Question about Garden
Toro 550 lawn mower
What kind of oil does it take?
mowerman1857
  • 389 Answers
SOURCE: oil for yardman lawn mower
Only 30wt DETERGENT HIGH QUALITY oil, never use NON detergent or 10-40. Takes approx. 20 ounces to fill
Posted on Sep 14, 2009
rwvanlue
  • 486 Answers
SOURCE: Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
Posted on Nov 08, 2009
SOURCE: Our Toro Personal pacer Model 20031 lawn mower will not start;
i turn the key and it grinds
Posted on Dec 06, 2009
barterjoe
  • 344 Answers
SOURCE: my toro lawn mower is hard to start in cold
This is covered by the Warranty. Take it to a local dealer like www.arcolawn.com and have the thermostat replaced.
The first generation thermostats are known for sticking.
Good luck
Joe
Posted on Feb 20, 2011
  • 6468 Answers
SOURCE: front wheels do not move on self propelled lawn mower
check the cable at the front gear box
Posted on Mar 25, 2012
Where is oil plug on toro 550
https://www.toro.com/en/parts Go here, select your model bt serial number, then select manual.
Aug 22, 2016 | Toro Garden
What kind of oil do I need for a Toro 6.75 lawn mower? How often do I need to make an oil change?
Hi dirk_koeppen...
You will use a good grade of 30W non-detergent oil.
Change your oil once per season/year
Please rate me
Bud
Oct 06, 2012 | Toro Garden
Toro cutting off
Maybe low oil level, all mowers have a low oil cutoff. 30w oil.
Aug 07, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Lost instuction manual for Toro lawn mower 20333 (Walk at your own pace) . What kind of gas or oil do I use? How much of each or do I just use one of them?
I advise you to call your service provider about the lost of your manual. They can definitely help you get a copy of it. The manual for your Toro Lawn Mower is the best answer for your questions. Thanks.
Jul 10, 2011 | Toro Personal Pace CARB Walk Power Mower
Need to put oil in and don't know what kind of oil to put in or if it's gas oil mix????
ADD SAE 30 SMALL ENGINE OIL. 18oz TO 20oz
SEARS SALES A 20oz BOTTLE OF CRAFTSMAN SAE 30 OIL FOR $2.59
Oct 12, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Oil Drain Plug Location
that is the drain plug sometimes hard to get loose but should come out it is in bottom of engine above blade.
May 07, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
