Question about Craftsman Garden
Low spark can't start been setting 3 yrs.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Replace carburetor, fuel lines, fuel filter, and plug.
Posted on Oct 19, 2013
Mower starts good but only runs 5 minutes befor stalling out and won't start again until cool. It idles OK when blade is NOT engaged. Cause? And how do you set the carb adjustment screws to max. p
No adjustment for carb on newer mowers. All mowers now have a low oil cutoff. Ensure oil is full. 30w oil. If any grey is observed vin oil drain all oil. Moisture in oil. Dump old oil out every 2 yrs and refill. Ensure spark pluf is clean and gapped correctly. Ensure air filter is clean. Replace spark plug and air filter each year. Always use Stabile in gas. Spray outside of carb with carb cleaner to ensure proper choke movement.
Sep 24, 2012 | Toro Garden
Mac 3516 chainsaw won't start
Electronic ignition units work off speed of rotation so make sure yoy are cranking the engine fast enough, make sure the plug is well earthed against the cylinder whilst cranking, make sure the switch is in the on position, if there is still no spark you will have to replace the unit.
Aug 02, 2012 | Garden
92 dlx tercel, cranks fine, won't fire. No prior start issues in 17 yrs.
Igniter usually. You need a few things. Do you have fuel? To the carb not just in the fuel tank. And do you have spark? Check all plugs. Turn car over with a plug wire removed and see if you have spark otherwise you need to diagnose air intake or compression. Usually igniter if you have no spark.
Hope this helps.
Oct 20, 2017 | 1992 Toyota Tercel
My mower won't start
try running it with the gas cap loose the vent might be plugged
Apr 13, 2012 | Garden
I have a 1983 Honda Accord Auto which will not start. Have checked the ignition coil and spark plugs, and there is a spark but it is weak. Have tried with a new ignition coil and the same problem exists....
test battery -is it holding 12.6v charge-if not then its over 3 yrs old or the alternator is bad--also inspect inside distributer cap and plug wires--they get corroded and need replacin
Sep 26, 2011 | 1983 Honda Accord
The motor wont start
This could be a few different things. 1. Check oil level, if your machine is equipped with a low oil sensor the engine will not start if oil is low. 2. Check the spark plug, remove it and place it against something metal and crank the engine over while looking at the spark plug to see if you have spark. Don't hold the plug because you will get a shock. 3. Check the carburetor, remove and clean. Check the air filter, make sure its clean. If these steps don't work let me know.
Jul 23, 2011 | Black & Decker Garden
Hi. 1992 CB750 bought after being in storage for 4 years, changed oil and fuel - blowing smoke when warm, compression 165, 130, 160,160 - No 2 climbs to 200 with a little oil in cylinder - Rings on No 2 -...
If it was me, I'd take the time first to remove all spark plugs and add enough diesel fuel to cylinders through spark plug holes to at least cover top off piston well, and let it sit and drain down through rings etc. Do this numerous times over a few days, or even week if you have the time, and see if it will un-seize any possible seized rings. Have done this on a nice little Chevy II years ago and saved a seized engine.
Smoked for approx 10 minutes on first start after sitting for 3 yrs. and then purred like a kitten from then on. Be sure to drain oil from crankcase which will be where the diesel fuel goes as it seeps through rings. It's worth a try, and would be a low cost fix if it works.
Jul 23, 2011 | 1992 Honda CB 750F2 Seven Fifty
On spark ,setting 3 yrs,sanded mag fly wheel and pickup,
Has it got a low oil sensor? Most hondas have Try putting some more oil in motor
Jan 26, 2010 | Generac 5622 GP Series GP5000 6,250 Watt...
I have a 1974 dt 250 same as an dt 360 the bike has sat in a barn about 4 yrs it will not start removed and cleaned the gas tank went thur the carb new plug used ignition coil compression about 50 to 75...
Compression is too low!
Replace the piston rings.
Also check continuity from engine to frame till high-tension coil...
Check if breaker points aren't dirty ( clean out with fine sandpaper )
Check breakerpoint settings
Oct 31, 2009 | 1974 Yamaha DT 360
Garden Logo
82 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
