Question about Hitachi 1TB LifeStudio 35 Desk Plus external drive 0S02674 Hard Drive
Error SyncException I have used the Lifestudio successfully for a year now and all of the sudden it has an issue. I normally plug it in and double click the short cut to Backup and it does its thing for a minute or two and all done. Now it instantly says that the backup has been done, but gives me a ! to check. When I click it, it says: "Error Syncexception- failed to create provider". When I check files on the hard drive, it has not updated any of the files. I am also wondering how to back up to hard drive block and not the key. The key is almost to capacity and is now showing red status bar when looking through my computer.
Benimur
  • 6966 Answers
SOURCE: hard disk acess problem
Hi, What the message mean is that Windows can not read/understand the filing system (something like the Table of Contents in a book) and therefore do not which and where are your files in the 80Gb. A few things you can try: 1. Run Windows Scandisdk on the Hitachi 80Gb; 2. Run any third party disk check/utility such Norton Disk Doctor. Alternately, you can use a file recovery software (such as GetDataBack) to recover/copy all your important files from the 80Gb and transfer them to another mass storage device. Thereafter, you can re-partition and re-format the said Hitachi to start new/fresh/clean. Hope this be of some help/idea. Post back how things turnes up or should you need further information. Good luck and kind regards.
Posted on Oct 06, 2007
  • 916 Answers
SOURCE: hard disk error
Unfortunately this error occurs with a fault hard drive. You will need to replace the hard drive and then reinstall the OS.
Posted on Mar 20, 2009
  • 2973 Answers
SOURCE: I'm trying to use my
Try attaching the Hitachi to a different USB port. After connecting to the USB port, go to Control Panel->Administrative tools->Computer Management->Disc Management. And see if it is visible here? If yes, then you can do what you want with it. If not, then I am sorry about the HDD. I think it is still under warranty. Please make use of the warranty and return the HDD and ask for a replacement. It being a USB HDD there is nothing wrong you could have done to it. In an internal HDD you could have connected the data cable the wrong way and have caused the damage, but not in a USB HDD. So the replacement process should be smaller and smoother.
Posted on Sep 19, 2010
SOURCE: Hello I cannot transfer files from my hitachi lifestudio to my desktop or to another hard drive. It seems to copy all files except movies?
are those movies large(most likely) might be that your usb is overloaded suggest you consider using ethernet or other high volume connection
Posted on Jun 07, 2012
Geekman
  • 32281 Answers
SOURCE: Computer won't recognize external hard drive anymore Hitachi lifestudio
Try connecting the external hard drive to another computer to recover/backup your data.
When you have such a large capacity hard drive, it pays to have a second large capacity hard drive to backup your data in the event of the other hard drive dying.Hard drives do fail especially if you accidently drop it.
Posted on Jun 08, 2012
Power supply specs Hitachi Lifestudio Desk Plus
Hitachi Lifestudio Desk Plus Hlsdpub10001bbb 1TB Drive and original AC adapter have been separated. Need to know Adapter output Voltage/amperage identify original or acceptable replacement.
Sep 17, 2013 | Hitachi Lifestudio Desk Plus...
Nikon FotoShare
I would suggest reinstalling the application. Let me know how it goes.
Mar 17, 2008 | Cameras
I Have a Hitachi Lifestudio hard drive attached to my Apple G5 for 7 months now, and suddenly just dessapear of my desktop or menu the Computer it won't recognize it anymore HELP!!!!!!
Jun 07, 2012 | Hitachi Lifestudio Desk Hlsdbub5001bbb 500...
Windows xp sp3 stop error message 7e usb
Why not just pull it out instead of clicking on safely remove hardware? Try it and see if it works. Sounds like your usb drive is not windows 7 compatible. Or windows 7 has some driver issue which is not uncommon.
Jun 04, 2012 | Hitachi 1TB LifeStudio 35 Desk Plus...
Windows 7 home edition HP Deskjet D1660 Problem: Printer will print a full page document, but stops in the middle of printing a full page photo. I just installed this printer, i bought it yesterday....
I have the same problem with my printer. I don't use it too often, but when I attempt to print more than a few pages in succession, I run into this issue. Normally, the first few pages will print off just fine. Then, suddenly, it will print half of a page and simply stop in the middle. Pressing the power button gets the printer to release the stuck sheet of paper, but then it will not allow me to resume or delete what is in the print queue. I generally have to reboot my computer after unplugging the printer and plugging it back in before I can resume printing. It does this nearly every time with no known error messages. I don't understand why it happens.
Sep 04, 2010 | HP Office Equipment & Supplies
Runs at work, error at home
the restarting is an OS Problem . Please send More details . Regarding Error Code
Mar 25, 2010 | Microsoft Windows XP Home Edition
Error 7 keeps coming up when oppening itunes
A number of users have experienced problems updating to the newlyreleased iTunes 8.1.1. Generally, when this issue occurs, installationappears to proceed normally but then delivers the error message “Theinstaller encounted errors before iTunes could be configured. Yoursystem has not been modified. To retry these operations at a later timeplease return to the installer again. Click Finish to exit installer.”Fix
This problem can often be fixed by reinstalling the latest version of QuickTime via the following steps:
  1. Download the latest edition of QuickTime for Windows (make sure to pick the option without iTunes)
  2. Choose to save the file to your disk, then double-click the .exe file and install QuickTime
  3. After QuickTime is successfully installed, download iTunes again, choosing to save the file. Double-click the iTunes installer .exe and proceed with installation.
Other potential fixes for this issue include:
Run a disk check Disk errors, particularly in Windows XP, can prevent proper iTunes installation. See this Microsoft Knowledge Base article for instructions on performing a disk check/repair.
Use Windows Installer Cleanup Use the Windows Installer Cleanup toolto remove any references to Apple-related installation files(QuickTime, iTunes, etc.), then re-try using the aforementionedtwo-step method to reinstall QuickTime and iTunes
Oct 22, 2009 | Apple iTunes
Nikon FotoShare
After using Nikon FotoShare successfully for some years, suddenly on clicking "send" I get this error message 12152 and "server returned invalid or unrecognised response" What has happened
Mar 04, 2008 | Cameras
WS55711 mitsubishi RPS - Dec 2002
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
Oct 15, 2007 | Mitsubishi WS-55711 55" Rear Projection...
Hitachi 1TB LifeStudio 35 Desk Plus external drive 0S02674 Hard Drive Logo
162 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
