Question about Drills
Plasplugs drill sharpener instructions
I have lost the 'bolt that enables you to secure the chisel sharpening handle to the unit. Can I buy a replacement?
emissionwiz
  • 79865 Answers
SOURCE: need part for bit sharpener model 263 type 1
I have been unable to locate
Posted on Sep 02, 2008
  • 100 Answers
SOURCE: Drill doctor won't sharpen bit
sounds like the angles have been cut wrong on the bits or you are drilling too fast
Posted on Feb 16, 2009
efs_perpends
  • 1996 Answers
SOURCE: Black & Decker model 4300 manual
Here's a link to a downloadable .pdf manual for your sharpener that will give you pages and pages of instructions to make those dull bits history.
Enjoy!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 27, 2009
jimboz4
  • 305 Answers
SOURCE: Sir, I have a Powerbase Xtreme Rotary SDS 1200W
http://manuals.syntigroep.nl/manuals.htm
have a look here, they have just about every owners manual on the planet
Posted on Jul 23, 2009
loud_pipes69
  • 122 Answers
SOURCE: is there an adapter to
ebay
Posted on Jan 12, 2011
Tip
How Do Knife Sharpeners Work?
Knife sharpeners are a way of preserving
knives and other such tools that have become blunt with use and therefore less
effective.
Sharpeners work by grinding the knife
against a hard, rough surface. Usually stone is the most common type of
sharpener but sandpaper (which has a soft surface but is hard), can also be
used.
You can take your knives to a knife shop
where they will sharpen them for you (on average once a year), but if you are a
keen knife user and want to keep your knives sharp and in excellent condition,
it might be worth buying a sharpener of your own.
To sharpen your own knives you’ll need to invest in a good whetstone. These are
stones that are available in fine, medium and coarse grits.
The sharpener will come with
instructions about the angle you need to place the knife at in order to sharpen
it.
You can also buy stones for polishing
and to complete the job properly, after you have sharpened your knife, you
should polish it.
on Dec 25, 2013 | Kitchen Appliances - Others
Need a manual for bosch drill sharpener s40
Go to this site next scroll over to were it says more at the bottom you can chat with a Bosch tech. https://www.boschtools.com/boschtools-ba-search/us/en/manuals/search.htm
Jun 26, 2012 | Drills
Where can I get the blades sharpened? Marco Stratford CT 06614
you can do it yourself with instructions from ehow.com. see below OR you can get it done at a small engine shop repair, where they fix the lawnmowers, slingtrimmers and chainsaws such as Makita, shtil or any other company that makes them. Hope this helps!
How to Sharpen Hedge Trimmer Blades Instructions Things You'll Need
  • Metal filer Eye protective goggles
  1. Sharpen Your Shears
    • 1 Place the hedge trimmers on a flat surface. Ensure that the blades are pointed away from your body.
    • 2 Position a pair of pliers around the bolt on your hedge trimmers. Clamp the pliers on the bolt securely.
    • 3 Twist the bolt counter-clockwise to remove it.
    • 4 Separate the paired blades.
    • 5 Hold one of the handles with the blade facing away from you. Slide a metal filer down the length of the blade until you reach the pointed end. Continue to sharpen the blade for a minute or two, and then do the same with the other blade.
    • 6 Test the blades with a piece of paper. Hold a piece of paper next to the blade, and then try to cut the paper without using a lot of force. If the paper slices easily, then your blades are completely sharpened. If the blades do not cut the paper, continue to sharpen the blades with the metal filer, and repeat the paper test.
Sep 13, 2011 | Black & Decker 16Inch Hedge Trimmer
I have a plasplugs compact drill sharpener with chissel, knife and scissor sharpeners but there are no operating instructions. How do you use it?
Hi Rick,
You can go to this webpage and get the pdf document with your operating instructions: http://www.plasplugs.com/acatalog/manuals/4in%20one.pdf
Hope this helps. If it does, I'd appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | Garden
Does anyone know where i can get parts for a emak type fl136lr36941 chain saw sharpener?
emak home page
http://www.emakgroup.com/
I suspect it is actually tecomec (both owned by the Yama Group)
http://www2.tecomec.it/database/tecomec/tecomec.nsf/prcat/AD47E80A73B834FBC1256E670057DEDA?OpenDocument
PDFs for each model are at the bottom of the model page.
The Tilton Equipment Company handles Tecomec in the United States.
http://www.tiltonequipment.com/html/totaltecomec.htm
I suggest you contact Tilton or tecomec for parts availability. Oregon sharpeners are subcontracted to tecomec Italy. It's possible Oregon parts may fit your unit. HTH
Lou
Where did you buy the sharpener? They sould also have parts information.
Nov 20, 2009 | Garden
Enjoy!
May 14, 2009 | Drills
Jan 02, 2009 | Dynamic Drill Doctor Large Chuck, Black,...
Bench Grinders Objects
our bench grinder can be used to keep your chisels, knives, gouges and other similar cutting tools sharp, which every woodworker knows is vitally important. Also, bench grinders are handy for sharpening lawn mower blades, drill bits, gardening shears and more. Additionally, a bench grinder can be used for honing and shaping metal objects when modifications are needed. For instance, perhaps you need to modify a door hinge to make it fit in a certain application. No tool is better for this task than a bench grinder.
Aug 27, 2008 | Dewalt 6" 5/8 Hp Heavy Duty Bench Grinder
Drills Logo
266 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
