Question about Electrolux Garden
Model fl1500 gas or mix
2 Suggested Answers
farmerbear
  • 490 Answers
SOURCE: What is the oil gasoline
Howdy, 40:1 is the ratio and here is the link to the manual: http://weborder.husqvarna.com/order_static/doc/WOUS/WOUS2002/WOUS2002_530086312.pdf
Regards,Farmerbear
Posted on Aug 31, 2010
Should I use 2 stroke oil or synthetic 2 stroke oil
Synthetic oils claim to extend the shelf life of mixed fuel. If you are going to use the fuel within 30 days of mixing use regular 2 stroke oil.
May 22, 2014 | Weedeater Featherlite Blower 18 Cc 150 Mph...
My Weed Eater FL1500LE gas leaf blower will not run beyond the full choke setting. If I move the lever to half choke the engine will stop. Or if I move the throttle from full throttle to a lower speed...
This is a tell tale sign of a lean fuel mixture. By choking the unit you are manually creating a richer fuel mixture. I would purchase a compression tester from a local parts store and check compression. If that's ok, I'm willing to bet the problem is still carb related. Two stroke carbs are tricky to clean because of high/low ports that are one way and sometimes impossible to clean. Did you remove high and low needles when cleaning carb? Another trick is to mix seafoam with your gas, then mix two cycle oil to proper ratio. Use 2 ounces seafoam to one gallon of gas, then mix two cycle oil to proper mix. Hope this helps! Good luck and happy wrenching!
Sep 22, 2013 | Weed Eater Fl1500 Le Leaf Blowers
Is getting air in gas line, will not start
If the hoses are connected right and they are in good condition, it could be bad gas,sparkplug or carburetor needs cleaned and/or a rebuild kit. Check the link below for parts:
http://www.ereplacementparts.com/poulan-fl1500-type-blower-parts-c-16962_31724_31725.html
Feb 02, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
How do you know whether to use 50:1 or 40:1 gas/oil ratio mix in a 2 cycle engine ?
should be written in the manual and on the lid if not i always run 40 to 1 better safe than sorry to much oil ratio can foul a plug running to light on oil can blow the motor
Nov 07, 2010 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Weed eater Feather Lite Blower - replacing pull cord -can't figure out how to get to it
This should help you out. Go to Poulon's website. Look for a tab to "order parts". Model is fl1500. That will take you to a page that you can look at the blower "chassis" to order parts. That shows you how the bottom housing goes together. You have to take off the bottom housing, the blower fan, the top housing. That should take you to the starter cord mechanism.
Good luck.
http://www.ordertree.com/ARI.aspx?Mfg=75&Model=FL1500 Gas Blower Type 3&AFID=59
Nov 21, 2009 | Garden
I have a Weedeater FL1500. I just changed the
Once it heats up either the spark plug or the ignition module is breaking causing them not to work. I would first check on the price of the ignition module, Then decide it is to expensive to repair and send it to the scrap man.
Good Day.
Oct 30, 2009 | Poulan Featherlite Gas Blower, with Low...
Looking for featherlite fl150 gas lines, where can I buy them? price?
You can get a fuel line kit from PartsStore.com. It lists for $7.95 so even with shipping charges it would be inexpensive. Here is a link that will take you directly to the ordering page: http://www.partstore.com/Model/Electrolux/Poulan/FL1500.aspx
Hope this helps!
Oct 10, 2009 | Poulan Featherlite Gas Blower, with Low...
Garden Logo
Top Electrolux Garden Experts
Phil Walker
Phil Walker
John
Are you an Electrolux Garden Expert? Answer questions, earn points and help others
