Question about Camping, Backpacking & Hiking
It keeps flashing f11, after I just cooked on it.
    Problem Solver:
  • 18 Answers
That's an error code being thrown by the computer unit that controls the stove. If you are handy and don't mind taking things apart, look up your unit on repairclinic.com. You can likely get the replacement part (be warned, it's probably not cheap) and a video guide to replacing it.
I did the same to my range last year--the control unit was $150. Service tech quoted me $350 to replace it (part included). Doing it myself was a pretty good deal. :)
Posted on Oct 18, 2013
  • 3,187 Answers
My whirlpool washing machine model GHW9300PW4 will not run any cycles it keeps flashing F11 in the time remaining window
Whirlpool's 'F11' refers to 'communications error, control unit'- could/might be poor cable connections. Sorry but this requires a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 18, 2011 | Whirlpool Washing Machines
F11 code flashing-washer stops
hi!!!!
try to unplug it end then check the control timer if it is broken !!!!
or open it if you know and fix it may be the spring that pull back the pause botton
might be broken go check it?
Sep 19, 2008 | Kenmore Elite 45986 Front Load Washer
When i plugged my cooker in the numbers started flashing all zeros and now none of the buttons will change the screen except the cancel button. When that's pressed the screen goes blank for a second it...
I am having the same problem. Here is what the Tiger people say. I haven't tried it yet though.
* If an external power failure has occurred, but only for a short time, then there's a possibility that when the electricity has returned, all functions may work normally and the clock is working correctly.
* When a power failure lasts for a long time, and the indicator is flashing 0:00...
--> Please set the time correctly by following the instruction manual.
If the electricity has returned as in these situations below:
(If it's already past the set time, after a lengthy power failure, cooking starts immediately.)
* While cooking rice (or reheating rice).
--> Continue to do the cooking (or reheating).
* Keeping warm (or Low temp Keeping warm).
--> Continue to keep warm (or low temp Keeping warm).
Aug 25, 2010 | Tiger JAE-A10U 5..5-Cup Rice Cooker
My dryer keeps flashing f 11 wht does this mean
Fault code F11 means that the pump is not working,
check the pump connections and the pump itself.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Dec 21, 2009 | Hotpoint Dryers
My hotpont tumbledryer keeps flashing up f11 its a hotpoint ultima ctd85 pls help
Fault code F11 means that the pump is not working,check the pump connections and the pump itself.
Please leave feedback.
Thanks.
Nov 12, 2009 | Hotpoint Dryers
Stove flashed F11 and then locked the oven door
HI, this is control failure. the logic chip set is damaged. this is causing these erratic commands and the unauthorized locking of the oven door. you will need ot replace the control in this case.(EOC/clock)
May 29, 2009 | Frigidaire FEB27S5A Electric Single Oven
F11 flashing kenmore he washer
The F11 error code indicates a serial communication failure. This happens when the 2 main control boards are unable to communicate with each other. This is either caused by a loose wiring harness connection or one of the control boards is defective. Good luck and please rate FixYa!
Dec 28, 2008 | Kenmore Elite 45986 Front Load Washer
F11 Kiss of Death!
f11 is in my experience has been a faulty rear board, its really a communitcation error betwwen the control board, the latch and the lower motor control board(rarely an issue with the motor controller, but have seen faulty wiring(in which case had to replace the entire wire harness, as well as ann occasional door latch. keep after it under warr, so when it does runn out youll have records of attemps to fix while underwarr and make them make good on repairs after warrr expires
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Could you tell me what F11 code means?
F11 error code means there is a problem with the Control panel. Could be melted wiring, etc, since you left the oven standing. However, you can try unplugging the device from the power socket for about 5 minutes and reconnect. If the error goes away, then well and good; if not, you may have to replace the panel control.
Oct 13, 2008 | Frigidaire Kitchen Ranges
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Camping, Backpacking & Hiking Logo
478 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
