Question about Reebok 8050 ES Treadmill
The belt skips so I have to hold on. I can not run on it.
ProForm Space saver treadmill was closed while inclined, belt skips and moves to side
see the video and proceed according. God bless youlube the rack and pinion of elevation motor, and adjust the small POT attached. see the diagram attached.
Apr 05, 2013 | Exercise & Fitness
I have a Image 15.0 R treadmill. It skips and I tried tightening the belt 1/4 turn as directed and not over tighten it. Still skips and actually squeaks now especially when running on the treadmill at 6...
3 different possibilities in my opinion:
belt is too loose, belt is too tight, belt is worn out.
Try to lift the belt and get your hand under it in the middle of the deck. If you cannot reach, it is possible that your belt is too tight. Another clue for this would be the belt "curling" on both sides at the edges. Try to loosen the belt, gradually and testing it along the way.
If on the contrary you can easily slide your hand under the belt from one side to the other, it is more likely that the belt is too loose. The squeaking might be due to the belt not being "square" on the deck. Try to loosen it even more until you can slide it with your hands across the deck. And have it aligned evenly at the front and back. Then retighten and adjust the tracking at low speed.
!!! Do not over loosen as the bolts might come out of the back roller.
A worn out belt might squeak and skip when its old.
Mar 04, 2011 | RTO Image 15.0R Treadmill Walking Belt
Belt skips
This typically means the belt is worn - or not tensioned properly.
Look in your owner's manual - and it will tell you how to properly tension the belt with the included spanner wrench.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 27, 2010 | Proform 540ls Treadmill Walking Belt
Belt skips when weight goes on. It squeaks and
* take nail polish or paint and place a mark starting on the front roller pulley and going onto the front roller metal shaft
* then try to walk on it and see if the white mark separates
* if it does then the roller is bad and would need replaced or tap screws placed through the pulley into the metal shaft to hold it in place
* if it doesn't separate then the drive belt is slipping and most likely will need replaced, although you could try spraying belt dressing on it to see if that would be a temporary fix.
* if neither of these is your problem and the walk belt is slipping then you will need to try to adjust the screws in the back of the treadmill through the end caps. these are allen wrench screws.
Tighten each one the same amount such as 1 full turn to start with.
see if you can now walk without it slipping.
If not then tighten 1-2 more turn on both sides.
If after 2-3 full turns it is not tight enough
I would recommend replacing the walk belt.
Hopefully this helps with your problem!
Jul 22, 2010 | Proform Exercise & Fitness
Belt skips
take the cover off, if the front drive roller continues to turn when the running belt stops, tension the running belt by using the rear adjustment screws. One full turn on each side should do it. If the front roller stops turning but the motor doesn't, tension the drive belt by adjusting the motor back.
May 26, 2010 | Proform 760 CrossTrainer Treadmill
On a 2000 plymonth voyager wy does serpintine belt come off when it rains
Because the belt is not tracking straight and water lubricates and helps it skip over the groves.Make sure belt is aligned properly and is inline on all pullys
Nov 20, 2009 | 2000 Plymouth Voyager
Teac PD-D880 5-CD changer Disc Skip
The belt for the carousel has snapped and the noise is the gears continously turning and not being caught by the belt.
Oct 27, 2009 | Teac Audio Players & Recorders
1997 2.0 y code engine mitsubishi eclipse
P1390 - Timing belt skipped 1(or more) tooth
(click for full size)
Jan 21, 2009 | 1997 Mitsubishi Eclipse
Mazda 626
had the same problem in my car. the transmission may over heated and its blown the overdrive. it could also be the trans cooler playing up or finally the cam belt may have skipped a few notches. DONT run the engine get a repair man to come to you. if its the cam belt running the engine can damage the cylinder heads and then it becomes real expensive, they're all relitivly easy to fix.
Jul 18, 2008 | 1992 Mazda 626
Reebok 8050 ES Treadmill Logo
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
