Question about Panasonic KX-T7730 Corded Phone
What is a pcb - Panasonic KX-T7730 Corded Phone
    Sergeant:
  • 259 Answers
Printed circuit board.you're welcome......meder's tv service
Posted on May 10, 2013
Testimonial: "thankyou"
E-000711-0001 in canon ir 3300 xerox
The connector has poor connection. The ADF controller PCB is faulty. The finisher controller PCB is faulty. The DA unit PCB is faulty. The card reader PCB is faulty.
Connector, ADF controller PCB Is the interface cable between the ADF controller PCB an the reader controller PCB normal? NO: Correct the cable. YES: Replace the ADF controller PCB.
Dec 31, 2017 | Canon Office Equipment & Supplies
Error Code: E197 0000 in cannon 2900 printer
Printer engine communication error
Erroneous communication between the DC controller PCB and image processor PCB was detected.
- Check the connectors of the DC controller PCB and image processor PCB.
Replace the DC controller PCB for normal connection. - Replace the image processor PCB.
E197 0000 Laser Driver PCB communication error
Description :
Description Error in communication with the Laser Driver PCB (communication data failure)
Causes :
Solutions :
Remedy
1. Check the Laser Scanner Unit connector.
2. Replace the Laser Scanner Unit.
3. Replace the DC Controller PCB (PCB1).
Nov 16, 2017 | Cannon Office Equipment & Supplies
Printing blank copies
1. No transfer charging. A. The connector terminals of the high-voltage PCB make poor contact. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. B. Defective engine PCB. Replace the engine PCB and check for correct operation. C. Defective high-voltage PCB. Replace the high voltage PCB and check for correct operation. 2. No LSU laser is output. A. Defective laser scanner unit. Replace the laser scanner unit (see page 1-6-29). B. Defective main PCB. Replace the main PCB and check for correct operation. 3. No developing bias is output. A. The connector terminals of the high-voltage PCB make poor contact. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. B. Defective engine PCB. Replace the engine PCB and check for correct operation. C. Defective high-voltage PCB. Replace the high voltage PCB and check for correct operation.
Jun 09, 2015 | Kyocera Mita Drum Cleaning Blade Km 1620...
Hardware error 03130031-2618
Follow these steps : Cause: The Voltage of the print head is abnormal.
Problems can be with:
-Printhead -head relay PCB -Carriage relay PCB -Main controller PCB
Steps to be followed:
1. Replace the printhead. 2. Cable continuity check. if continuity of the cable between the head relay PCB and the carriage relay PCB is abnormal, replace the cable. 3. Replace the head relay PCB. 4. Cable continuity check. if continuity of the cable between the carriage relay PCB iand the main controller PCB is abnormal, replace the cable. 5.Replace the carriage relay PCB. 6.Replace the main controller PCB.
May 15, 2011 | Canon imagePROGRAF iPF8000 Printer
Error e000733
E733
0001 A fault is detected by the main controller PCB in the communication between
the DC controller PCB and the main controller PCB.
Main cause The connector has poor connection. The DC controller PCB is faulty.
Action
1. Connector, DC controller PCB
Is the connection between the connector J1015 on the main controller PCB
and the conductor J316 on the DC controlled PCB normal?
NO: Correct the connection.
YES: Replace the DC controller PCB.
Mar 04, 2011 | Canon imageRUNNER 2200
Errore000064 occured
Power supply voltage error (high-voltage error)
The presence of a high-voltage error is communicated by the composite
power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause: The contact has poor connection. The wiring is faulty. The composite power
supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly,
or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller,
developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Jan 19, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Giving an erro E220(IR3300)
E220
0001 A fault is detected on the inverter PCB for the scanning lamp.
Main cause The inverter PCB is faulty. The reader controller PCB is faulty.
Action
1. Wiring
Is the wiring from the scanning lamp to the reader controller PCB normal?
NO: Connect the connector firmly, and correct or replace the wiring.
2. Inverter PCB, Reader controller PCB
Try replacing the lamp inverter PCB. Is the problem corrected?
YES: End.
NO: Replace the reader controller PCB.
Aug 02, 2010 | Canon imageRUNNER 2200
E90 IS THE ERROR CODE IT IS SHOWING
E90 is a communication error between the main pcb and the display pcb.Check the blue wiring loom that goes from the main pcb to the display pcb.normally it is a bad/loose connection on the display pcb end.clean pcb tracks and tighten the blue connector loom pins up and hopefully it will work.if it doesn't solve the problem then you could have a faulty display pcb or main pcb.
May 02, 2009 | Washing Machines
How to clear E000064 problem in ir3300 model
E064
0000 The presence of a high-voltage error is communicated by the composite
Main cause The contact has poor connection. The wiring is faulty. The composite power
Action
1. Contact
2. Wiring
YES: Yes.
Feb 26, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
2. Wiring
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
YES: Yes.
Feb 24, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Panasonic KX-T7730 Corded Phone Logo
79 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
