Question about Garden
My simplicity mower dies while I am mowing, then will re-start after about half an hour, full gas tank
Mower dies for no apparent reason, then will re-start after sitting awhile, then will die again later on
3 Suggested Answers
SOURCE: My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Posted on Dec 31, 2010
SOURCE: Mower will start up cold, i will mow for a half
Try cleaning out your gas cap - if debris gets in the holes in the cap it will eventually cause a suction in the tank preventing fuel from getting to carb and engine. Any doubts, try running with the gas cap off and see if that does the trick.
Posted on May 08, 2013
My simplicity riding lawn mower was submerged for about a half hour and will not start. what should I do?
change the sump oil , remove the plug and dry off, turn motor over with out the plug to empty water from the cylinder
remove fuel tank and empty water out , remove carby and empty water out
check all switches for water immersion
Jul 24, 2016 | Simplicity Broadmoor 20hp Briggs &...
Why wont my John Deere D130 will not stay running
You know the old adage, Keep it simple, lol.
I was mowing along on my LA145, which had about 200 hours on it, and it slowed down then died. Before it died, it was acting like it was losing power. It felt like it was only firing on one cylinder. I waited a bit and it restarted after a lot of cranking. I made a couple mowing passes, and then the same thing happened.
Because I have mowed commercially for many years, I know my equipment inside and out. This mower was in top running condition and should not have been acting this way. There were no engine misses, no backfires and it was not normally hard to start. I knew the carburetor was clean, the coils were good, and the plugs were new. The fuel filter was recently changed. I got off, lifted the hood and gave a general inspection of the engine compartment. I noticed the fuel filter was nearly empty. I pulled the hose off the tank side of the filter and saw there was no flow.
The gas should gravity flow from the tank to the filter, if the tank has a good supply of fuel. Not that I recommend this practice, but I have no problem with doing it myself....I wiped the hose off and blew air back into the fuel tank. It helps to take the gas tank lid off first. After I got a good flow of air going back into the tank (it required several lungs full of air, you can hear the bubbles) the fuel began to gravity flow back through the hose at a decent clip. This fixed the problem. There is likely silt build up in the tank and it settles at the output port blocking the flow of fuel.
The problem repeated itself several times last summer. Back at the shop, I used compressed air to blow the line clear. The problem has not shown up in quite some time.
Aug 29, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
Why is my riding lawn mower acting like its running out of gas?
probably needs carb rebuilt and needle and seat put in
Aug 25, 2014 | Garden
Craftsman riding mower runs mows fine for about 10-15 mins then sputters out and wont restart tuill bout half hour later
two things can be doing this ,
(1) fuel tank pick up is broken in half and works till gas works it way down to break , proof of this is when u add more gas and it starts right back up
(2) breakdown in ignition system , this can happen in a few places (if I knew your model number I can tell u more) eventually It will fail and never restart
Jun 07, 2014 | Craftsman Garden
Mower will start up cold, i will mow for a half hour then it sputters and dies. After it sits for a while and cools it will start again, but not as easily as the first time. It will again mow for a while...
The valves DO NEED adjusting every 250 to 300 hours of service. That is why it dies out beleive me. It is not that hard to do if you have a service manual to help you along to perform this task
Jul 09, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
See below
A couple things, is it full of grass and hay up top that would cause it to overheat? Or the fuel filter got clogged up from debris in the tank. Or the governor spring came off, loose, make sure it moves freely, and then check the air filter. Then before filling the tank up, peek in there with a flash lite and see if there is any water floating in the bottom. Then check the spark plug. Hope one of these helps.
Jun 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hi, I have a simplicity brodmoor mower, purchased new in 1994. Recently the mower will run for about 15 minutes and die. I let it rest for a half hr & it starts back up again. I eventually get the lawn...
not saying this is your problem, however i have found this to be a problem in some cases. Because of the time duration that the mower runs then quits, i'd almost have to say (believe this or not ) your gas cap vent may be plugged. As gas leaves the gas tank, air has to replace that space. If air can't get into the tank, then as gas leaves the tank, it creates a vaccume, and shortly, no gas flow. try replacing the gas cap or make a small hole thru the cap so air can get into the tank. I'll be wondering how this works out for you.
May 28, 2010 | Garden
I have a simplicity zr-38 mower with kohler 17.5 hp motor last time i mowed it died but started back up finished mowing went to start it this week and wouldnt start and discovered it has no spark could...
that sounds like your issue exatly. That would be the only thing that would let it die, re fire, then not restart again. If it was a fuel issue it would have still restarted, a spark issue it would still have started.
May 06, 2010 | Garden
Mower stalls out after about an hour of run time
A few possibilities
1. If engine runs hotter than normal it can eventually heat up the carburetor to the point that there is a vapor lock. Blockage caused by gas bubble: a bubble of vaporized gasoline that blocks the normal flow of fuel. Problem goes away when things cool down. If that is the problem, you need to solve overheating problem. Since you have changed the oil, might be something blocking airflow to the flywheel which has the cooling blades on it. Or cooling blades are filled with debris. Make sure vent hole in gas cap is not blocked
2. Could be bad coil, or condenser causing the windings to act up when they are hot and have expanded they short out (kill engine) on their own casing. After they coil and shrink, they un-short themselves.
May 14, 2009 | Garden
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
