Question about Samsung RB2155 Bottom Freezer Refrigerator
'FD' continuesly blinks on the display and won't do anything,
No even the light comes on when FD is blinking I replaced the main board,capacitor,transformer,and display board and still continues to display FD.
  • 62 Answers
SOURCE: green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Posted on Oct 13, 2008
SOURCE: Samsung TV won't turn on- trying to fix it. A challenging problem
I had the same problem. I live in NJ and called the local authorized "service provide" listed on the Samsung website. What a joke. Quoted $350 just to show up, never showed up. So I opened my own TV. Took off the plastic back (10 screws) took off the large metal RF shield (12-14 screws) and noticed a blown component. The markings on the component were KL15L and it is apparently an NTC Thermistor. Obviously it got fried and not knowing if there was other damage I decided to set out to replace the entire Power PCB Board Assembly and not the component. There were two part numbers on the assembled board (BN97-00457E & BN94-00622E). After searching online I also found a suitable replacement number for these (BN96-04896A). I found two places who claimed to have the part or have it on order (shopjimmy.com and vancebaldwin.com). After placing orders with both and having neither come through, I broadened my search and found out that the LNR409D was basically the same model as my LNR408D so I looked for its Power PCB Board Assembly part number which turned out to be BN41-00521B. Google search for that part number showed the item available on ebay. I bought it a week ago (ebay 260311519904) for $144 plus $12 shipping. I removed the bad board an hour ago (6 screws about 7 connectors) installed the new one, plugged in the connectors, replaced the covers, plugged in the TV... AND IT WORKS!
Suggestion: If your TV is out of warranty then open it up (what have you got to lose) and see if the problem is obvious and maybe something you can fix (replace) yourself. The parts, spare boards, etc. are out there if you look.
Posted on Nov 16, 2008
ladywinn
  • 5138 Answers
SOURCE: Samsung HL-S5679W won't start - LED light blinking
Replace Lamp,but CK to make sure Fans are running if OK then replace Lamp Mats Has them for 99.00
1-800-628-1118
Posted on May 11, 2010
budmrtn
  • 11361 Answers
SOURCE: TV WONT SWITCH ON LE26A456C2D standby light blinks
Please read my giude then you may understand more as to what it takes to make the TV functions.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Posted on Mar 06, 2011
imufo2
  • 3773 Answers
SOURCE: Fridge is freezing everything. Tried
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Posted on Aug 25, 2011
My tv kv-xr29m50 won'to on.stand-byl light blinks 8 time
Count the number of blinks occur at one time switch ON. These blinks are fault indications. After counting it, check this link for more details. There are details about Sony blinking codes. Search the site by brand name and model number to your TV in its search box.
Jan 29, 2013 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Sony trnitron tv won't turn on. stand by light blinks. Any ideas?
watch the blinking light---if a specific sequence like 7 blinks a pause and repeated endlessly that is a error code. It will not point to a specific part but will indicate where the issue might be.
Dec 19, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony Trinitron won't turn on red light blinks 9 times
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not re-solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Apr 29, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv36xbr800 won't turn on -standby blinks 2 times pls help
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Apr 22, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
Tv won't stay on it shuts off as soon as I turn it on and now there is a blinking light on the front and it's blinking 7 times
Most Sony's usually always have bad regulator ics. Depending on your model, could be a mcz3001 or str ic or mxoa ic. Check for 160v across the main capacitor for 160v to see if your power supply is working. Do not use chassis ground. Use the ground on the cap.
Oct 22, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My tv sony wega dont turn on an the standby light blinks 16 times model KV-32FV310
Hello
Standby light on Sony TVs blinks 16 times is abnormal I thiks. It may come up to 8 blinks or so. You jsut switch off the set by AC mains switch at the front panel, switch it again with it and count the exact numbers. Never switch it On_Off by remote hanset.
If it happens even after this process, you just do the following
Press the following button on your remote control as stated
"Display"_"Channel"_"5"_"Vol Minus" [not plus] then "Power".
You may get "OVP" "OCP" "V STOP" etc displayed on the screen.
Just report the result to me through Fixya. Ok.
Nov 04, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Is my tv dead?
no not at all , may be lot or h.o. transitror ar circuit dry solder, if any problem led red indicator blinks continuesly.. please chek all h.o section...and smps...
Sep 28, 2007 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Samsung RB2155 Bottom Freezer Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
