Question about Craftsman GT 5000 26 HP54" Garden Tractor ()
When i let off the clutch it stalls. ive tried every gear fast and slow and even in reverse and every time i let off clutch to go it stalls out a nd shuts off
  • Craftsman Master
  • 2,478 Answers
Stalls with mower ingauge , make sure blades turn ok. No move,check transaxle.
Posted on Jun 22, 2013
I had new clutches put in my 4l60 transmisson I put the transmisson back in an now it want hardly pull itself in drive but will do fine in reverse. What could cause that?
10 Most Common Transmission Problems
www.transmissionrepaircostguide.com/10-common-transmission-proble...
Ever notice that while driving that the car hesitates or refuses to go into gear? ... but after shifting into gear the engine's RPMs will surge, but the car won't move as fast as the ..... It's slow to shift gears and accelerate in Reverse, D4,D3,2 and 1.
Nov 14, 2015 | Cars & Trucks
Kia Rio 2005 manual, the gear will get stuck and car shakes and stalls on its own when I come to a stop, foot on clutch and brake, in reverse and first gear.
what would happen if you put it in first gear,put your foot on the clutch then try to start the car....of course pick a place where safe!!!...if it rolls forward while cranking ,the clutch plate is touching the flywheel (in other words the clutch all the way down while in gear while cranking,should NOT touch the flywheel(transmission part that makes the car move) so if it moves then it shows the transmission reacts to the clutch touching the other jiggamathig. Possibly clutch system needs bleeding (air in the hydraulic system). I'm sure your car has this thing called a "clutch slave cylinder". Now,this is one thing I would check first.
Dec 21, 2013 | 2005 Kia Rio
1997 Saturn SC1 | manual transmission not going into first or second.
when was the clutch last change ?
my saturn is a 1998 with over 300k and never had this happen but I have changed my clutch at 275k
Mar 12, 2017 | Saturn SC Cars & Trucks
Saab 900 manual (1991) - difficult to get into 1st gear/reverse. Sometimes won't go into gear while engine is on. Very easy to stall - clutch control very difficult. In reverse it just stalls when I let...
clutch hydraulic system has failed
low fluid levels , air in system,problem clutch master cylinder will cause the indicated problems
take it to a clutch/brake specialist shop and get a proper diagnosis and quote
Nov 28, 2017 | 1991 Saab 900
Just got a used mx5 with 32000 miles on clock. When in first gear having trouble finding the biting point, too slow it nearly stalls too fast revs engine
I would only use first gear for starting when on inclines or in heavy traffic. I rarely use the 1st gear in any of my standard shift vehicles. This problem is mostly clutch and rpm mixing till you get used to the clutch or if it was not broken in correctly you get used to what was broken in at.
Nov 20, 2009 | 2003 Mazda MX-5 Miata
Clutch or Transmission?
Whining noise is worn gears or low on transmission fluid. It after reading your post, sorry to say but you were low on transmission fluid and your transmission needs to be replaced. You gear box has seized and every time you release the clutch even in neutral will kill your engine. The transmission shaft may have seized on the bearings in the transmission case, regardless you need a new or rebuilt transmission. Good luck friend and sorry for the bad news. Keep me posted.
Jul 02, 2009 | 2000 Nissan Maxima
Towing my boat /seems like its slipping/new clutch?
Try having clutch adjusted first, then you will know if clutch has been slipping.
Let me know if this helps. MMP
Jun 15, 2008 | 1987 Ford Bronco II
Craftsman GT 5000 26 HP54" Garden Tractor () Logo
75 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
