Computer Will Not Power Up
My mergers is working for my wireless things, however I'm not sure if my comcast router is working properly. All lights are on on that router, just one blinking
  • 7,627 Answers
I don't quite follow your question? My mergers? My wireless things? If you are referring to laptops/Desktops, connect a Ethernet Cable directly to the Comcast Modem. You can call Comcast to verify the signal and sent a fix signal, basically a reboot, which you can do by removing ALL power from the modem and wireless and replace battery, plug in the Modem, wait for selftest, plug in the wireless device, wait for selftest, try again. As to the Computer not powering up, that's another issue.
Posted on May 10, 2013
SOURCE: no power led, wlan led blinking
remove the power adaptor for about 5 min. and plug it again.
reset the wifi router to its original setttings (factory default) and configure again the settings.
check your network card disable it and reenable it again
same thing with your wireless card
Posted on Feb 27, 2008
mspcrepair
  • 169 Answers
SOURCE: arimex comcast router won't talk to belkin wireless g plus mimo router
Comcast has a little known "trick" that they use when setting up users. Here's how it works:
When Comcast first comes to setup your new cable modem service, they insist on connecting it to your computer and "testing" it. Most people think nothing of it, and that it's good customer service ...truth be told, what they are doing is attaching your computer's MAC address to that cable modem, so that you cannot create a wireless network. This is because they want you to pay them $150 to do this for you.
In this situation, since the modem is a modem/wireless router in one, my guess is that the MAC address on your machine now does not match the MAC address on the new router, which is what Comcast has stored in their database(s).
Try this: on your computer (while connected to the modem), perform a release on your IP address (start, run, cmd, then type "ipconfig /release"). Disconnect the ethernet cable from the computer. Turn computer off completely. Hold down the reset button on the cable modem until it performs a reset. Once it's back up and running, boot up your computer with the cable back in the ethernet port.
The cable modem should assign a new address to your computer. However, that may or may not work ...this is an easy workaround with a Linksys router, but not necessarily with the all-in-one devices.
Worst case scenario: contact Comcast and notify them that the new modem is not recognizing your computer's MAC address and that it needs to be updated in their system. They will scan your computer (through the telnet interface on your modem) and get your computer's MAC address, then (hopefully) make the necessary changes on their end.
After that, everything should work flawlessly. If not, insist on a Comcast tech to "fix" the service that you are paying for.
Good luck - hope this helps :)
Posted on Sep 29, 2008
sitehr
  • 94 Answers
SOURCE: My router is not broadcasting wirelessly
their is option in setup to enable wireless or disable it go to modem setting page and enable wireless function
Posted on Aug 17, 2009
Geekman
  • 32281 Answers
SOURCE: Modem router light blinking (no wireless connection) F5D8631-4
Try restoring the Belkin back to the factory default by powering up the Belkin and pressing the RESET button on the back of the Belkin for 7 secs. Then connect a LAN cable from the computer to the Belkin, open IE browser and type the configuration IP address and configure the wireless settings ie. SSID, encryption etc. The computer wireless cards will need to be configured with the Belkin wireless settings to allow them to communicate with the Belkin.
Posted on Nov 12, 2009
Baloney King
  • 38 Answers
SOURCE: Should the status light be blinking?
you should call the wireless manager.
good luck.
Posted on Jul 26, 2010
I need a simple set-up manual for model # WRT54GS router
Your Internet service provider is comcast cable company.
You need to open the setup page of the router and change the Internet connection settings manually.
Connect the computer to the router and modem to the router.
Open the setup page of the router using 192.168.1.1
Click on MAC address clone. Enable it and click save settings.
Power cycle the router and your main computer will be online.
Then you can change the wireless settings manually.
Click Linksys router setup steps
Jan 04, 2012 | Linksys Wireless-G Broadband Router
My wireless is not connecting to my computer its saying UNIDENTIFIED NETWORK ACCESS LIMITED CONNECTIVITY
You may be connected to the router, but the router may not be properly connected to the internet. You could try unplugging the router's power for 15 seconds, then plugging power back in. Also, try making sure all the cables in the back of the router are plugged in properly. The last thing you could try is restarting your actual modem. This is the device that actually connects to the internet, and it sounds like you're having internet connectivity issues. So the problem may be there.
