Question about Cycling
Setting ECHO F1
I have old unit (setting buttons on the rear, more than 15 years), no more manual on the internet. Requires resetting- do you have the manual?
2 Suggested Answers
  • 1796 Answers
SOURCE: Do you have the instruction
Echo F1 bicycle user manual
Posted on Sep 26, 2010
Won't turn on
Can u tell me model no and brand name so that i can help u sir..
Sep 03, 2008 | Samsung PCN5425R 54" Rear Projection...
Jenn-Air Range displaying Error F1-8
Did not find an error code "F1-8"
I did find these. Seems that about everything that can go wrong with a Jenn Air is related to the clock.
https://www.repairclinic.com/RepairHelp/FaultCodes/26/Range-Stove-Oven
Sep 22, 2017 | Jenn-Air JES8850AAS Electric Kitchen Range
Ge geospring hot water heater fault code F1
Copy following links before calling GE with model and serial number for local trained service technician.
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
Don't buy expensive water heaters that do not have service manuals available.
Gene
h
Nov 18, 2013 | Geospring Hybrid 50 Gallon Heat Pump...
Unit won't cool. Unit is set on is on cool, but warm air comes out. Is there a reset button on the unit ? Unit is 21 1/2 years old.
Some of those old Mach 3's have a manual reset pressure switch, but you will have to take the cover off to find it. Most manual resets have a red button to push to reset. The unit may be low on refrigerant or the condenser coil stopped up with dirt.
May 13, 2011 | Coleman Mach III Air Conditioner
MSI RG54 SE- how do I reset the password? I tried messing with the custom configuration and just messed it up
Press and hold the RESET button(with a pin/pentip) (located on the rear of the unit) for more than 5 seconds and reboot the router. This will reset all settings to factory default
Full PDF manual can be downloaded here: http://www.msi.com/product/net/RG54GS.html#/?div=Manual
I hope this helps
Magoo
Mar 10, 2011 | MSI RG54GS Wireless Router
There is no reset button at the bottom where is it?
Hi cloriaj,
There should be a reset button on the back righthand side of your unit.
The Garmin Nuvi 205W and most other 200 series GPS receivers are normally reset as follows:
The reset button is located on the right rear-backside of the unit. Press a blunt non-metallic object or a cut off toothpick into the small hole and hold for approximately 15 seconds. The unit should do a fresh reboot. Sometimes these GPS units can be reset by sliding the Power key to the left for 10-15 seconds to completely shut the unit down. Then, do the same procedure for 10-15 seconds again, to power it back on.
It would be best to assure the unit has external power, and hopefully a full battery charge, for best results. Also you can download a complete manual from this link for more info:
http://www8.garmin.com/manuals/nuvi205_OwnersManual.pdf
Let me know how this turns out, and if I can help you further.
Regards,
Bill
Sep 19, 2010 | Garmin nuvi 205W GPS Receiver
Same problem
It sounds like the classic "timer problem" that requires a "kit" (mostly capacitors) to repair it. To have someone do it (such as your service person) for you can be expensive and time consuming. Sets that are 5 or more years old usually have other problems too which, simply put, is a complete cleaning of all mirrors, fans, and filters.
Jun 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
How to reset sound card to stop constant, strong echo?
Try setting your sound card back to the defaults by going into your control panel (Start--> Control Panel) double click Sounds and Audio Devices (if in classic view), while on the volume tab press the ADVANCED button, then go to the performance tab and press the RESTORE DEFAULTS button. If that does not do it you can try moving the Hardware acceleration slider to the left one notch at a time, and if none of those help I would use the device manager to remove the sound card (if you have the drivers to reinstall when you reboot.
Dec 25, 2008 | E-Machines eMachines Desktop PC
"F1" error code on Magic Chef gas range Model 3488XRA
I'm not sure how to fix this, but my mom's magic chef has been doing this for close to 10 years. She's managed it by plugging a power strip into the wall outlet and plugging the stove into the power strip. Then she can just turn on the strip when she needs to use the oven. It only requires moving the unit once, and is easy for the technological/ home repair novice.
Sep 18, 2008 | Kitchen Ranges
Cycling Logo
32 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
