Question about Apple iPod touch
Limited or no connectivity
No connection
    New Friend:
    Problem Solver:
  • 6 Answers
If you don't mind me asking, what service provider (Sprint, Verizion, T-mobile) do you have for your cellular device?
Posted on May 10, 2013
Changing how many devices can connect to my hot spot at one time
Every device has a limit set to its connection as far as Hot spot connections are concerned. Check under your Settings, Under Networks, there has to be a limit set, or an option to set up the limit of connections to your hot spot
Nov 15, 2016 | Computers & Internet
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
Limited Connection Error
A limited connection on a Windows PC usually means that there is no connection to the internet on that segment. That is if you connect to the printer via a network switch or LAN. Newer printers can act as a DHCP server/router assigning IP addresses to LAN clients. It has no impact on your LAN if you do not want or need a connection to the internet. However if you want to access the internet from this PC I suggest you get a separate router and use that as the DHCP server on your LAN. Connect the PC and the printer to the router and disable the DHCP server on the printer. Also make sure that all devices (PCs and printer) are using the router as the default gateway. Once again if you don't need an internet connection the limited connection shouldn't worry you.
Nov 15, 2013 | Kyocera Mita Office Equipment & Supplies
Why is limited internet connection?
You are facing the limited internet connection only when its secured with the username an password.
Check for it or contact your ISP.
** You can also avail our technical support by visiting our website: http://www.vtechsquad.com
May 01, 2013 | Linksys WRT54G-TM Wireless Router
Limited or no connection
Limited connectivity
If you get a 'Limited connectivity" on you LAN connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the router.
To fix this problem, right click on the LAN icon on the Task bar and then click Repair.
This will force the router to issue a IP address to the LAN card on the laptop.
Feb 11, 2013 | Computers & Internet
Connected with limited connectivity
Go to your local area connection from Control panel>Network and internet connection>Network connection.There choose the property of your local area connection.
In property,uncheck the option Notify me when this connection has limited or no connectivity.And choose OK button.Now you have done.Now disable and enable local area connection from network connection.You will seenotification saying acquiring network address and connected.The error of limited area connectivity will never disturb you again.
Resource : http://www.ehowportal.com/fix-limited-connectivity-laptops-wireless/
Apr 26, 2012 | Computers & Internet
How do I fix limited connectivity? I'm using
Unplug wifi box wait 30 sec or so plug back in, wait for desktop to re see the signal, hope this helps.
Mar 05, 2012 | Microsoft Computers & Internet
My XP laptops cannot connect to my TEW-639GR router over wifi. I get the "Limited or No Connectivity Message". The same 2 XP laptops can connect if they are wired without problems. My Ubuntu...
You can disable the notification so that it would either be on or off only and not a limited connection.
click on start > control panel > network connections
right click on the Local Area Connection > under the general tab, please uncheck the box that says "notify me when this connection has limited or no connectivity" click on ok and then restart the computer.
After the restart, please check the network connection if is still says connected now or it is disconnected. We will check where we can proceed from there.
Mar 25, 2011 | Computers & Internet
I'm looking for the 2000 isuzu rodeo 3.2L v6 connecting rod bearings torque specs.
1. Check the connecting rod alignment If either the bend or the twist exceeds the specified limit,the connecting rod must be replaced. Bend per 100 mm (3.937 inch) Limit: 0.15 (0.0059) Twist per 100 mm (3.937 inch) Limit: 0.20 (0.0078)
2. Measure the connecting rod thrust clearance. Use a feeler gauge to measure the thrust clearance at the large end of the connecting rod If the clearance exceeds the specified limit, the connecting rod must be replaced. Standard: 0.16 mm - 0.35 mm (0.0063 inch - 0.0138 inch) Limit: 0.40 mm (0.0157 inch)
3. Measure the oil clearance between the connecting rod and the crankshaft.
    1. Remove the connecting rod cap nuts and the rod caps (12). Arrange the removed rod caps in the cylinder number order.
    2. Clean the rod bearings and the crankshaft pins.
      1. Carefully check the rod bearings. If even one bearing is found to be damaged or badly worn, the entire bearing assembly must be replaced as a set. Reinstall the bearings in their original positions. Apply plastigage to the crank pin.
      2. Reinstall the rod caps (12) to their original positions. Tighten the rod cap nuts. Torque: 54 Nm (40 ft. lbs.) Note: Do not allow the crankshaft to rotate.
      3. Remove the rod caps.
        1. Measure the width of the plastigage and determine the oil clearance. If the oil clearance exceeds the limit, replace the rod bearing as a set. Standard: 0.019 mm - 0.043 mm (0.0007 inch - 0.0017 inch) Limit: 0.08 mm (0.003 inch)
        2. Clean the plastigage from the bearings and the crankshaft pins.
May 21, 2009 | 2000 Isuzu Rodeo
Apple iPod touch Logo
13 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
