Question about Cell Phones
Apostrophes What did you do with the houseplant's I bought yesterday?
Getting rid a fungus gnats throughout the house and killing houseplants
Mix one part 3% hydrogen peroxide with four parts water. Allow the top layer of your soil to dry, and then water your plants with this solution as you normally would. The soil will fizz for a few minutes after application; this is normal. The fungus gnat larvae will die on contact with the hydrogen peroxide.
Feb 11, 2018 | Garden
Small bees in the corner of my planter, in the dirt. Will they leave on their own or do I have to force them out? They are killing my plants.
Go out to Lowe's or a similar store which has a good garden shop and pick up an organic spray insecticide that contains pyrethrins (organic insecticide made from chrysanthemums). That'll get those little buggers out. I have many houseplants and use Garden Safe Houseplant and insect eliminator. Treat all your houseplants every couple weeks with it.
Jul 27, 2017 | Garden
When to put apostrophe in the sentence, the boys have read their books.
http://data.grammarbook.com/blog/apostrophes/apostrophes-with-words-ending-in-s/
Feb 04, 2015 | Crazyprofile Apps Fill In The Plural Noun
Is this sentence right? Hams' trip made him famous.
In possessives, the placement of the apostrophe depends on whether the noun that shows possession is singular or plural. Generally, if the noun is singular, the apostrophe goes before the s. The witch's broom. If the noun is plural, the apostrophe goes after the s: The witches' brooms. However, if the word is pluralized without an s, the apostrophe comes before the s: He entered the men's room with an armload of children's clothing. If you create a possessive with a phrase like of the witches, you will use no apostrophe: the brooms of the witches.
Oct 12, 2014 | Computers & Internet
How can i type latter Apostrophe with dell laptop
Apostrophe key is next to the enter key
Aug 07, 2012 | Computers & Internet
How to use accents when writing in Spanish in a Dell Precision m4500 laptop?
On Windows XP
  1. Log On
  2. Click the Start button
  3. Click on Control Panel
  4. Click Regional and Language Options - a new window will pop up
  5. Click the Languages tab
  6. Click on the Details button
  7. Click the Add button - a new window will pop up
  8. Select United States-International (keyboard layout menu)
  9. Click OK
  10. Click Apply
  11. Read the instructions for "Using the U.S. - International Keyboard" below.
Note: You will now have a keyboard icon on the taskbar (usually on the right side). To switch between keyboard layouts click the keyboard icon on the task bar and choose which layout you want to use. Changing the keyboard layout will only affect the log on profile used. No other users will be affected.
Windows Vista
  1. Start-->Control Panel-->Clock, Language, Region-->Change Keyboards
  2. New Window: Click the Change Keyboards button
  3. New Window: Click the Add button
  4. Select United States-International keyboard
  5. Click OK
  6. From drop down menu (Default Input Language) select United States International
Using the U.S. - International Keyboard If you followed the above directions carefully, your keyboard will now react slightly differently than it did before. First of all, notice that if you strike the single apostrophe (') key, nothing happens. To type the single apostrophe now, you must strike the single apostrophe key and then strike the space bar. When you strike the spacebar, the apostrophe will appear.
The next thing to note is that the quotes (") key behaves the same way as the apostrophe key. You must first strike the quotes key and then strike the space bar in order to create the (") symbol. These two minor inconveniences are more than made up for by the ease with which you can now type the special characters.
To type the special characters, two keystrokes are required. To type the ?, you need only strike the apostrophe key and then the letter a. The other characters are just as easy:
  • ? = ' + a
  • ? = ' + e
  • ? = ' + i
  • ? = ' + o
  • ? = ' + u
  • ? = ~ + n
  • ? = " + u
To type the special punctuation characters, you need to hold down on the Alt key while you strike the appropriate punctuation mark. On some keyboards, only one of the two Alt keys will work for this.
  • ¡ = Alt (hold down) + !
  • ¿ = Alt (hold down) + ?
Using Cryptic Codes If, for some reason, you don't want to change your keyboard, you can always type in the troublesome cryptic codes. Using this arcane system, the following codes apply:
  • ? = Alt + 0225
  • ? = Alt + 0233
  • ? = Alt + 0237
  • ? = Alt + 0243
  • ? = Alt + 0250
  • ? = Alt + 0241
  • ? = Alt + 0252
  • ¡ = Alt + 0161
  • ¿ Alt + 0191
When using this utterly out-dated system, there are two important things to remember. First, when you type in the numbers, some keyboards require that you use the "numeric keypad" located to the side, rather than the numbers along the top. Second, on some keyboards, only one of the two Alt keys will work for this.
May 02, 2011 | Computers & Internet
Where is the apostrophe on my windows xp keyboard? It is not the sintle quote per my publisher.
http://en.wikipedia.org/wiki/Apostrophe, according to it, right of colon and semi-colon.
Aug 10, 2010 | Computers & Internet
HP G50 laptop,problem with apostrophe key
It seems likely that you touched the CTRL key while pressing the apostrophe key, which creates a shortcut to an accented letter eg CTRL+',e will give ?.
Try Ctrl + e again to see if it goes away..cheers
Jan 16, 2018 | HP Computers & Internet
Cell Phones Logo
76 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
