Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Undefined correct way to adjust valves
  • 21 Answers
Order new Rocker Cover gasket for your Engine Code located at top of motor nameplate)
Drain Oil. 3 pints SAE 30
Remove OHV rocker cover 4 bolts carefully and remove rocker cover and toss old gasket. Clean rocker cover with a clean rag and set aside. Fetch standard feeler guage which has a .003" and a .005" available.
Exaust valve .005" is the top one and Intake .003" is the bottom.
First check the gap between the rocker arm and valve tip.
If they need adjusting then you will need star driver to slightly loosen the center star screw then use a 10mm or 3\8 ( i think )
To slighty adjust the outter bolt until its almost tight to feeler guage then at same time while holding the outside bolt, tighten the stardrive center until tight. It will still pull it in a bit is why I say "almost tight".
You will need to reinstall new OHV rocker gasket around the rocker pan, set the top 2 bolts to help align and you might need to shift the rocker cover upward while bolt it down so the bottom edge is high enough onto motor. Do not over tighten. Aluminum is soft. You may use some "weakest" loc-tite product but I never do.
Posted on Jun 13, 2013
Valve clearance on suzuki vitara 1999 1.6
  • Set the engine to Top Dead Centre (TDC) of the compression stroke for the cylinder to be adjusted.
  • Check the valve clearance. The valve clearance specifications are as follows:
    Intake valves: 0.005-0.007 inches (0.13-0.17mm) Exhaust valves: 0.005-0.007 inches (0.13-0.17mm)
  • After adjustment, tighten the lock nuts to 11-14 ft. lbs. (15-19 Nm).
  • Repeat for each valve to be adjusted.
  • Feb 16, 2017 | Suzuki Cars & Trucks
    Beetel undefined connection error 123
    The problem is your 3G setup.
    1. Plug the adapter in any of the USB ports
    2. Go to connect to or click the wireless icon on the bottom right with a signal bar or computer icon
    3. Select 3G and connect to it.
    4. go to command prompt. Start>all programs>accessories then click CMD
    5. type in ping(space) any website then enter. If you have replies then it`s good to go.
    6. if not, remove, then add the APN settings on your modems configuration, checking they are correct.
    Dec 09, 2014 | Computers & Internet
    6.75 tocumpsi lawn mower engine 6.75 h.p.undefined
    drain the oil, then try a heavier weight oil first.
    Also due to the alcohol in the gas , sometimes they run better on the middle grade of gas.
    Sep 19, 2014 | Garden
    Hi i try to login on facebook and I get this error message.. Webpage error details User Agent: Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; Trident/5.0; SLCC2; .NET CLR 2.0.50727; .NET CLR...
    A programming error on the computer though not from facebook interface software. That could be check verified from another computer without programming variables disconfigured. A programming envirionment communicates with the codes of any software a feature that could set by an expert computer programmer requiring reconfurating or performing diagnostic functionalities. How to disable the program environments.
    1. Sign into the internet browser.
    2. locate the settings toolbar on the browser, click on toolbar that indicates options.
    3. Access the internet settings from where to disable the kind of way the computer recognises data on the network explained
    4. reconfigure the internet search setting by clicking browser defaults
    5. reconfigure all settings to defaults to achieve internet data recognition after the computer has been altered.
    Dec 07, 2010 | Microsoft Internet Explorer 8
    My internet says that there is an error on my facebook homepage.
    Here is my advice : Just go to www.microsoft.com and download internet explorer again and install it , then reboot your system . I'm sure that this will solve the problem . any way , why don't you try other internet communication softwares like ( firefox or google chrome) those both are great also . I advice you to have more than one internet communication software . I already have three just in case if one of them is corrupted . I have ( Internet explorer and firefox and google chrome ) . just try the idea and you'll be satisfied with the result .
    good luck .
    rate if useful please !
    Jan 23, 2010 | Microsoft Internet Explorer 8
    When I put X^(1/3) into Y=, and go to nDeriv, and find the derivative at X=0, the calculator gives me 100. I (and a few math teachers) have done this many times by hand, and we all get undefined as an...
    The derivative of the cubic root of x is, as you wll know, equal to (1/3)*x^(-2/3). Its limit as x approaches 0 is undefined. However the calculator uses approximate representations of numbers to calculate. And you can never be sure what it is going to give as results near singularities (poles of functions).
    Calculators with Computer Algebra Systems can do better. To show you this, I am enclosing a screen capture showing you the correct result.
    On this screen I defined a function u =f(v) where u is the derivative of cubic root of v. I stored 0 in the dummy variable v, and I evaluated the function u at v=0. You can see that the result displayed is undefined.
    That this result is deemed correct seems to me just a matter of convention. We do not know, we cannot know, or we dont care to know? It will not make any of us lose sleep.
    Hope it helps.
    Nov 10, 2009 | Texas Instruments TI-84 Plus Silver...
    Lifter adjustment
    IF I recall correctly, the Kawasaki valves are adjusted by shims as opposed to a lock-down screw or hydraulic lifters. The shims come in different thicknesses. As the valve parts wear, a change in shims is how the valves are adjusted.
    Mar 13, 2009 | 2003 kawasaki VN 800 Vulcan Classic
    Check engine light on
    Hi ,
    I have a Haynes manual and it says that code P1490 identication is Vacuum Cut Valve Bypass Valve fault (California). I hope this helps.
    Rudy
    Aug 19, 2008 | 2000 Mercury Villager
    Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
    57 people viewed this question
    Top Craftsman Garden Experts
    Dean Gruber
    Roland W VanLue
    Roland W VanLue
    Dennis Key
    Dennis Key
    Are you a Craftsman Garden Expert? Answer questions, earn points and help others
