Question about Gates 2003 Ford Focus Belt Tensioner
Engine revving when doing 10 mph the engine revs high , just had timing belt and altenator belt replaced
  • 3,976 Answers
Sounds like the stop pin has been moved check on the throttle there is a little stop screw see if it is coated in muck and the part that the throttle arm hits the pin. someone may have moved its setting before hand. and now the problem has been fixed with a new timing belt the timing is right and engine is running smooth. if engine is pinking the timing belt is still not set properly and this is the reason for high revving. timing is to advanced. and needs reseting.
Posted on Oct 20, 2013
Revving of engin between 3000 and 4000 revs on ople astra is it the timing belt
please explain what is happening. Timing belts have nothing to do with engine rpms other than to keep the valves in correct time. If the engine just revs up to 3-4000rpms then there are other sensors that are faulty. run the fault codes to find out which ones may need fixing.
Dec 09, 2014 | Opel Astra Cars & Trucks
Chirpping in the engine
might be a bearing in your altenator or water pump, is it high pitched? does it go away if you rev the engine? if it goes away it might be the belt and u could try some belt dressing, its a spray u put on the belt that stops it from squeking
Apr 11, 2013 | Chrysler PT Cruiser Cars & Trucks
After i had to jump start my 2006 mitsubishi galant, the engine started to rev up pretty high and when I put it in gear it went rolling kind of fast. I don't feel I can control the acceleration. What do I...
One possibility is you have corrupt data in the engine computer parameter memory due to the low voltage and jump-starting surges. Disconnect the battery, wait ten minutes, then reconnect the battery and follow the engine computer training procedure (this may be titled "After Changing the Battery") in your owner's manual. Usually it's something on the order of letting the engine idle for a period of time, shifting through the gears if you have an automatic transmission, then driving normally.
May 02, 2011 | 2006 Mitsubishi Galant
My headlights on the car will not work..I revved the engine and all the headlights went out. I also noticed the radio staticked out when i rev motor also..could this be from the altenator surging???
The headlights and fog lights were burnt out. The battery was also boiling rapidly like a kettle...Hmmm i think the regulator is shot. I had to remove the altenator.(you can tell the engineers never tried to change one) What a terrible chore to remove the altenator, and find the maxi fuse...OMG if id only known Id bought a CHEVY .
Feb 14, 2010 | 1998 Ford Contour
Car stalls while pulling up to stop signs or red lights
check battery connections tighten altenator belt or replace altenator
Jul 07, 2009 | 1997 Mitsubishi Mirage
Hi I have a '98 megane RT 1.6 petrol, the engine is having issues
coil packs. im sure your car has them pencil coil packs, these are ****.
if it has a torx bolt holding it on to head its your problem, ps buy a spare u will need it.
Jul 01, 2009 | 2005 Renault 181
My 1992 Chevy Blazer S 10 is revving really high when it starts
i have an s10 that would rev up high. i hooked up my scanner and it didn't give me much information, so i started researching. it took a while. i got my manual out and looked up all of the sensors in the fuel system. i even paid some web site $10 for help {wasred my $10} and they were no help. so i researched all of the sensors and found out their symptoms when they malfunctioned. the culprit turned out to be my water temp sensor. here is how it works, when you first start your engine the water is cold, the sensor sends out the information to the brain [warm me up] so your engine idles high to help reach operating temp quicker. when the sensor malfunctions it will send the wrong info to the brain [i'm cold] so the brain revs up the engine in an effort to get warm .i replaced the water temp sensor and the engine is back to normal.
Nov 19, 2008 | 1992 Chevrolet S-10 Blazer
98 nissan frontier
acts like maybe a timing belt problem.
Sep 13, 2017 | 1998 Nissan Frontier
Intermittent high revving!
Throttle position sensor.
Jun 25, 2008 | 1998 Ford Escort
Gates 2003 Ford Focus Belt Tensioner Logo
479 people viewed this question
Top Gates Home Fencing Experts
crkuc
R Daniel Wolfe
 Russ Hill
Russ Hill
Are you a Gates Home Fencing Expert? Answer questions, earn points and help others
