Pro Form 590s
The problem is that it shuts down right after I select any speed. All the rest of the buttons work (incline, fan, programs, etc). I first thought it was due to overheating but i normally run 3 -4 miles and I've never had this problem before. It started after I ran a mile then I went back to it to finish my workout and all of the sudden it shut off. Then, it stays off for a few minutes while the safety key still on then turns on showing a bunch of zeros then the normal screen shows up. Again, I tried the rest of the buttons but as soon as i hit any speed it shuts off as if it didn't have any power. I tried plugging it to a different power source and reset button but no luck. Any other suggestions? Thank you Victor
  • 7,627 Answers
I think you have the wrong category.
Posted on May 10, 2013
  • 324 Answers
SOURCE: Viao PCG-GRX650 won't shut down fully
DaveBaker,
Here are a couple of tips that I've collected that may address your problem.
Go to start>run>then type in "cmd" without the quotes. this will bring up the command prompt. next type in the following command: "shutdown -s" without the quotes again. This should tell your system to shutdown your computer entirely.
Next
Try doing this. Hold down "ctrl" and left click "shutdown". This skips some windows XP shutdown procedure and should do the trick.
And, finally
http://support.microsoft.com/?kbid=831431
You cannot log off, restart, or shut down your Windows XP-based computer This article talks about an issue with Norton 2003 incompatibility.
Would appreciate any feedback as to which of these worked for you.
Thanks much!
Ron-
Posted on Nov 10, 2007
Palmbeach
  • 185 Answers
SOURCE: Aspire 5610-4621
Hi Dianne
Do you have a battery installed or are you running on a power adaptor but no battery at all.
A couple of things I would think about. Firstly, if you do not have a battery installed, install one. There are pros and cons as to whether a battery should be left in if you always use mains. However, if there is a problem with the mains adaptor or any interruption caused by poor connections or intereference, the battery will keep your laptop alive.
Laptop power sockets are notoriously unreliable especially if you are constantly plugging in and removing the power adaptor. Make sure it is firmly pushed home and if it is loose, consider replacing the socket. Also the power lead may have become intermittent.
Yes it could easily be caused by heat. Ensure that there is sufficient ventilation to allow your computer to dissipate heat effectively. I always use a neat home made stand on all my laptops so that even if it sits on my bed there is plenty of room underneath and the vents are not covered or restricted. It only needs to be elevated by an inch or so. I always think of a computer needing to breathe and I don't want to suffocate it.
Can you hear the fan(s) operating? Laptops can end up as dust buckets. Have you made sure the fans and vents are reasonbly clean.
Finally, if you often take your laptop out, something may have worked loose inside such as a ribbon connector.
Posted on Feb 20, 2008
askmenow
  • 22 Answers
SOURCE: Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
Posted on May 19, 2008
naslicer
  • 73 Answers
SOURCE: Travelmate 290 starts then shuts down
please re install the recovery software.
Posted on Dec 11, 2008
gsage
  • 180 Answers
SOURCE: HP probook 450s When I
You have a m/board power chipset failure - new m/board required
Posted on Jul 10, 2011
How to recalibate a pro-form 595LE treatmill.
follow this steps and fix it. God bless you
The Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Dec 09, 2013 | Proform 595LE Treadmill Walking Belt
Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Nov 17, 2011 | Nordic Track NordicTrack Commercial 1500...
Ifit light flashes. Everything works properly except light flashes, which is distracting and irritating.
o 1 Check the connection cablebetween the Pro-Form device and the home stereo, computer, television or VCR ifthe iFit program is not working. Ensure that both the Pro-Form device and thestereo device are both turned on in order to function properly.o 2 Connect the Pro-Form deviceto the computer prior to logging onto the website iFit.com if the iFit programsare not downloading or operating on the computer. The fitness device mustremain plugged into the computer at all times in order to use the iFit programsduring the workout.o 3 Insert the console key andpress the "Program Select" button repeatedly if the iFit program isnot working properly. Ensure that the fitness device is connected to thedesired output device, such as the computer, television, VCR or MP3 player. TheiFit indicator should be lit on the console display.o 4 Press the "Start"button on the console if the time display is flashing on the Pro-Form device console.The iFit program will not function while the time display is flashing.o 5 Listen for a chirping soundif the incline or speed changes suddenly on the fitness device. The chirpingsound indicates that a speed or incline change is about to take place, even ifthe iFit program has not announced the change.
Nov 09, 2011 | Exercise & Fitness
I hae a Pro Form 540 Iteracive Trainer treadmill. When the key is inserted, the treadmill cuts on but the control panel doesn't seem to work when you touch start. I waited and cut it off and went...
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful."
Aug 08, 2011 | Sport & Outdoor - Others
My treadmill will not incline. when you press the
Wondering if you found a solution to this problem yet? I seem to have the same situation with my 730cs treadmill. It is inclined and will not move up or down...thanks.
Mar 02, 2010 | Proform 730 Folding Treadmill Model...
I have a pro-form 550 XL treadmill its in #10 deg. incline and wont come down. The motor keeps running trying to incline more and wont shut down or lower the incline. Reset it talked to sears rep. and they...
i ran into the same problem today with another proform model. i shut the machine off and lifted the platform to the stow position and brought it back down, turned it on. it worked fine during a workout. i was using an ifit sd card when it got stuck. were you? just wondering.
Feb 03, 2010 | Exercise & Fitness
Ifit treadmill will not incline but everything else works, how do I fix the incline
You may need to calibrate the incline. Do this with the following procedure.
Safety key out
press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
press the stop button one time only.
now press the incline up button (incline motor should start moving up)
incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
Good luck Tim
Nov 23, 2009 | Proform Quick Burn Pro Treadmill with 12...
Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Apr 27, 2009 | Proform Sport 1000 Folding Treadmill...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
