Question about Coffee Makers & Espresso Machines
Cuisinart DGB-900 won't withdraw water to make coffee
The coffee maker has worked well, except if you turn the grinder off and try to use pre-ground coffee, it doesn't take the water from the reservoir, heat it, and drip it through the basket. We just used beans with the grinder and it worked fine. Now the problem has surfaced when using the grinder. It grinds the coffee but won't heat the water and drip it through the basket. The water reservoir remains full and the coffee grounds remain dry. The coffee maker appears to go through a normal cycle with the ON/OFF LED light going on for a couple of minutes and the machine making its normal noises except the LED ON stays on too long and I don't think it makes the end of cycle 5 beeps. I have never performed the decalcifying cleaning cycle with vinegar. I tried removing the charcoal filter when making coffee but it didn't make a difference.
3 Suggested Answers
SOURCE: Cuisinart DGB-700BC grinds but no grounds in the basket.
We have had a similar problem but ONLY with Starbucks coffee beans. Starbucks seems to put some type of coating on, at least some of their beans causing the problem.
Posted on Feb 23, 2010
  • 23 Answers
Not a solution but...
Many folks have reported this, the latching mechanism wears out eventually.
We had the problem but discovered that the door on the basket wasn't getting completely closed. Now I make sure it's closed and haven't had any problem since.
Hope this solves your issue - if not, keep an eye on yard sales, we picked up two at different times for $5 and now have parts to swap out - not much help for a failed latch though.
Glad I never paid full price for it, even though it's a fairly good grinder/brewer.
Posted on Dec 08, 2010
I have a cuisinart grind & brew coffee pot that leaks when I put water in it. How can I open it to see where the water is coming from?
The Manual for your coffee maker can be found here:
'Leaks' are usually caused by overfilling either the water reservoir or the coffee basket or by coffee grounds interfering with a seal.
Make sure you perform a complete cleaning on your coffee maker making sure any contact points which need to seal are free of coffee grounds.
Instructions for removing the grinder and filter baskets are contained within your manual.
Feb 06, 2011 | Cuisinart DGB-600 Coffee Maker
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Where can I get a replacement grinder filter basket holder for a Cuisinart DGB 300 coffee maker
Go to this link to order directly from Cuisinart for items for your coffee maker. Just copy and paste into your web browser.
Hope this helps, let me know if I can help you with anything else.
Sep 30, 2009 | Cuisinart DGB-300 Coffee Maker
DGB 500 Grinder
You may try opening the front cover first and removing the filter then after opening the top lid, remove the clear grinder cover and lift the grinder from the rear. After you get it out be sure to clean the motor drive shaft and the bottom of the grinder. then use a trace of vegetable oil to lubricate the motor shaft where is attaches to the grinder.
We are on our second coffee maker and it makes great coffee.
Jan 19, 2009 | Cuisinart DGB-500 Coffee Maker
Cuisinart dgb-500 automatic grind & brew
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Jun 11, 2008 | Cuisinart DGB-500 Coffee Maker
Cuisinart DGB-300 coffee maker brew pause valve
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Aug 30, 2007 | Cuisinart DGB-300 Coffee Maker
Cuisinart BGB-300
I just got mine to work. It seems that so much water condensation gets into the grinder that there was rust stopping the grinder from moving. Just remove all the parts, especially the blade and basket holder assembly. Take a pair of pliers and twist the grinder stem manually to loosen the rust. Turn it a good number of times and then test it out. I didn't want to use WD-40 on something my wife uses everyday. Good luck.
Aug 10, 2007 | Cuisinart DGB-300 Coffee Maker
Cuisinart grind and brew coffee maker
here is the link to the manual; ask again if you still haven't figured it out :)
Mar 15, 2007 | Cuisinart Thermal DGB-600 Grinder
Coffee Makers & Espresso Machines Logo
44 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
