Question about Toshiba Satellite L675DS7060 NoteBook
Need boot media download cd - Toshiba Satellite L675DS7060 NoteBook
  • Toshiba Master
  • 7,627 Answers
Contact Toshiba Support for a Factory Recovery DVD. Have you tried a Factory Recovery from your Recovery Partition?
Posted on May 10, 2013
How can you figure out the administrator's login password on a windows xp computer
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Dec 01, 2012 | Samsung Yepp YP-T7JX MP3 Player
Reboot and select proper boot device or insert boot media in selected boot device and press a key w7
Give this a try you probably have a mbr virus..
Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up.
Kaspersky rescue cd download:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Imgburn download:
http://majorgeeks.com/downloadget.php?id=4870&file=15&evp=0636b68877cb69b15faa3374cb1dcd89
Sep 05, 2012 | Gateway SX2855UR20P Desktop (Black
Pxe-e61: media test failure, check cable acer extensa 542
Your computer tries to "boot" from several devices:
* floppy disk
* CD/DVD optical device
* disk-drive
* external CD/DVD
* USB memory stick
* PXE ("Pre eXecution Environment)
To use PXE, you need "media" -- a network cable connecting yur computer to a "boot-server". The "media test faiure, check cable" reports that no network-cable exists, or that it does exist WITHOUT being connected to a boot-server.
Probably, your computer failed to boot from a DEAD disk-drive, and then tried floppy/CD/USB before checking PXE.
Replace the disk-drive.
Jul 30, 2012 | Compaq Presario-Notebook 700 Series, 2500...
Disk read error
it is entirely possible that the boot sector is damaged. if this is the case you need to boot with the cd that came with the machine, or a recovery cd you've made, and load the recovery environment. once their load the command prompt. it should just be a button in vista or 7 and it will automatically load in xp. once loaded type "chkdsk c: /r" no quotes. let it run, this will check for bad sectors and should fix the issue. try and reboot, and let me know what happens. if you don't have the recovery cd's or installation media you can download msdart, which has the recovery console built in. i went ahead and uploaded msdart, download the version you think you need. https://rapidshare.com/files/2296685117/ERD50_x86_WinXP_SP3_blueforce.ziphttps://rapidshare.com/files/2914560443/ERD60_x64_WinVista_SP2_blueforce.zip https://rapidshare.com/files/267688033/ERD60_x86_WinVista_SP2_blueforce.ziphttps://rapidshare.com/files/1400985026/ERD65_x64_Win7_RTM_blueforce.ziphttps://rapidshare.com/files/3314839442/ERD65_x86_Win7_RTM_blueforce.zip
Jan 05, 2012 | Dell LATITUDE Computers & Internet
Blue Screen doesn't load Operating System. I beleive there is a software conflict when my daughter downloaded an application she needed for university
If you are getting 'Uncorrectable data Error or Media' for your internal hard drive then it is likely that you have a disk problem rather than a software conflict caused by anything your daughter downloaded.
If the Dell diagnostics provide no solution, then you would need to use a specialist boot CD to try to repair the disk errors. One such disk is Hiren's Boot CD which can be downloaded as a CD image file (.ISO) from http://www.hirensbootcd.org/ then would need to be burnt on to a blank CD then the laptop booted from this CD.
On the initial Hiren's boot menu, select DOS programs, then select Disk tools before selecting HDAT2 to perform the disk repair actions.
HDAT2 can take some time to complete depending on the size of your internal disk drive and the number of bad sectors or other errors encountered - the tool will attempt to repair bad sectors by reading, verifying, writing and re-reading / verifying the data.
If the disk can be recovered, then you may be lucky and the system will be able to boot but otherwise, you may still need to do some further recovery work for the operating system, in which case you may need your Windows install or recovery CD media.
Dec 22, 2011 | Dell Inspiron 6000 Notebook
How do I download or get gateways 500 gr recovery disc ? I need everything reistalled
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer. Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Sep 22, 2011 | Gateway 500GR PC Desktop
My samsung will not boot up and i have no os recovery discs though just downloaded one and that wont boot, tried lots of different options in boot setup and pretty sure its fucoooed removed hd and put it...
Sep 20, 2011 | Computers & Internet
You hear my hp 490n media start up. the fan start then it read it shuting down to protect my files
This could be several things, from your desciption.
First disconnect every accessorie you have to reduce the load on your power supply.
Then start it and see if it boots ok, if soo you may need a new or bigger Power supply.
If not then try pulling all the memory form it and put just one stick of memory in and try to boot then, if you get the same error then try another stick if this does not work.
download Hiren's boot CD and burn it to a cd, place it in the CD drive change your boot options to boot from CD first. then boot.
If hiren's boots then use the disk drive diagnosis software and find out if there is a problem with your HD.
Good luck
Oct 06, 2009 | HP Computers & Internet
Can not boot dell 6650 from external dvd
Have you checked boot device options....from BIOS
Use F9 during boot to goto ROM-BIOS and change Boot device option to CDROM/DVDROM.
Insert Boot media or DVD-Win2003, to DVD-ROM device..
reboot Server, try now
If still issue.. Check to boot Server using some other media..
if other cd media works, then it could be DVD-Win2003 faulty, otherwise download firmware for CD/DVDROM and upgrade it and check if DVDROM works, otherwise you have to contact Dell Support..
Oct 06, 2009 | Dell PowerEdge 6650 Server
My pc crashed and on restart it asks for me to reboot and select proper boot device OR insert boot media in selected boot device and press a key- I don't have the boot media c d and can no longer get
Listed below is link to HP drivers page for M270. The recovery Windows Media Center CD is no longer availabe for purchase. If you have a license copy of Windows XP you can install then download remaing drivers from link listed below:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=339679
Apr 29, 2009 | HP Computers & Internet
Toshiba Satellite L675DS7060 NoteBook Logo
20 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
