Question about HP Compaq iPAQ MP4800 Multimedia Projector
Greenish display My MP4800 has a greenish tint to the display no matter what is being projected. I tried all the different connections, S-video, DMI to VGA, VGA to VGA and tried to different VGA cables. I also went into the Color options & tried to tweak those at no success. The lamp has been replaced as well. I'm out of options. Can you help?
  • yusuft Mar 11, 2009
    The projector only shows green. It is fine before it is connected to a laptop but the moment it gets connected it turns green
  • Anonymous Mar 20, 2014
    Graphics accelertors says there is no option for tv connection. surely there is a way to connect.
Had the same problem. Opened the cover and find out that when I press the part above the lump the display become normal. Some loosed connector was my first thought. But, after a while looking and pressing around found out that the cover of the lamp was not placed properly and one corner side of the lamp cover was displaced. Opened it, returned it back to fit properly and the green display is gone. Hope that will not appear again and that is the same "problem" with yours.
Posted on Jul 21, 2009
Greenish tint
Might try the color tones buttons on T.V. up or down.
Oct 13, 2013 | Samsung LN-S1951W 19 in. LCD Television
Tip
My TV picture has a greenish tint.
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal is often coded in separate colors signal, and a bad cable can cause a green picture when red or magenta (depending on type of signal) are out.
A faulty receiver or DVD player can also send a bad output. Try connecting different devices to TV.
If the cables and receiver are OK there are also internal faults that can cause the same effect.
The fault depends mainly on the model and type of the TV set.
On all TVs a faulty input/output can cause greenish picture.
On all digital TVs the signal is also elaborated on different color channels . Video circuits are often located on digital board.
A fault on digital video processing can cause a green picture.
If you have a rear projection CRT based technology, one of the three CRT may be faulty, or the power board supplying the CRT (red in your case) may have blown.
In that case you will get a greenish picture.
If instead you have a CRT TV, a greenish picture means that the red gun inside the cathode ray tube is not working. The CRT itself must be replaced.
Generally, when the problem is not the video cable , or the connected device, the TV must be inspected and repaired by a technician.
If you have a new digital TV, as an LCD, Plasma, or any non CRT based technology, the problem is usually caused by cables, input output, or connected devices.
Check the cables thoroughly, if that is not the problem, call manufacturer to find the nearest repair service location.
on Oct 23, 2009 | Vizio L32 32 in. LCD HDTV
Tv is 6 years old - greenish tint to everything KDS-60A2000
it is, called a optical light engine and that is about the most expensive part in the set.
Nov 28, 2012 | Sony KDS-60A2000 60" HDTV
Picture is starting to get greenish, yellowish colored
hitachi model 51f510 projection tv has horizontal lines & has greenish tint,do i need to chang the bulbs??i alredy tryd the magic focus button & manual focus,but unsuccesfl,any ideas????
Nov 27, 2009 | Hitachi 51F510 51" Rear Projection...
Color is a problem. Screen picture has greenish
well it seems you have an issue with one of your video boards, it could be that the Analog Video Board (the one with the inputs and outputs) is partially damaged, but it can also be your Digital Video Board, which is the one that projects the image
Jul 22, 2009 | Panasonic Televison & Video
Rear projection HD Hitachi Ultravision always has greenish tint
This is what you're going to do, Turn on the Tv and go to the service manual, if the green tint is still there, you have a defective dmd board, but if it's no there, then you have an issue with your video board
Jul 09, 2009 | Hitachi Televison & Video
Monitor screen changes from regular color to a green tinted screen?
Connect a different monitor to your computer, if it still displays the same fault the the problem is the video card and you need a replacement.
May 27, 2009 | Dell Computers & Internet
RCA R2WH74YX58 tint problem
MAYBE LOOSE CONNECTION--CAN'T PICTURE YOU PROBLEM--WHAT'S THE CHASSIS #?? TUNICA
Sep 17, 2008 | RCA P52926 52" Rear Projection Television
Greenish yellowish tint on the tv
I have been advised that the color/light engine of the TV fails often and will typically create a green tint on this unit. I have one on order to get a replacement installed. BTW, it is not "user serviceable" and (for me) will require moving the TV to the repair shop for the change-out.
Nov 11, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
HP Compaq iPAQ MP4800 Multimedia Projector Logo
329 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
