Gtwn5050m0ws GE washer model #gtwn5050m0ws keeps beeping and lights flashing. Will not start. Had a power outage and it has not worked since?
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet Washer
F11 is a serial communications error. This is a symptom of an electronic control board starting to go bad. As defined by the technical information provided by Whirlpool, the error could also be caused by a loose or broken wire connector and/or the central control unit (CCU) (front panel). I would double check all your wire connections leading to the control board and CCU, first. Don't be surprised, however, if the problem persists and you eventually have to replace the electronic control board. To check, follow these steps: 1. Unplug washer. 2. Remove the three screws along the top of the washer in the rear that holds the top panel on. 3. Once the screws are removed the top should slide back then lift up. 4. The electronic control board is gray (or white) in color and located in the rear of the washer. It's impossible to miss. Double check all the connections ONE AT A TIME. 5. Double check the wire harness connections leading to the front panel as well. I hope this resolves your problem, but experience has proven that this is usually an Electronic Control Board failure. It could actually be a combination of the CCU as well. The part numbers are as follows: Electronic Control Board: 959503 Central Control Unit: 1025824 Both boards cost about $150 each. Let me know if this helps you.
Posted on Sep 03, 2007
dh1200s
  • 335 Answers
SOURCE: maytag neptune washer keeps beeping
The Service Manual for reference. Sears Parts Direct for reference.
I have tried to work with a few folks on this issue never received feed back to resolution see this post. I feel the issue is caused by one of three possible issues.
A stuck key issue/defective Spin Cycle key making constant contact forcing the Key/LED to cycle thru the Spin Cycle settings. Under normal conditions if you press and hold the Spin Select key it will cycle thru the settings, yours has a mind of its own (defective issue).
A false signal from the Control Board for the Spin Cycle.
A corrosion path issue at the Membrane Pad ribbon cable socket connection between pins 5 and 4. See page 20 of the SM button functionality “Spin” key.
Try to verify that the spin cycle membrane key is not stuck/defective signaling the Control Board to cycle thru the spin settings. I have not experienced this issue but let’s try the Membrane Pad Test
to get a start point. See the Service Manual page 15, I have modified the process to make it a bit more understandable at least for me. Make sure the two digit display is not On or Lite.
Press the off button first so there is nothing displayed in the Two Digit display of your FAV6800AW.
Now Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys for three seconds or until the control beeps. While in Service Mode, pressing the Presoak key will start a membrane switch check that verifies switch operation.
All the LEDs (except Presoak ) can be toggled or slewed by pressing the key associated with the LED or set of LEDs. Do not press the Presoak again during this test.
Press each key once and only once including the Signal Key the on side and the off side, also the UP and Down Arrow key of the LED display. All keys (including the OFF button) must be pressed within 5 minutes for this test to pass. “PA” will be displayed for five (5) seconds once all keys have been pressed and the test is completed (more like PA will be displayed for only a few seconds on my FAV6800AW). Following 10 seconds of inactivity at any point, this test will exit without any display. Let us know the results.
See my additional comment this board has message limit issues.
Posted on Sep 17, 2009
  • 1531 Answers
SOURCE: GE front load washer wont start model #WHDVH626FWW
there is a chance that your door lock has failed
Posted on Feb 06, 2010
SOURCE: WCVH6260HWW GE front load washer won't start -
no power to control panel checked outlet with another appliance it worked drained water from pump filter still nothing door locked and nothing on control panel
Posted on Oct 12, 2010
  • 713 Answers
SOURCE: hi my Pride Washer model
Hi just read your posting.Now you mentioned in your posting that the lights that are on when the machine is beeping are 1and 7.This is on the row of 8 lights and you started from left to right.Is this correct? If it is correct then the fault you have on your machine is called SINGLE ROTOR POSITION SENSOR ERROR.This means that the rotor sensor which is attached to your motor is faulty or your control module is faulty.Please reply with confirmation on the lights that are on when the machine is beeping and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on Oct 14, 2010
Location of discharge hose on model GTWN5050MOWS
See step 3 of manual. Sears parts provides great customer service with parts and manuals
Hope this helps?
http://www.searspartsdirect.com/partsdirect/user-manuals/GTWN5050M0WS-GE-WASHER-manual
Jun 26, 2017 | GE Washing Machines
Kenmore Oasis no error code keeps beeping low -loud
If its the main board that you are having an issue with, honestly i will suggest to get a new one instead, might cost you as much as buying a new one if you are going to have it repaired.
May 14, 2008 | Kenmore Oasis HE 27082 Top Load Washer
The start button keeps blinking, WONT LET ME DO ANYTHING
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
GE Washer Start button flashing - DoItYourself.com Community Forums
www.doityourself.com/.../386041-ge-washer-start-button-flashing.html
Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
Oct 29, 2015 | Washing Machines
GE GTWN5050M0WS top loader Washer, during the spin cycle the tub itself will not spin, but the bottom center piece will? Any ideas? Thanks
Call in an engineer. We had the same trouble and it was the clutch in the bottom of the drum. Takes about 20 minutes to fix.
Sep 18, 2015 | GE GTWN5050MWS 27" top-load washer with...
GTWN5050M0WS won't fill
There is a small glass fuse on the left inside the front panel. Replace it.
Jun 24, 2014 | Maytag LSE7806A Top Load Stacked...
GE refrigerator pfss6pkwbss flashing 88 82 after a brief power outage...any info on how to resolve? Tried unplugging for about 2 minutes, and this did not solve it. buttons on door panel do not work at...
To reset the panel display, press and hold the top left (Energy Saver) and top right (Alarm) buttons at the same time for about 10 seconds--the panel will beep and reset.
The panel will require a reset whenever the power is interrupted..
Feb 03, 2011 | Refrigerators
Simply press the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 seconds--it will beep and reset the panel! I was told by both GE and a local repair service that I had to replace the entire control panel...what a RACKET!! GE needs to start telling people this trick when they call in with this error...it will come up every time there is a power outage.
Nov 23, 2010 | Refrigerators
WCVH6260HWW GE front load washer won't start - press the On button, then press Start/Pasue button and it goes beep beep, and keeps blinking, and washer does not start; the washer pump strainer has been...
Feb 23, 2009 | GE WSXH208A Front Load Washer
Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
118 people viewed this question
Top Washing Machines Experts
