Red light blinks twice even with left flap pressed in.
    Top Expert:
  • Televison & ... Master
  • 74,377 Answers
What is the brand name to your remote control?
Posted on May 11, 2013
I need a code and instruction to program my remote control with a magnavox tv
  • The Magnavox codes are 32114 and 11434. Should those codes not work then follow these steps to do a code search that will find the code inside the remote.
  1. Turn on your TV.
  2. Press and hold down the SET UP key until the red light blinks twice.
  3. Press Programme - three times. The red light will blink twice.
  4. Alternate between Programme- and Power until your TV turns off.
  5. You may have to press these keys many times, so please be patient.
  6. When your TV turns off, press the SET UP key to store the code. The red light will blink twice. Your TOTAL CONTROL is ready to run your TV.
Regards, Tony
May 18, 2011 | One For All URC4110 Remote Control
So my urc-3021 used to work for my durabrand television. I went away for a few months and came back and the batteries needed changing. I changed them and the remote didn't work for the tv (although the...
then 0178 is not the right code if the light blinks twice try code search turn the tv on press tv then hold setup till it blinks twice then point the remote at the tv then press the power button repeatedly till the tv turns off then press the tv button again
Aug 28, 2010 | One For All URC-3021 Remote Control
Hi i have lost instruction manual for my total remote urc 11-4110 b02 Universal Remote could you tell me how to code it to tv manually please
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 10pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; } SET UP
TV
The Search Method
If your device does not respond to the TOTAL CONTROL after you have tried all the codes listed for your brand, try searching for your code. The Search Method allows you to find the code for your device by scanning through all the codes contained in the memory of the TOTAL CONTROL.
To search for your TV code:
1 Switch your television on (not on standby) and aim your TOTAL CONTROL at your TV.
2 Press the TV key on your TOTAL CONTROL.
3 Press and hold down SET UP until the red light blinks twice. (The red light will blink once and then twice)
4 Press 9 9 1. The red light will blink twice .
5 Now slowly, alternate between POWER and TV, over and over, until your television turns off. You may have to press these keys many times (up to 150!), so please be patient.Remember to keep pointing the TOTAL CONTROL at your television when you press these keys.
6 As soon as your television turns off, press SET UP.
The TOTAL CONTROL remote should now be ready to operate your device. Turn your device back on and try all the remote’s functions to ensure they are working
properly. If some of the TOTAL CONTROL’s commands are not operating correctly, try the search method again. You may be using the wrong code.
Once you have Set-Up your TOTAL CONTROL, you can blink back your SET-UP CODE for future reference.
Example: To blink out your Television code:
1 Press TV once.
2 Press and hold SET UP until the red light blinks twice (The red light will blink once and then twice).
3 Press 9 9 0. The red light will blink twice.
4 For the first digit of your four-digit code, press 1 and count all the red blinks. If there are no blinks, the digit is "0".
5 For the second digit, press 2 and count all the red blinks. If there are no blinks, the digit is "0".
6 For the third digit, press 3 and count all the red blinks.
7 For the fourth digit, press 4 and count all the red blinks. If there are no blinks, the digit is "0". Now you have your four-digit code.Make sure you write your Television code for easy future reference.
Aug 12, 2010 | Televison & Video
Ice maker will not make ice. Red light blinks
I have a kitchenaid with the same problem. Red light blinks twice when open is normal. Hold the flap down and the red light will be on.= normal= optics are working. If the ice rakes rotate, module is probably fine. Check the simplest solutions first, defrost the freezer in case the icemaker water nozzel might be frozen. That solved my problem. I then increased my freezer temp by a couple of degrees and so far, no problems.
Good luck.
Jan 30, 2010 | KitchenAid Superba Architect KSCS25INSS...
Universal remote - program digital converter box and Roku?
if you still have your remotes you can program the buttons for each funtion.
1. Hold down P until the red light blinks
twice.
2. Press 9 7 5. The red light blinks twice.
3. Press the device key that corresponds with
the desired device's remote (TV, CBL/SAT,
DVD, VCR or AUD).
4. Press the desired learning key. The red light blinks rapidly.
5. Place the device's remote control head-to-head
(about 2 inches apart) with the
11
Gamer Remote.
6. On the device's remote control, hold down the key to be learned until the red light on the Gamer Remote blinks twice. If the red light does not blink twice, repeat Steps 1- 5.
7. To lock in learned functions on the Gamer Remote, hold down P until the red light blinks twice.
8. To test a learned function, press the learned key on the Gamer Remote and use the function as usual.
Jan 14, 2010 | Radio Shack (15-2147) Remote Control
How do you tune Sky+ remote into Sony KDL46W5710 Television
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Dec 19, 2009 | Televison & Video
Red light on ice maker blinking twice, no ice.
I would assume you are referring to the ice level sensor that is on the center divider. It is normal for it to blink if the door is open. You can test out this theory by holding the flap on the left side closed but not blocking the sensor. The light should go steady. If the ice maker is not working then you either need to change the lazer sensor or the ice maker itself.
Feb 01, 2009 | KitchenAid KSRG25FK Side by Side...
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
Oct 17, 2008 | Philips HDD065 MP3 Player
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press tv guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
Feb 13, 2008 | Televison & Video
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
