Question about Pentair Compool CP3400TX Pool & Spa Control System w/Standard Power Center
Compool cp3400 I just moved into a house with a compool cp3400 system. i am leasing and the landlord say he knows nothing about the pool system and that the pool is a luxury item so anything related to it is my responsibility and on my dime. he just obtained the house from the bank who got it from foreclosure. the ?genie? is missing, do i need to replace it or will hiring a weekly pool service suffice? also the service light is on, what does that mean. Is it equipped with solar or do i need to use the other heating option? Thanks
4 Suggested Answers
Muzzi_123
  • 749 Answers
SOURCE: Minimaxpower on but fails to start no error code just flashes off
hi, it seems like a component malfunction, Try a hard reset Just unplug the power cord for 30 minutes or more, then try again.
Posted on May 07, 2009
  • 760 Answers
SOURCE: pool heater is not working properly
So I assume you have pressed the button by pool to select the pool thermostat? If this doesn't work sounds like another mother board problem, or try powering down the unit a few minutes then restart. IF you haven't pressed the pool button, the read this: The heater comes factory set at 78° F. for the pool mode and 100° F. for the spa mode. If it's in spa mode it's trying to get to 100F. Using the up and down arrows,you can set the thermostats to a minimum temperature of 65° F., or a maximum of 104° F. If you desire to heat only one
body of water, the thermostat is capable of an off mode. As an example, if you only wish to heat the pool and not the spa simply depress and hold the spa down arrow, and the thermostat will lower its setting to 65° F. then go to an off mode. Here is a link to your manual :http://www.pentairpool.com/pdfs/MasterTempOM.pdf
Posted on Jul 08, 2010
  • 44 Answers
SOURCE: We cannot program the system
Turning on the spa side remote will remove the error code.Pentair will send you a new manual if you ask for one.
Posted on Sep 28, 2010
I have a compool CP3400 system and my spa jets will not turn on
check to see if relay is sending voltage to motor if not bad relay if so bad motor
Mar 10, 2015 | Pentair Compool CP3400TX Pool & Spa...
Compool cp3400
online/Amazon - but the best thing is to use your local pool spa professional. Then you can always call them for help when you really need a pro.
May 22, 2014 | Pentair Pool & Spa
My Compool 3000cp appears to be blank, I cannot select any features.
I would recommend a professional in this case. Those systems are very old. It may be a case of old wiring in the walls. Difficult to say.
Mar 31, 2014 | Pool & Spa
Compool 3000CP inside pool control is blank. I cannot select any features. It appears that there is no power going to it.
It could be one of 3 things, the indoor controller may needto be replaced, or the outdoor controller, or the wiring betwen the two, from your outdoor control to the inside house panel. your best bet is to switch out your old system with a compool to easytouch upgrade with the screenlogic interface bundle, or a Jandy Iaqualink upgrade. This will enable wireless access to the pool programs as well as give you control over variable speed pumps, which, if you dont have already, you will want to purchase.you will want a pool professional to install these items.
Service mode Compool
turn everything off then turn back on if it is still uncontrolable sounds like master pc board
Feb 27, 2014 | Pentair Compool CP3400TX Pool & Spa...
We have compool lx3400. have no connection between house and outside panel . We have to go out to the box outside and manually turn off and on
If there is no wall mounted controller (CP-3400) it probably had a wireless remote. You'll need to get in touch with a pool tech to see exactly which controller will work with your system.
A cheaper solution may be to convert it to Intermatic timers if all you really need is on/off function for the pumps.
Oct 24, 2013 | Pool & Spa
Compool cp3400
when the indoor control start the alarm , did you notice any error code display in indoor control like 170 ? POSSIBLE IS THIS control a pool only or pool and spa combination, did you have a pool heater connected to compool 3400 (PENTAIR)
Jun 14, 2013 | Pool & Spa
We cannot program the system inside the house. It is showing ERR 4 - We need the manual to show us what to do. The motor number is Compool CP-3600.
Sep 26, 2010 | Pentair Pool & Spa
Pentair Compool CP3400TX Pool & Spa Control System w/Standard Power Center Logo
69 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