Sep 12, 2011 | NetGear WGR614 Wireless Router
The internet connection in my area went down yesterday, but i didn't know this and thought the reason i couldn't access internet was a problem with my linksys wrt54g router. So i unplugged and...
The first thing you should do is a proper 'powercycle' for all of your internet equipment.
To do this:
1) Unplug the power to your modem and your router, and power off your computer.
2) Wait a full minute.
3) Plug the power back in to JUST the modem.
4) Wait some more - for the modem to fully connect to your ISP, and the lights to indicate. If you're not sure, just wait about 2-3 minutes.
5) Plug the power back into the router.
6) Wait another minute or two for the router to finish connecting.
7) Then turn the computer back on.
You can bypass the computer turning on and off if you can repair your wireless connection.
If this doesn't work, there is a pinhole sized reset button on the router itself that you will need a toothpick or somesuch to press - press and hold the button for 5 seconds, and then try the steps above again. If you do this, the network id and password will be reset to the default, just like it was when you bought it.
Jul 20, 2011 | Linksys Wireless-G WRT54G Router
I have a Zonet Router that I am hooking up to Comcast DSL internet. i show that i am connected but i can not get online. i duplicated the MAC address i just dont know what else can be wrong. is there a...
The first thing is that Comcast is Not a DSL connection it is Cable connection. Now first make sure that your computer will be able to go on line when connected directly to the modem. Connect your main computer directly to the comcast modem and check if that goes on line. If not then you will need to contact Comcast and get main computer on line. If it is online then reset your router for 30 seconds. release the reset and wait for 1 minute. Now connect the main computer to the router and comcast modem to the router. open the set up page and Clone the MAC address of the " Main " computer.
power cycle the modem and the router. See if it works.
Click here for more information about router and networking
Apr 19, 2010 | Zonet ZSR1104WE Wireless Router
I have recently moved from Pittsburgh, PA to Charleston, SC. My linksys Wireless G 2.4 gHz router worked great with the ISP in Pittsburg (Comcast). Now, with Time Warner's Road Runner, I get an error and I...
Connect your main cmoputer directly to the time warner modem. make sure that your computer will be able to go on line when connected directly to the modem. If not then call Time warner.
If your computer is able to go on line when connected to the modem then your modem is working properly. You will need to change the settings of the router.
First reset the router for 30 seconds. On the router you will find a small reset button. Hold it down for 30 seconds. release it. wait for 1 minute. now unplug the power to the router and plug it back in. wait for 30 seconds till the power light on the router will be solid.
Now connect the modem and the computer to the router.
Now you will need to clone the MAC address of your main computer to the router. you will neeed to open the set up page of the router.
once your main computer is online , you can change the wireless settings of the router and connect to the wireless network on the laptop.
Click here for step by step solution
Apr 10, 2010 | Linksys Wireless-G Broadband Router
I have comcast cable net and D-link WBR 1310
Hi, forget about the USB connection since you wanted to use a router for your wireless connection. Contact Comcast asnd make sure they assist you in making your computer connect to the Internet using the ethernet connection because you are going to use the ethernet connection for the modem-router connection. Once your computer is online with the ethernet connection, you can connect your Dlink router to the modem and configure it for Internet connection. There will be more steps before you can use the wireless connection. Just make sure you can get online with ethernet connection first.
Jul 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Linksys wrt160N router inconsistant internet connection
Check on your cables makes sure they are inserted properly and the cord should be free of kinks, scrapes or loose connections......Also check the back of your computer make sure your ethernet card (the one that has the green lights/LED's) is seated properly (not loose)....
Good Luck.....hope this helps...if not let us know....cheers
Apr 13, 2009 | Linksys WRT160N Wireless Router
Wireless G and Comcast cable internet
Im not sure about the monopoly thing?
But it must the settings that is causing a problem.
If I understand you concern correctly your computer is connecting to the router wirelessly, is that right?
and can you get online if the computer is wired directly to the router?
Jul 21, 2008 | Linksys Wireless-G Broadband Router
Problem with initial install
hello!
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on
Step 7: test the Internet connection on both pc
if this still didnot work, upgrade the firmware of your router
May 30, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
David Payne
David Payne
