Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Lawn boy mower troubleshooting - Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
4 Suggested Answers
SOURCE: 2 cycle oil to gas ratio for Lawn Boy mover Model 10324
32 parts gasoline : 1 part oil
Posted on May 06, 2009
  • 391 Answers
SOURCE: lawn boy 2 cycle mower won't start
Replace the spark plug and retry.
If a new plug does not work push the spring button on the bottom of the carburetor to make sure fresh fuel is in the fuel bowl.
if this does not work remove the spark plug and squirt some light oil (like wd 40) right into the spark plug hole; roll the engine over slowly a couple times using the starter rope. put the plug back in and snap the plug wire in place. If the mower now starts after a couple pulls it means the rings are worn, replace the rings.
Posted on Jun 01, 2010
  • 885 Answers
SOURCE: can you run your lawn boy mowers without the
Yes you can. The only reason small engines have the primer button/bulb is to get gas to the carburator to make it easier to start it. If your mower starts OK without using the primer bulb you will not harm the mower.
Posted on Apr 14, 2011
Why did my Lawn Boy Platinum self propelsion quit?
I believe there is a V-belt that drives the front wheels,it may have broken,or the gears in the gear box have failed !
Jun 22, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Where can I find a troubleshhot guide for a lawn-boy cordless walk power mower model 10123
Batteries need to be kept warm and charged,on a regular basis,this is where a "Float Charger" comes in handy to monitor battery voltage while in storage ,I'd bet the ranch your battery is toast,but any auto parts store could LOAD test it for you ,Good luck !
Jun 08, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Why lawnmower cut off after it start
Make sure the fuel filler cap breather hole is clear if its blocked it will create a vacuum in the tank which prevents the fuel flowing forward. also check out the kinks below
Lawn Mower Troubleshooting Guide Engine
Small Engine Repair Help
May 01, 2014 | Toro Lawn Boy Self Propelled CARB Walk...
After about 15 to 30 minutes, engine starts pinging (for a few seconds) then dies
Not familiar with tecumseh lawn boy. Lawn boys I worked on were 2 stroke, if this is the case the crank seal is sucking air after engine warms up. New seal would fix. If you can't do it you're self may not be economically worth it.
Sep 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Can't get my lawn boy started
check for a faulty wire to the engine kill switch it may be contacting the ground
Jun 22, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
ACCELERATOR HAS STOPPED WORKING ON BRIGGS & STATTON PETROL MOWER
when the lawn mower suddenly stop working,first you should check the fuel. i think the Self-propelled device was broken. You can take the Self-propelled device off and try again with it.
May 03, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
261 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
itsman
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
