Question about Amana NED7200TW Electric Dryer
Error code UPSIDE DOWN F5
2 Suggested Answers
GodBlessU
  • 3513 Answers
SOURCE: getting an upside down F5
Hi
That is actually a " ts " error. Thermistor Short Sensed or the Thermistor resistance is very low.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Check this link for the part marked as 27:-
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Dryer-Parts/Model-NGD7200TW10/1268/0151200/W0712024/00003?componentDescription=BULKHEAD%20PARTS&brandDescription=&searchTerm=
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jul 26, 2011
Bravos XL F5 error
Here is a link to the error codes for your machine. There are several F5 error codes. F5 E4 Lid not opened between cycles F5 E3 Lid unlock fault F5 E2 Lid lock fault F5 E1
Lid switch fault
Oct 31, 2017 | Washing Machines
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How do I trouble shoot the error code on my LG Tromm WM0642HW, it is an upside down F and E.
could the upside down F be a lower case t. If so the error code is tE and you have a heating problem.
Jan 25, 2015 | LG Washing Machines
Won't self clean. I am getting an error messag FSE 1.
Most likely it is F5-E1 code. self clean latch will not lock. follow procdures below,but likely problem is failed lock motor
All F5-E Codes - Door Switch Defect - This occurs when the door switches do not match. If door is latched, disconnect power from unit and check wires and connections. If damage is found, replace appropriate part. If connections are not damaged, reconnect power and hold down any key until the F5 error clears. Once the F2 code appears, select 'cancel' and observe for one minute for errors. If door is NOT latched, disconnect power from unit and check wires and connections. If damage is found, replace appropriate part. If connections are not damaged, measure door switch (door open = latch open) and latch switch (unlatch = switch open) and replace either if defective. If corrections are made during any step, power should be reconnected and the unit should be tested. Press and hold any key to clear the error code and F2 code should appear. Select 'cancel' and observe for one minute for errors. If error continues, disconnect power and replace control.
Dec 28, 2010 | Whirlpool GR460 Electric Kitchen Range
Cd read e-05
Well E-05 error code on Kenwoods is "the cd is upside down" So either the disc is upside down or there is a problem and the Kenwood unit thinks it is upside down.
Mar 05, 2009 | Kenwood KDC-MP332 CD Player
Samsung front loading washer temperature sensor problem
It may not be your temperature sensor or thermistor. If you have a tE error code on your Samsung washing machine, first check the wiring. My Samsung washer had three visits by the repair tech. and new parts ordered again and again. I looked on a British web site and two people said that it turned out to be wiring broken in several places. Sure enough, I found a broken wire. Technician didn't look for that. Hope it's as easy for you.
Feb 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool accubake oven door will not open e1 f5 and e0 f5 error codes
F5 fault codes are latch mechanism problems. One means the latch won't lock, the other means the latch won't unlock. Odd you're getting both...
Feb 09, 2009 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool accubake oven error code
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
It may just be a door switch
Dec 18, 2007 | Whirlpool RBS305PDS Electric Single Oven
Amana NED7200TW Electric Dryer Logo
24 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
