Question about Crosley CA18WYR Thru-Wall/Window Air Conditioner
Sqwealing noise Fan on the outside sqweals
    New Friend:
  • 107 Answers
This is most likely bad bearings in the motor and would have to be replaced.
Posted on May 11, 2013
My Frigidaire FWS833A1 top load washer makes a horrible sqwealing noise when starting the spin cycle and does not stop. Could this be a belt issue and if so, how can I fix this? Thanks for your help!
The problem could be with the "belt", "transmission pulley", or the "idler pulley". If you remove the front panel and run the machine, you should be able to see where the noise is coming from. To remove the front panel, there are 2 screws located on the bottom of the front panel, remove them and then push in on the 2 clamps located on along the seam at the top of the panel and the top near the corners. It may just come down and off once you remove the 2 screws on the bottom. Once the panel is off run a small load of clothes and listen and locate the source of the noise.
Jan 21, 2011 | Frigidaire FWS833A Top Load Washer
MOTOR NOISE and noise stopped after closing the fridge door
Hello
Is the noise on the inside or the outside? Most often noise is caused by one of the fan motors going bad.That being said. If the noise is on the inside it's the evaporator fan motor. If it's on the outside in the back then it's the condenser fan motor.
I hope this helps you. Please leave feedback.
Thank you.
Aug 24, 2010 | Refrigerators
Fan not working on outside AC unit
The buzzing noise is probably the fan motor. Is the compressor running? First make sure that there are no tripped breakers. After that kill the power and check the capacitor with a multimeter. If that checks good then check the fan motor windings with the multimeter. Let me know if you have any questions.
May 26, 2010 | Intertherm P3RA-060K Air Conditioner
38CKC036 Air Conditioner: outside fan will not come on makes a humming noise...
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
May 18, 2010 | Carrier 38CKC036 Air Conditioner
Feels like my front drivers side tire is lose but I check all the lugg nuts and they are tight. I can drive straight and I get a loud sqweal(as if I'm taking a corner to sharp) from the passenger side...
sounds like you have either tie/thrust rod ends going bad, or ball joints. Your wheel bearings could be going bad as well. Any of these can cause this problem. To check the tie/thrust rod ends, turn the vehicle off, and have a friend turn the wheel back and forth while you look at the steering linkages. If you see anything moving more than the part that it's attached to, you have found something that needs replacing right away. For Ball joints, put a jack on the a-arm right beside the wheel. Jack it up, and watch the tire as it starts to come off the ground. If it slides out when it just gets off the ground, you have bad ball joints on that side. Wheel/hub bearings can be trickier, unless they're REALLY worn. Jack the car up so that it's clear of the ground, and see if you can make the wheel wobble by moving it with your hands. You may also notice a grinding or whining sound coming from the affected side. You'll especially notice it if you drive with your window down, as you're passing a building or other hard object, as the sound reflects back at you. Hope this helped you find your problem.
May 11, 2010 | Cars & Trucks
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Noisy Aga fridge
where is the noise? inside or outside? inside maybe the evaporator fan motor. hitting somethig> wire . get a tech to double check not dangerous. outside. noise compressor dont replace. have to live like that or replace the whole fridge. or condenser fan motor. call atech for replaced
Mar 30, 2010 | Refrigerators
FRONT END SQWEAL AND MAKES NOISES
Yep....agreed. Ball joints are bad....if you had done maintenance on the front end steering or suspension system, you need a front end alignment. But, you definitely have issues with the suspension system.
Tierod, ball joints, struts....could be a lot of things.
Let us know what has been done to the front end.
Mar 21, 2009 | 1996 Ford Thunderbird LX
My car makes a sqwealing noise when I press on the brakes
That noise you hear, is the brake indicator,letting you know its time to put new pads on.Its a small tab that scrapes on the rotor when the pads get low
Jan 19, 2009 | 2002 Saturn L-Series
Belts
Belts tend to dry out with time causing all this noises. The best solution is replacement. Its better to change it than be stranded in the street.
Jun 28, 2008 | 2003 Dodge Neon
Crosley CA18WYR Thru-Wall/Window Air Conditioner Logo
20 people viewed this question
Top Crosley Heating & Cooling Experts
David White
J Rosado
Kiri Amarakoon
Are you a Crosley Heating and Cooling Expert? Answer questions, earn points and help others
