Canon ir3235 is there a way to change the default setting from 2-sided printing to 1-sided?
alvinbga
  • 130 Answers
SOURCE: Changing default paper size
Press & hold shift then press sel to enter menu mode. Press group until the group you wish to change appears in the first column. Press item until the item you wish to change is in the second column. Press set until the setting you want appears in the third column. Press and hold shift then press sel to exit & save your settings.
The default page sizes are; 11", 11-2/3", 12", 14", 17", 5", 3", 4", 5.5", 6", 7", 8", 8.5".
Posted on Jul 04, 2008
the_fire
  • 432 Answers
SOURCE: HP Laserjet 5000dn
if you using office go to page setup and select the tray(s) that you want to use for the first page and other pages ( both must be the same ) unless you only want the first page as letter head and the rest on plain paper or something along those lines ?
Also if you go into the properties of the printer and go to advanced and then click on the printing defaults button and see if the options in there are the same or different to whats in printing preferences.
If they are set to tray 1 then it will default to tray 1
Posted on Apr 13, 2009
SOURCE: Keeps telling me to load tray 1.
dragon is a moron... cram cheese into the cyan ink cartridge.
Posted on Jul 08, 2009
komguy
  • 2306 Answers
SOURCE: Default Settings for Canon Imagerunner 3025 Scanning
You will find those settings in your scanning software on your computer, since all of them are different, there is no one right answer. Some you have to choose each time you start a new job or document.
Posted on Jul 22, 2009
  • 4 Answers
SOURCE: HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Posted on Sep 18, 2009
I cannot figure out how to get this printer (Canon imageRUNNER 3235) to join a wifi network so we can wirelessly print from multiple computers.
Is this a wireless device? According to the Canon specs it's wired LAN only http://www.canon.co.uk/For_Work/Products/Office_Print_Copy_Solutions/Office_Black_White/iR3235/index.asp?specs=1 You could either use a wireless bridge to connect it to your wireless network or hard wire it to your switch/router by a CAT5 cable
Jan 08, 2013 | Office Equipment & Supplies
Canon imagerunner 3235i. When it goes to print out the copy it instantly pulls it back into the machine and causes a jam. Any ideas as to what would be causing this or how to fix it/
you have opted for a 2 sided profile in the printer driver.change it to default settings.the copier is trying to print on both sides.if it is happening also during copying then u have to check the settings you have made.you can also clear the settings in common settings in additional functions . if u cant take 2 sided copies then u have to get ur copier check for duplex unit malfunction.
Aug 03, 2011 | Canon ImageRUNNER 3235i Black and White...
Canon iR3235 will not print over the network. I can ping
Reboot the printer. ANd also try re-mapping the printer from your system.
Jul 09, 2010 | Canon Office Equipment & Supplies
We have 2 Canon ImageRunner 3320N copiers, but they are behaving differently when they are being used as a scanner. On one copier, when scanning a double sided paper it will automatically scan each side....
it is in the copier settings. one is actually set up to automaticly do doublesided copies as a default. while the other one is only set up to do singlesided copies
first while on the main copy screen change the setting how you want the copier setup ..... double sided printing, black and white, or how ever you want your defaults to be set up
then you will need to goto the additional functions button and under copy settings you will need scroll down to the second page.
there you will want to hit the standard setting button then click the store button, then click yes... now it will default to the double sided copies.....
hopefully this will fix the problem if not get back to me
Jun 18, 2010 | Canon ImageRunner 3320N Copier
Printing booklets without reducing contents
Click on the "arrange" tab and then click on Layout Guides, and the margin guides will come up. 1" is trhe default setting, you can set it to whatever you want
May 05, 2009 | Canon MX700 Office All-In-One InkJet...
Printed 2 sided copy now everything is printing 2 sided ITS STUCK
If you printed this from the PC you might have changed the default in the printer driver. Browse to printers folder then right click and choose Print Preferences. Look for 2 sided selection and make sure it hasn't been changed.
Hope this helps,
TankMurdock
Mar 20, 2009 | Canon imageRUNNER 1023iF Black and White...
How do I stop daily reports from printing? How do I change the default tray for fax reports?
To program a default paper tray to print fax reports, perform the following:
1. Select Utility/Counter.
2. Select User Setting.
3. Select System Setting
4. Select Paper Tray Setting.
5. Select Print Lists
6. Select the paper tray for the fax reports to print from.
7. Press OK.
8. Press Exit on the lower left side of the display to return to the copier screen.
to set the activity report to not print daily
1 touch the utility button
2 touch administrator settings and enter the password 12345678
3 press fax setting
4 press report settings
5 select activity report and change to off
6 press close then exit
Mar 17, 2009 | Konica Minolta bizhub C250 All-In-One...
82 people viewed this question
jasbo
jasbo
