Question about JBL Eon15P-1 Main / Stereo Speaker
Tweeter not working - JBL Eon15P-1 Main / Stereo Speaker
  • JBL Master
  • 15,557 Answers
What is the make and model of the speaker? To trouble shoot this, you need to be able to take the unit apart. There is a circuit board inside called a crossover network, it might be bad OR the tweeter might be bad. To tell you should have a OHM meter for basic testing.
Posted on May 11, 2013
Only right side tweeter working
check you haven't got the wires on the back of the tweeter touching, Then check the rest of the wiring you may have touched. Jon
Dec 18, 2014 | Cars & Trucks
Tweeter no sound but speaker no problem
In the most general, basic sense, I would be assuming that this is just one speaker and not 2 with this problem, or 3 or more.
Only way to get the ball rolling is pull the tweeter from the cabinet, checking to make sure all wires are connected at the tweeter and inside the speaker.
If that is the case, then you would need to determine if this is the tweeters fault, or its crossover (thing that divides the sound into whats right for the woofer and what the tweeter wants).
If you have a multi-meter, you would disconnect the wires from the tweeter, set the meter to ohms and touch a probe to each speaker terminal. No action means burned out tweeter, 100% action means burned out tweeter, a reading slightly less than the rating on the back of the tweeter (for instance an 8 ohm tweeter would show anywhere from 6 to 8 ohms on the meter) means tweeter is good.
If you have no meter then take the tweeter from the good speaker and swap in place of the bad one, making sure you respect + and - connections.Its a little risky this way,since if there is something wrong in the speaker it may hurt the good tweeter..(the meter is the safer bet). If it works, then you need a replacement tweeter, if not the problem is either wire connections inside the speaker, or something is wrong with the crossover.
Nov 03, 2014 | Audio Players & Recorders
Tweeter problem
Since this is a bi-amplified speaker there's only 2 possibilities here:
*Tweeter amp or,
*Tweeter diaphragm.
You can test the diaphragm as a starting point using an ohmmeter to verify tweeter coil impedance, let me know if i can help more.
Mar 21, 2012 | Mackie SRM-450 System
I have wharfdale atlantic 400se. The tweeter is no longer working. How do i work out if it is a cross over or the tweeter
If there was a traumatic high-volume event that preceded this problem, I'd guess the tweeter died.
If you can access the connections on the tweeter and you have an ohmmeter, you could disconnect the tweeter and measure across the the terminals. A shorted or open voice coil = dead tweeter. A measurement near the stated impedance is probably ok.
If you have NO ohmmeter, you could carefully connect the output of one amplifier channel directly to the tweeter and just scooch the volume upward slightly from silence while playing something with very little bass in it. If you hear it, the tweeter is alive.
Apr 18, 2011 | Wharfedale Atlantic 100 Rear Speaker
No sound from one tweeter
Could be an open capacitor in the cross-over, unconnected wire to the tweeter (not likely) or a blown (open) voicecoil in the tweeter. Remove the tweeter and with a 9 volt battery (even run down but not dead will work) quickly touch it to the connections to the tweeter - it should pop and crackle. No static, the tweeter has sung it's last song.
Apr 08, 2011 | Acoustic Research AR 318PS Speaker
Tweeter not working
hi,
Remove the tweeter and check the same with one AAA cell. Connect the two leads between the leads of the tweeter. if ther is no crakking noice from the tweeter the its coil is burned. you have to replace the tweeter.
ok
Feb 07, 2011 | Technics SB-T200 Main / Stereo Speaker
Paradigm Monitor 9 v4 tweeter not working.
speaker is must likely blown. check to see if another tweeter works at that connection.
Feb 14, 2010 | Paradigm Monitor 9 Speaker
Tweeter broke need replacement wharfedale
Just google the brand name of your reveivers and ask link site of thier service center so you can order the spare for tweeter don,t forget give also the model number.
Hope it may help you;
Regards;
VOTIT
Jan 02, 2009 | Audio Players & Recorders
Need to replace 11L tweeter
the best solution I've found is this:
1. Remove all the tweeter screws.
2. Take a thing metal rod (a coat hanger should work) and lightly tap the tweeter through the top port in the rear until it is loosened and comes out. The tweeter is totally sealed so you probably won't damage it if you need to do this to a working tweeter.
This method also works for the woofer but you need to be very careful to tap the frame or magnet of the woofer and not the cone.
Jun 25, 2008 | Quad 11L Main / Stereo Speaker
TweeTer Not working.
The only way I can think of to check is to disconnect the leads to the tweeter, then check resistance with an Ohm-meter...no reading means dead speaker.
Dec 28, 2007 | Car Audio & Video
JBL Eon15P-1 Main / Stereo Speaker Logo
82 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
