Turning key to start Mitsubishi Outlander, nothing only the A B S light coming on, switch ing on all seems o.k,warning lights all go out etc, but turn key to start and A B S light reapears.
SOURCE: 2000 dodge intrepid won't start
If the key is returning to the 'Run' position as it should, then either a relay controlling the solenoid or the solenoid itself is hanging up. The heavy contacts that send power to the starter can develop rough surfaces that can temporarily weld themselves together causing the starter to run on even though the engine is running and the key has returned to the proper position. There is also a spring that should normally help return the solenoid's contacts to their 'off' position that may be weakened.
SOURCE: 96 Voyager won't start
Then the next thing to check is the starter itself, are you hearing any popping noises from the base of the motor? The starter should not be hard to change. Once you pull it out you can take it to the autozone and they can test it for you. The starter solenoid may be bad also, but these are normally attached to the starter. I hope this helps give you some insight.
SOURCE: 2006 Jeep Wrangler won't start
First, make sure you can turn the engine by hand. If you can't then the starter can't turn it either. Have someone else turn the key and look for the source of the click...may be a relay. Go over the starting circuit with a volt meter. Check for power at the starter main terminal and then with the key turned to "start" check for power at the trigger terminal on the starter. Check battery voltage and check relay operation.
You have a neutral safety switch on the transmission if its an automatic and a clutch switch if it's a stick. Check them as well. Make sure battery grounding on fender and block are also clean and secure.
Testimonial: "Will try! Thanks!"
SOURCE: 1996 mitsubishi eclipse doesn't start when turning
check for voltage at the small start wire on the starter when cranking the engine--you will need someone help. If there is no voltage you may have a bad neutral safety switch ,which is on the trany shifter.you have an automatic trans i assume.
If so try putting in neutral when cranking.
SOURCE: 2001 ford Taurus. Will not start. Turn key and
The problem would be the starter they go without any warning
Testimonial: "Terian5- Thanks for the help Traced the wire to starter. the wire looks like it snaps on. put it back and it started. I need to tighten nut."
