Question about Lands Phones
Clarity crc2765 cassette encoder - Lands Phones
How many watt (power) is this?
  • 24 Watts Total Power
  • Active Clear Sound (ACS) to improve clarity for better balance with deep lows
  • AUX Input
  • 3 Preset Equalization Settings
  • Digital Tuner with Auto Preset
  • 15 AM and 30 FM Station Memory
  • Twist Lock CD and Cassette Doors
  • 1-bit D/A Converter
  • Continuous, Repeat, and Random Play
  • Programmable up to 20 tracks
  • Auto-Reverse Cassette Transport
  • Full-Logic Tape Control
  • CD Synchro-Start Recording
  • 2- 4" Full-Range Speakers
  • 4-Layer Voice Coil: shifts down the lowest resonance frequency and increases driving power
  • Long Labyrinth Ducts: extend the frequency response down to the lowest frequencies
  • Speaker Illumination: the illuminated center cap blinks with the rhythm of the music
  • Carrying Strap with Remote Control Holder
  • COMPU PLAY
  • Clock/Timer with Sleep and Wake-up
  • Back-lit Illuminated LCD Display
  • Full Function Remote Control
  • 1 Year Parts and Labor Warranty
  • Weight: 13.5 lbs.
  • Width: 21 3/8"
  • Height: 8 9/16"
  • Depth: 10 1/4"
  • Oct 23, 2012 | JVC RV-B550 Cassette/CD Boombox
    Hook up for dbx model 224 type 2
    Handy private archive of dbx reference material and service manuals...
    http://vintagedbx.free.fr/dbx.html
    dbx searchable...
    http://www.dbxpro.com/
    http://www.dbxpro.com/Classic_resources.php
    The manual for the 224X which is different in that it adds front panel lightshow and level adjustments. Otherwise, functionally the same.
    http://vintagedbx.free.fr/doc/22-222-224_II.pdf
    Be advised that this is a two-ended system that must be used on Playback if it is used on Record. Don't bother using it for anything but analog TAPE. CDR-Audio has plenty of dynamic range and no noise floor to speak of.
    If you dont already have one, I advise you to get a dbx 400x or 400x-ds to manage the 224 and any other processors you may have. It is an amazing piece of equipment that allows you to place 3 processor loops before or after the encode/decode loop, or bypass them altogether or in any combination, PLUS you can dub encoded or non-encoded music to or from either encoded or non-encoded music unlike the previous dbx 200 or 200x. I have the 224x plus a 400x and a number of other dbx, Pioneer, BSR, Carver, BBE, SAE and ADC goodies; and have created some impressive cassettes back in the day, given the limitations in speed stability. Now-a-days I make impressive CD's of old analog source recordings with improved dynamics, less noise and zero wow and flutter.
    Look for a 400x on eBay. Snipe it at the last 10 seconds if you don't want to bid against yourself..
    http://cgi.ebay.com/DBX-400x-Program-Route-Selector-/250818700329?pt=LH_DefaultDomain_0&hash=item3a65f5a429
    May 16, 2011 | Audio Players & Recorders
    Poor sound clarity
    get some q-tips, peroxide. power off and a cassette tape you been playing...open compartment door... poor a cap full of peroxide in cap.. take one q-tip dip in peroxide.. now take q-tip and wipe the recording head, erase head and play head (do not saturate) each tip should be black or dark brown now take another q-tip to dry the same heads and the roller... let the air hit it for about 5 min... power on insert tape press play ... how do it sound...
    Aug 15, 2010 | ION Audio TAPE2PC Single Cassette Deck
    How to record a phone conversation
    The best solution I found for recording a telephone conversation is a product I purchased at Radio Shack. But actually, I have replaced my Perlcorder with an HTC Hero cell phone, but any Android cell phone will do. There is an app called Ultimate Voice Recorder which is absolutely unbelievable both for its total clarity and automation. It makes ant other type of telephone recorder obsolete. With the app you get complete clarity, the call is saved to your SD card, and you can set the app to record every call, if you like.
    Jun 08, 2010 | Olympus Pearlcorder L400 Handheld Cassette...
    Blaupunkt Radio Cassette . peugeot 206 n2. 96
    Try asking here for free advice and code
    www.ukbookshelf.co.uk
    Oct 05, 2009 | Alert JOBCOM Display Series Radios:...
    Recording from one handheld cassette recorder to another.
    use a mono cable on the output or headphone side of the one playing the tape to the microphone input on the other,make sure you have the volume set right on the one playing the tape for better clarity
    Jun 05, 2009 | Panasonic RN-202 Handheld Cassette Voice...
    I put in a new cassette and it just makes a pop and that is it. It is a Lexmark 83. No copies.
    What u can try is remove the ink cartridges from the printer. Unplugg and replugg the power cable. Clean the copper contacts of the carts using a dry paper towell. Snap the cart back to the printer and install the cart as the new cart. Print the alignment page and if still have the same issue it might be the issue with the encoder strip. Call Lex Tech Support and get help to fix the encoder strip.
    You can also try to download the updated drivers/software from here: downloads.lexmark.com
    Sep 24, 2008 | Lexmark Office Equipment & Supplies
    Sound Problem
    first thing i have to say is all music files doesnot have the same quality some are encoded in high bit rate which produces high clarity and loud sounds (256 kpbs ...> above) . some are encoded in 128< below fromat which produces low sound quality and low sound 9 this is done mostly to reduce size of file ) . i also xperience this in my nokia 6680 phone . this sis no serious problem
    Dec 06, 2007 | Nokia 5200 Cellular Phone
    Lands Phones Logo
    32 people viewed this question
    Top Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a Lands Phone Expert? Answer questions, earn points and help others
