Question about Hitachi 42PD7200 42 in. HD-Ready Plasma Television
Hitachi LCD TV Dead
TV is just under 2 years old and was fine last night. Now totally dead. Have changed the fuse in the plug, checked the power lead and tried a different socket. Is there an internal fuse that may have blown? Thanks.
  • Hitachi Master
  • 933 Answers
There is a internal fuse on the power supply board. When you plug in the set, does the standby light come on?
Posted on May 11, 2013
Testimonial: "Just noticed the model is wrong in the heading. It's a 22" Hitachi LCD L22VG07U. When plugged in there are no lights at all."
4 Suggested Answers
repairtech99
  • 767 Answers
SOURCE: no power - have checked fuses, power leads and master switch
Well yes, there a problem in the power supply modual.
It does sound like a failing power supply , becuse of the
fact you don't get charge up spark from the plug , wich is normal
affter it's been off /unpluged for 20 min or so .
check the resistance of the plug coming from the set with a volt meter if you have 10 meg ohms or higher,
it's an open circuit and more than likely a 1.50 fuse in the power
supply. If the fuse blows instantly then it's a shorted output transistor or rectifier diode in the switching power supply.
Be a shame to pay 300.00 plus for a stupid fuse.
hope that helps a little . if you have any questions just comment
an i'll respond
Rob
Posted on Oct 04, 2009
  • 8457 Answers
SOURCE: Dead TV
U know basic electronic's,and u know how to do soldering?Have soldering iron,tools and solders?The power supply board,the board that the power a/c power cord plug into it.That the power supply board have these parts call capacitors are dead.These capacitors alway bulges up on it top or puff on it top.Check all around the power supply board and it supporting boards.Replaced these dead leakage bulges up on it top or puff up on it top.Or tries websites like Shopjimmy.com,Ebay.com to buy and replaced the whole refurbish power supply board.
Posted on May 28, 2010
jdvillanueva
  • 2098 Answers
SOURCE: my hitachi 42pd6600 is not working,switched it off
Hi Peter,
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the power supply board, try online like ebay.com and shojimmy.com.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Posted on Mar 11, 2011
TV Totally Dead
If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
May 10, 2013 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
I shut the tv off last night and now it won't turn
If total dead (no lights on blinking etc) follow power cord into the set and find and check the main fuse--in this set it usually is a glass 5 amp fuse.
Dec 19, 2012 | RCA P52926 52" Rear Projection Television
Model DP26649 No pic no sound no warning. Shut off last night and dead today. Will be 2 yrs old in August.
Now the tv it is completely dead no LED power light indication is on at all or the tv power LED light indication blinking too?Check the power source?Tries tv unplug,replug it back about an hour later for the tv do a resetting itself back to the factory setting,tv should be working again.If not the tv power supply board it is dead,that the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 17, 2011 | Sanyo DP32746 32 in. LCD Television
I have a 32inch hitachi and was working fine turned it off and when i went to turned it on nothing happened not even the red light came on have tried changing the fuse and still nothing only had it 18...
Check ur house power outlet source?Yes.Than the tv whole power supply board it is dead,modern electronic equipments rarely have dead fuses alone or only.Tries websites like Shopjimmy.com Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 30, 2011 | Hitachi 32LD8700 32 in. LCD Television
MY VP42HDTV WILL NOT DO NOTHING WHEN I PLUG IT IN WHAT COULD IT BE.
Hi if you plug it in at the mains and switch it on and you get nothing not even the standby light then this points to either a fuse been blown so check the fuse in the plug failing that it will mean getting a new power board fitted, now if the telly is more than say 2 years old i would say its not worth getting fixed as the chances are you will replace the power board and then you will start having problems with the inverter, soyou could end up throwing money down the drain.
if its less than 2 years old and its totally dead check the fuse in the plug change it anyway and then give it a try but if its still totally dead then this points to either the fuse been blown in the telly this is a little clear glass fuse located where the mains cable plugs into the main power board, if this fuse is not blown also then the whole power board will need replacing.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Nov 28, 2010 | Vizio VP422 42 in. Plasma TV
Hi my 3 year old 32" t.v just died last night, electricity is fine at plug and through scart but t.v just went dead, no bang or anything, just blank. Please help, thanks Liz
Your tv died on three things
such as,
Ac fuse is out of order
Bridge diod may be short curciet
Power transistor out of order.
check it htoroughly
then fix your problem
Mar 12, 2010 | Televison & Video
Monitor dead
Check your power cables properly and make sure it is attached. Check your power button, maybe you have pressed the wrong one.
Jan 03, 2010 | Acer AL1916W 19" LCD Monitor
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
I have a 2 week old Sony Bravia KDL-40V4000 It will not turn on
Try using a different wall plug one you know that works run an extension cord if you have to check it. Lastly are your wall plugs grounded 3 prong plugs? The old fashion plugs with 2 prongs are not sufficiently grounded and that may be your problem and you would need an electrician for that. Otherwise you may have a defective tv. BTW how did you change the fuse in the plug? Are you talking about the breaker box?If so you probably do have a grounding problem.
Mar 22, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
HITACHI 37PD5200 E Plasma dead.
The fuse is either open or it will have continuity do you have any standby voltages
May 14, 2008 | Televison & Video
Hitachi 42PD7200 42 in. HD-Ready Plasma Television Logo
264 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
