBand GPS WiFi HSDPA Cellular Phone X10i Black
Setup wizard com. sony ericsson . setup wizard
Need calibration on sony ericsson p990i
Recalibrating the screen is a rather simple matter on this phone.
Navigate to Control Panel\Other\Setup Wizard
Then, follow the on-screen prompts and you should be good to go.
If problems still persist, it may be possible that you are in need of a new LCD on the handset itself, which can be costly and difficult to install. Take the phone into a professional near you for an estimate.
Jun 14, 2011 | Sony Ericsson P990i Cellular Phone
I cant find the setting for pen calibration of P1i.where is it?
Hi. It is part of the setup wizard. I think it is on step 6 where the calibration takes place. The wizard is in advanced tools. Cheers!
Feb 13, 2011 | Sony Ericsson P1i
I just need to set it up...how do i do that?
Hi,this is how you set up yous sony ericsson W880i,
1.you insert the battery in the battery slot behind the phone,and turn on the phone from the power button in the keypad,
2.when the phone comes on,you will be asked if you want to setup wizard,click yes,
3.Follow the instuctions,given by the phone step by step until the phone completes the set up.
4.Exit the set up wizard,and start using your phone.
Take care
Mar 10, 2010 | Sony Ericsson Walkman® W880i Cellular...
Calibrate
go to main menu> control panel> general> setup wizard
click next untill pencabration comes
Feb 10, 2010 | Sony Ericsson G900 Smartphone
Whenever i get a picture message sent to me i just get a failed connection error...why..? Im using erickson z530i on vodafone payt
If you have problems sending or receiving MMS (picture messages) on your phone, you probably need new settings installed in your phone. Go to www.sonyericsson.com/support, choose your phone, choose "Phone Setup - MMS" then go through the wizard. When you've done this they'll send you the new settings in an SMS.
If you can't find your operator in the list,you need to contact your operator to get the settings. Many operators have similar settings wizards on their websites.
Sep 18, 2009 | Sony Ericsson Z530i Cellular Phone
Bottom of touch screen (G900 handset) doesn't respond
use the myphoneexplorer free software to run the setup wizard in main menu>settings>general. use the L and R buttons on the software after you connect it via usb inphone mode to your computer to run the wizard and then calibrate the touchscreen... it solved the touchscreen problem for me..
Aug 03, 2009 | Sony Ericsson G900 Smartphone
P990i touch screen not possible to calibrate
First, upgrade the software of the phone. After the upgrade, the setup wizard appears; complete it, and start it again from "Control panel", "Other", "setup wizard": now, just press the next button until 1 2 3 4 appears in the screen: don't select anything else, just the next button, or the calibration screen would not appear.
Jun 17, 2009 | Sony Ericsson P990i Cellular Phone
Sony ericsson k750i want to share the internet connection
if you use windows xp, go to network connections and start Network Setup Wizard and choose the appropriate options.
Apr 10, 2009 | Sony Ericsson K750i Cellular Phone
Touch screen not working properly
you can do it by running setup wizard, located in control panel->others-> setup wizard and follow instructions till you will be asked to tap on blinking points.
Sep 10, 2007 | Sony Ericsson P990i Cellular Phone
Sony Ericsson XPERIA X10 Unlocked QuadBand GPS WiFi HSDPA Cellular Phone X10i Black Logo
14 people viewed this question
Top Sony Ericsson Audio Players & Recorders Experts
Dai Boyce
Dai Boyce
Are you a Sony Ericsson Audio Player and Recorder Expert? Answer questions, earn points and help others
