Question about Gbc Heatseal H320 Laminator, 12.5" Wide, 5 mil Maximum Document Thickness, Black
Wire diagram gbc h425 - Gbc Heatseal H320 Laminator, 12.5" Wide, 5 mil Maximum Document Thickness, Black
3 Suggested Answers
SOURCE: I have a gbc heatseal
There is a small 125 v 10 amp fuse in the circuitry on the right inside the unit. Whether or not this will solve your issue is unknown. I have one apart in front of me right now with other problems.
Posted on Jan 13, 2011
m4c2
SOURCE: a laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Posted on Jun 30, 2012
Testimonial: "Thanks! It's all fixed now and put back together!"
How do I put a GBC Heatseal H425 laminator back together?
You might contact GBC directly and request an assembly diagram
Jul 14, 2017 | Gbc Office Equipment & Supplies
Laminate Film Disconnected
Un-coil the lower roll and feed it through by hand.
Dec 06, 2013 | Gbc HeatSeal H425 Laminator
Machine will not power on
To be honest other than checking the obvious like the plug fuse, plug wiring there is not much you can do. If you are ok with a screwdriver you could check internally for a loose wire but parts will cost as much as replacing the unit for new
Mar 01, 2013 | Gbc HeatSeal H425 Laminator
Making loud noise
something inside obviously is awry
Jan 15, 2013 | Gbc HeatSeal H425 Laminator
My laminator won't stop heating
so what model are you having troubles with
Aug 30, 2012 | Gbc HeatSeal H425 Laminator
A laminate and paper jam in a Gbc HeatSeal H425 Laminator
floating cowboy
Jun 26, 2012 | Gbc HeatSeal H425 Laminator
I have a heatseal h425 and it is making a loud sound when turned on. The rollers are not rolling and it feels very hot on the outside of the unit.
hi can you please open the laminator up and tell me if there is a rubber toothed belt on the cogs by the motor then i may be able to help.
May 10, 2011 | Gbc HeatSeal H425 Laminator
The wheels wont turn, can this be serviced?
can you please tell me if the cogs by the motor have a rubber toothed belt around them it would be very usefull
Mar 22, 2011 | Gbc HeatSeal H425 Laminator
I have a gbc heatseal h425 laminator and it wont turn on. Is there a fuse inside the machine that needs to be replaced
Dec 23, 2010 | Gbc HeatSeal H425 Laminator
Gbc Heatseal H320 Laminator, 12.5" Wide, 5 mil Maximum Document Thickness, Black Logo
27 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
