Question about Toshiba Satellite Computers & Internet
Interchangeable parts Hi, Would like to know if a Toshiba L355D-S7901 Touchpad will swap with a L355D-S6889 Touchpad?
  • Toshiba Master
  • 7,627 Answers
mjoverstreet
  • 19 Answers
SOURCE: Remove Bezel on Toshiba A355D-S6889
Ok, if you have never replaced a laptop screen before, you might not want to do this one first. It appears that the screws on the face of the screen have to come off first. They are under the rubber footies. After screws are out, tape them to a piece of paper, and label what they were for. Do this for all screws you remove, After screws are out, you will open the screen as far as it will go without forcing it. Using a plastic card, or similar PLASTIC tool, slide into the crack around the perimeter of the screen facia. You will hear "pops" as the snap clips are opened. The lower case of the laptop may also need to be removed. This repair is best left to someone with experience, so be careful to remember what screws go where. This is very important as a long screw in the wrong place will destroy your machine. Check out this page that sells parts for this machine:
http://www.laptoprepairparts.com/html/LRsearchmodelresults.asp?brand=toshiba&model=a355d-&txt=Satellite A355D series (A355D-S6881, A355D-S68811, A355D-S6885, A355D-S6887, A355D-S6889, A355D-S6921, A355D-S6922, A355D-S69221, A355D-S6930, A355D-S69301)
you will need to copy and paste since the website uses spaces, and the models were truncated. Without seeing the actual device in person, it would be difficult to walk you through it. Just remember how you took it apart, tape screws to paper with descriptions on where they went, protect against static, dust, water, and always use plastic tools to avoid scratches.
Posted on Jun 30, 2009
  • 66 Answers
SOURCE: Toshiba Satellite L355D-S7901 will not boot
pull the ram individually and see if that allows the computer to boot. If that does nothing then you would need a new motherboard.
Posted on Nov 06, 2009
  • 13433 Answers
SOURCE: my laptop says its missing
You need the windows vista disc, insert it to the laptop, and select Repair my computer when it loads.
Then select start up repair from the top:
If you didn't receive a disc with the computer, any windows vista disc would do, can you get one from somewhere? borrow?
Posted on Sep 28, 2010
  • 181 Answers
SOURCE: Toshiba Satellite L355D-S7901 problem : after
Try to remove the laptop battery, hard disk. connect the laptop to AC power then start the laptop. Then try to check whether you can login to the BIOS setup or not.
Posted on Jun 06, 2011
DJ Skywalker
  • 507 Answers
SOURCE: when restoring toshiba L355D-S7901 what
Read this forum:
http://www.howtogeek.com/forum/topic/recovery-error-on-toshiba-satellite-a205-s5864?replies=21
Posted on Jun 20, 2011
Toshiba Satellite Laptop wont boot up
does it shows the flash screen which displays *********** board? if yes then you can check by installing a fresh copy of windows and if nothing comes on the screen then you may have defective mother board.another thing if *********** board is fine and you find that your system is not installing the OS,you need to zero-fill your hard drive then,coz you may have a corrupted hard drive.
Apr 07, 2012 | Toshiba Satellite L355D-S7901 Series...
Problem with L355D-S7901 random shut off
check all leads from motherboard to hard drive including electrical extensions and all of your cd/dvd drives make sure connections are secure dust free and not faulty
computers need all power and data to travel through every working device and to finish its cycle
so any faulty lead will end in computer error or shutdown or fail to boot
make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets
some motherboards cmos batteries are soldered in
might be getting hot check your CPU make sure it has a thermal paste and a dust free and secure seating
could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU you might not have enough RAM random access memory
hope this helps you
Mar 23, 2012 | Toshiba Satellite L355D-S7901 Series...
Toshiba l355d s7901 black screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 26, 2012 | Toshiba Computers & Internet
When restoring toshiba L355D-S7901 what does "error 10-FA11-045D" mean? i get that code when its creating the crc files. how can i fix this?
Read this forum:
Jun 20, 2011 | Computers & Internet
Help me please my toshiba satellite l355d-s7901 not starting up it only stay in long beeping sound when i power it on please do help me
i doubt it that its a long single beep ... chk out this website it has the beep codes u wil be able to understand what the issue is if u do not get it plz reply with the beep code and the meaning given on the website
http://networking.ringofsaturn.com/PC/beep.php
Feb 04, 2011 | Toshiba Satellite L355D-S7901 Series...
Can i replace a toshiba l355-s7901 motherboard with a toshiba l355-s7915 motherboard
Going out on a limb here, but I'm going to state yes, except the s7901 has hot keys in the center strip under the LCD screen. Above the Keyboard, where the Power On button is located. The s7915 doesn't.
Toshiba Satellite l355-s7901,
http://www.notebookcheck.net/Toshiba-Satellite-L355D-S7901.14988.0.html
You can click on the photos towards the bottom to enlarge.
Toshiba Satellite l355-s7915,
http://www.notebookcheck.net/Toshiba-Satellite-L355-S7915.19879.0.html
Same with the photos at the bottom.
I know this doesn't seem like a very professional answer/solution, but in viewing both of the laptops the ports, (USB, DC Power Jack, etc.), and the peripherals, (DVD optical drive, add-in card drive, etc.), seem to be in the same place.
Viewing a Service Manual for the Toshiba Satellite l350 series of Notebook PC's, shows removal procedures to be the same across the board, no matter what model deviation it is.
As long as it's one of the Satellite l350 series.
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the second Satellite file header. The one that starts with Satellite A10.
Now go down to the second line, and then go across to L350, and click on it.
This is a PDF file. May take up to 30 seconds before you see the first page, and additional time to fully download.
Do I know for a fact they will interchange? No, I do not.
I'm willing to bet strongly that they will.
Nov 20, 2010 | Toshiba Computers & Internet
Toshiba Satellite L355D-S7901 will not bootup. Hard drive light, lights and just stays on.
Nov 06, 2009 | Toshiba Satellite X2 RM-72 Notebook
Computers & Internet Logo
54 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
