Xerox 432st erroe code 4D23
4 Suggested Answers
xptareq2000
  • 1447 Answers
SOURCE: xerox 432st leaves a margin of an inch on 2 side of the paper.
you must be change your copier internal setup.
press Default code key symbol button #22222 then press enter copy setup change margin or disable
Posted on May 19, 2010
xptareq2000
  • 1447 Answers
SOURCE: Xerox 432 ST Service Manual. Is there a service
xerox is a big copier company they always support on line www.xerox support.com
lbrown1806
  • 488 Answers
SOURCE: I need a list of erro codes and definations for
When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
003-754
003-755 An error occurred in the document scanner. Reset the document, and scan again.
003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
smaller segments.
003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
005-210
005-275
005-280
005-283
005-284
005-285
005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
Posted on Jan 16, 2011
Xerox DC250 error code 116 340
my machine is the xerox 7245
erros is the 116-340
Nov 03, 2012 | Xerox DocuPrint 340A Laser Printer
Xerox 7328 error code 026-717
Make sure the DNS info is properly configured.
http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html
Jun 23, 2012 | Xerox Workcentre 5225 / Copier, With...
Area where final copies come out of machine making
Sounds like the output clutch. Take the top off the fuser area and clean the clutch.
Dec 04, 2009 | Xerox WorkCentre 432 ST Copier
Xerox document center 430st
I will try to find a solution
Feb 21, 2008 | Office Equipment & Supplies
Xerox U2-2 erroe code
You did not say what type of copier this is, but most codes are the same for most of the copiers.
Look at this link:
http://www.copier-help.com/copier-help/ecs/xerox/ecx1012.html
Oct 19, 2007 | Office Equipment & Supplies
598 people viewed this question
jasbo
jasbo
