Question about ViewSonic N1930W 19 in. LCD TV
Viewsonic N1930w every time I autoscan I either lose or gain channels. How can I add the channels I keep losing?
    Top Expert:
  • ViewSonic Master
  • 74,383 Answers
Check its tuner. If tuner is faulty, this kind of fault can occur. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window.
Posted on May 11, 2013
4 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: I cannot find hdtv channels on my viewsonic n1930w
Are you trying to get the HD signal from the roof antenna or from cable? when you set the tuner to scan for channels make sure it is set for 'CABLE' if you are on cable, or 'AIR' if using roof antenna.
Posted on Oct 31, 2009
PCJanitor
  • 72 Answers
SOURCE: viewsonic N1930W input menu missing
According to this image, the input you are looking for is marked 'G'.
You would then use the Input button on your remote control to select that option. The OSD does not support selection of the input.
Posted on Oct 27, 2010
  • 121 Answers
SOURCE: need ViewSonic N1930W repair manual
Here you go http://www.manualowl.com/p/ViewSonic/N1930W/Manual/20267
Posted on Sep 26, 2011
How to unlock channels on viewsonic monitor
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Unlock procedure is too much to type in here, and is not practical.
Jul 10, 2014 | ViewSonic N1930W 19 in. LCD TV
Power locked viewsonic n1930w
On the tv itself hold down CHANNEL button and hold the MENU button then press the POWER button, You will get into the service menu. from here I went in to the CARNIVAL menus and changed the PW setting then backed out... Power button worked. Then I went back in and played with everything else... but in the end left everything the way it was in the end. I suggest you do the same. Good luck.
Jun 10, 2012 | ViewSonic N1930W 19 in. LCD TV
Need ViewSonic N1930W repair manual
Sep 26, 2011 | ViewSonic N1930W 19 in. LCD TV
Keep loseing local channels , change antenna 4times allways resetting channels gain and lose
Hi, I may have the answer for you. Your (TV) is very sensative to off air stations (anntena).
If you are near a cell tower or Power lines your TV tuner will have a harder time finding anything.
You may need to switch to Cable or dish to recieve anything worth watching. Most off air channels
will fade away because of DTV. If you have a chance Google (digital TV) for your search.
Good luck...
Jun 04, 2011 | Televison & Video
Starview channels missing
you should not have factory reset when you lose a chnl delete the chnl then rescan you never need to factory reset you lose the flash or newest update you had installed reflash your box and delete the chnls that are scrambled only and then rescan
Feb 20, 2010 | StarTech.com StarView SV431USB 4-port KVM...
I cannot find hdtv channels on my viewsonic n1930w hdtv monitor, but it does find them on my vizio 22'' hdtv monitor. Am I doing something wrong
Oct 31, 2009 | ViewSonic N1930W 19 in. LCD TV
My setanta sports and sky channels are gone
You could try this,
sometimes channels change frequency so they dont work,have u tried a factory reset 0000 to delete,power off at back/on and autoscan ur provider,and emu to on,usually brings them back,do not scan thru splitters as u will lose channels.
Apr 01, 2009 | StarTech.com StarView SV211K 2-port KVM...
Playing vcr causes new digital tv to lose saved channels
Vizio representative suggested connecting antenna directly to TV and not through the VCR. In doing this, we lose the ability to record on the VCR but we record elsewhere and watch downstairs. The problem is solved on losing channels. I must add that we watch and record on a Sharp digital TV upstairs and do not lose channels. I don't know why the VCR had this effect on this Vizio TV.
Dec 01, 2008 | Vizio L37 Television
Cannot keep all channels on tv
When you say you "lose" channels, you probably mean there's no signal there anymore but they are still in the channel memory. This is normal if you have a rotatable antenna. You need to mark the rotator (or just keep a chart nearby) with the heading for each channel.
If you mean you're losing channels from memory when rescanning after turning the antenna, the only solution I can offer is to record the channels found (and their signal levels) after scanning a direction. Then change directions and rescan. See what new channels have been found, what have been lost, or how signal level has changed on common channels. Then you can manually add whatever you need, and you'll know what direction is best for each. It's tedious, but you should only need to do it once.
Nov 24, 2008 | Insignia Digital-to-Analog Converter for...
We have a sharp lcd tv c/w built freeview,the last couple of weeks it keeps losing just 1 channel ie bbc1 or itv1 every other channel is fine if we retune the tv everything goes back to normal, is it the...
no problem occur on your set but the only problem is you can not lock the fine tuning (in manual procedure) but is it better to set the program to AUTOSCAN OR AUTO PROGRAM and authomatically tune and save to the memory all the program channel
Apr 29, 2008 | Televison & Video
ViewSonic N1930W 19 in. LCD TV Logo
74 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
