Question about Poulan Garden
What makes the blades on a riding mower stop turning once the mower belt is disengaged?
I have a poulan pro PR1842STC; the blades won't stop turning after I disengage the mower belt. Before when I disengaged the mower belt, within seconds the blades would stop turning regardless of the engine rpm. Now they continue turning until they slow down to a certain rpm then a "brake" or something engages (I hear a "clunk" sound") and they immediately stop turning. I'm now having to turn off the engine to get the rpm's slow enough to get the brake to engage. What is the "braking" or stopping system for stopping the blades on a riding mower?
  • Poulan Master
  • 645 Answers
The brake mechanism works when tension is released from the idler / cable. The brake is spring loaded to contact the spindle this stops the blades from spinning. I have attached a drawing showing the brake arm and where it can be found on the deck.
What makes the blades on a riding mower stop turni - afzvk1vyaxgoaaaaaelftksuqmcc
Posted on Dec 04, 2017
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
Posted on Jun 01, 2009
SOURCE: once engaged and start mowing, you can mow for
I have the same problem with mine and its not the air filter. I have a new filter and cleaned it and still does it. I even took the air filter off and it still does it.
Posted on Aug 18, 2009
  • 6 Answers
SOURCE: Park Brake / Clutch Lever will not disengage.
check ur belt and pullys under deck or pto switch went bad could be replace
Posted on Oct 11, 2009
  • 75 Answers
SOURCE: Riding only on an old Craftsman riding mower, when
Check on the mower that your drive belt has not come off or has not broken
Posted on Jun 14, 2011
  • 665 Answers
SOURCE: swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
I struck an object while mowing my yard and the tractor wont start or even crank what could the problem be?
start by disengaging the blade and putting the deck to it's highest position, prior to attempting to start the mower inspect under the mower deck making sure there is no Debee wedged interfering with the blade rotation, check your spindle's for play and inspect your mower and drive belts. once complete than give it a try. if by chance it does start but turns over you more than likely sheered the flywheel key.
Oct 10, 2013 | Poulan Pro 46Inch 22 HP Yard Tractor with...
On the top of the mower deck, there is a spring that will pull to disengage the blade idler pulley. At the same time, it will release two springloaded arms with brakes that press on the pulleys at the top of the blade spindles. On top of the mower deck at the back, the two spring loaded arms may be held out of the braking position by a cam. Make sure the cam is free to allow the blade brakes to activate when you disengage the blades. If arms are out of alignment, or the parts are too worn, the blade brakes won't move and the blades keep spinning, even after you have disengaged and the safety switch is deactivated. This is a dangerous situation and should be fixed soon. Good luck.
May 09, 2013 | Poulan Garden
Blades won't disengage.
If this is a riding mower, then check the cable tension around the belt. I have a craftsman and when I take the deck off for the winter, there is cable under there that controls the blades from going. You can follow the cable down to the blades it usually is under the hood. When you are on the bottom have someone control the lever and see if it tightens and loosens the belt (do not have the mower running!). A axel should move to tighten the belt to turn the blades and when you pull the lever to stop the blades the axel should move to loosen the belt. Hope this helps. Oh from there the cable could be snapped, which is a 35 to 65 dollar part. Also could be the axel itself has something faulty where it doesn't move.
Oct 15, 2012 | Garden
Poulan Pro riding mower won't turn right. I can
there is a plastic connector that holds the steering shaft down into the drive gear the plastic cracks and wears out then the gear jumps passed the teeth its about a $15 part
Jun 14, 2012 | Garden
Need to locate a diode for a Poulan Pro riding mower
it is on the engine side of the two wire plug going to the engine it will only be a slight bubble in the wires
Apr 03, 2012 | Poulan Pro Garden Tractor 2005 and Older...
The mower blade drive belt on my Poulan Pro 16.5 HP, 42", model #310777 broke. The only manual I could find was for a model 60614 which was of very little value to me. The parts store sold me a Gates...
The only thing I can suggest to get you in the ballpark of what is wrong or if you can replace what you need replaced is to look on the Poulan website and get a customer service phone number. Chances are they will know exactly what you need. Hardware stores are too broad and it sounds like you need specilized attention.
Aug 07, 2010 | Poulan Garden
Mower will not disengage
this is because your belt that drives the blades is to tight i suggest getting a looser belt
May 10, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
After replacing the belt, new pulleys, and bolts, my mower wont disengage the blades when i disengage the lever. when i start the mower, the blades are off, but once i engage the lever, they start, but...
sounds like the linkage to your blades, check your lever, to make sure its working right may need some grease, it may be sticking and not fully engaging, or doing its job when its supposed to
Oct 17, 2009 | Craftsman Garden
Garden Logo
91 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
