Question about Epson TM-T70 Receipt Printer
Epson tm p2 01 drivers
Cant install. no drivers found. im using the parallel cable. the printer is included in the "unspecified" section on my device and printers. Im using a 64bit windows 7.
Noggin
  • 944 Answers
SOURCE: Printer problems...
It sounds as if the port is trying to operate a mouse - giving the ???????. If you have windows XP then go to control panel, printers and faxes, then click "add a printer". The add printer wizard starts up, click next. select the "local printer" option and make sure the "automatically detect and install....etc" option is turned off. Click next and you should be able to select printer port. If you are using the serial port COM 1 (usually the only one externally on the pc), then select it from the list and follow the wizard through to the end. Restart the PC and you should hopefully find that the port has become dedicated to the printer alone. if still problems, go to device manager, right click on the COM 1 port and select properties, it should allow you to start the troubleshooter for the port. This should help. Other operating systems will have a similar procedure. Also worth trying is to uninstall the epson drivers, restart, plug the printer in and turn it on, and see if windows will automatically install the printer without the epson drivers. If it will, then let it do it's stuff and hopefully it will work. Hope this helps :)
Posted on Jul 01, 2007
CompuGuy44
  • 432 Answers
SOURCE: ??????????? printer doesn't stop printing, help!
Turn off the printer. Hold down the power on button for 20 secounds. Did that clear it up Pete ??
  • 99 Answers
SOURCE: driver TM-L90
Hi...here is the European download page for this model, ...hope it helps!
http://content.epson.de/en/rsd/service/index.1022.htm
Posted on Jun 03, 2008
muntejaya
  • 10421 Answers
SOURCE: I have a epson TM-T8III printer of a POS windows 7 printing slow.
Please get the correct driver here : www.printcountry.com/drivers.asp
www.opendrivers.com/.../printers-free-driver-download.html
www.driversdown.com/driverslist/r_4_1.shtml
Regards, Jay__yhr4e5
Posted on Feb 26, 2011
Basti
  • 1447 Answers
SOURCE: Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Posted on Sep 20, 2012
Epson UB-U03II not working
I had huge issues with my TM-U220. It does not play well with a Centronix-to-USB cable or with Windows 64-bit. I played for AGES to try and get it all to work.
I installed the USB device driver[1] I was able to print the Test Page proving that the connection between Windows and the printer sort of worked, but when I tried printing anything from Unicenta POS, it always failed.
I finally bought a new Centronix-to-USB and a new parallel port card, used Windows 32-bit, and problem solved.
They key is to uninstall everything, including searching through the Registry to delete everything.
[1] https://pos.epson.com/developers/techresdetails.htm?ProductPK=545
May 30, 2014 | Epson TM-U220 Matrix Printer
Epson TM-U220D. Parallel to USB connection. Which drivers should I install?
Hi Ali
The problem by doing this is that not all Parallel to USB cables work right out of the box with your equipment.
What you need to do first is make sure that your computer sees the device through the cable. Then when it prompts you for the drivers for the printer install the driver set (parallel) the connection should not matter at this point. However the step of the computer detecting the device first is very important.
I hope this helped.
Philipp
Apr 16, 2014 | Epson TM-U220 Matrix Printer
HP LaserJet P3005 Printer will not print using a parallel cable.
# Switch off the printer, cancel pending jobs..Refix parallel cable both ends & tighten them Check proper drivers installed or not if not install proper drivers.. shoot print command. check..if not resolved...For tech guys:# Replace cable..checkRemove printer formatter, check any dry solder or pin breakage at parallel port.(show in snap shot), found... try to repair it or replace the formatter assm. Check system parallel port working or not...
Dec 30, 2011 | HP LaserJet P3005 Printer
Hi!
Dec 24, 2011 | Epson TM-U220 Matrix Printer
Trying to install epson tm u220pd with USB port, what drivers do I need? Plug and play does not install it in setup wizard
if your using TM-U220PD which is a parallel , you should connect it in parallel port then use this printer driver http://pos.epson.com/developers/techresdetails.htm?productpk=545
Feb 18, 2011 | Epson TM-U220 Matrix Printer
I cant find a mac driver for the Lexmark X1270!! please help me. im using a macbook pro running Snow Leopard. Also, there are other answers but the links dont work, they just take you to the lexmark...
Lexmark does not seem to support this printer for Mac. I found MS drivers on their website (long URL, cut and paste each line in sequence into the browser address bar before hitting enter):
http://www1.lexmark.com/products/view/All-in-Ones/Lexmark-X1270/catId=cat10004-category&prodId=3562-product;jsessionid=91352532FD946388CB130A3CEEF86273.node2
The link to the drivers is on the lower right of the page labeled Download Drivers. There is are applications to run a virtual PC on a Mac system (Parallels is one such program). You would also need to purchase a valid copy of Windows to run inside the program to install one of these drivers for your printer.
Sorry that I can't be of more help.
Mar 08, 2010 | Lexmark X1270 All-In-One InkJet Printer
Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Nov 21, 2009 | Epson TM T90 Printer
Downloaded driver, can't print, when reloading printer, message says need IEEE: 1284.4 printing support. cant find anywhere in hp to fix
The error refers to a parallel printer cable, also known as a centronics cable. This surprises me as I believe this printer is connected via USB cable. If not, get a new parallel cable and try it. Here's a link about that cable...
http://en.wikipedia.org/wiki/IEEE_1284
If it's USB, I would use HP's online chat and ask them what to do about the problem. You can reach them here...http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=445194&taskId=110
Aug 12, 2009 | HP LaserJet 2840 Printer
Epson TM-T70 Receipt Printer Logo
381 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
