Question about Beauty Without Cruelty Health & Beauty
Any recommendation about Colombian Spa provider?
I am looking for spa provider in Colombia.
    New Friend:
  • 20 Answers
Check these http://uribemorelli.com/en/medical-spa-services. These are Colombian provide which deals professionally.
Posted on May 10, 2013
Hi everyone my coleman lazy spa leaks from pump is there a way to fix this?TIA
looks like this has a magnetic drive pump and are not common to leak. so disassemble and locate loose or cracked part and try silicone or epoxy to do the repair. I recommend Majic lube for rubber o-rings and gaskets Lay Spa Teardown
Jun 18, 2017 | Pool & Spa
Waterco spa pump. In demand mode, why won't pump switch off?
Spa pumps are not only for Heat. The pup also circulates water thru the filter and provides optimal chemical dispersion. Recommend you call the customer service see how your warranty has been holding up and go from there.
Nov 21, 2015 | Waterco Pool & Spa
How to deflate and store
DRAINING THE SPA:
1. Unplug power pack from electrical receptacle before draining spa.
2. Put the rubber plug into the outlet in the inner wall of the spa.
3. Open the outlet in the outer wall of the spa. Screw one end of inflation hose into it.
4. Remove the rubber plug from the outlet in the inner wall of the spa.This will allow water to flow out of the spa. 5.When water is completely drained, press BUBBLE and run for 2-3 minutes to drain the water in the air pipeline. 6.When drainage is finished, remove the inflation hose and replace cap on outside of spa. Store rubber plug for future use.
SPA STORAGE
Make sure all water is drained from the spa and control box.This is essential to extend the life of the spa.We recommend the use of a wet/dry vacuum to blow out or suck up water from the spa pipes and pump lines. Remove the filter cartridge. It is recommended you store the spa in its original package in a warm, dry place.
Note: Plastic becomes brittle and susceptible to breakage when exposed to subzero temperatures. Freezing can severely damage the spa. Improper winterization of your spa may void your warranty.
http://img1.wfrcdn.com/docresources/17478/11/119999.pdf
Aug 13, 2014 | Therapure Four Person Inflatable Round Hot...
Can anyone suggest me best massage center in Pasadena, California?
There are quite a few Spa Envys around Pasadena and they are good affordable massages.
Jun 05, 2014 | Health & Beauty
How long does it take to heat a spa pool?
All depends on the amount of water in the spa or pool, and the size of the heater in BTU's. The time for "Heat Rise" will vary and the answer you are looking for can't be provided with amount of info you provided. But if a general rule of thumb - the closest answer: Spa with a gas heater, 1 degree about every 90 - 120 seconds. Electric heater (vary's by KW) on average: cold to hot = 8-13 hours. Swimming pool with gas heater (no suggestion for electric) about 1 degree temp rise every 90 minutes.
Dec 27, 2013 | Pool & Spa
Can anyone help me to find out any plastic surgeon in Colombia?
I think, I can help you for this topic the HUM Plastic Surgery & Medical Spa Clinic is in Colombia with best surgeon's in plastic surgery from many years. You can check more about click on this link......
http://uribemorelli.com/en/clinica-hum
Apr 04, 2013 | Health & Beauty
Is someone knows about best surgeon regarding liposuction in Colombia?
I recommend http://uribemorelli.com/en/procedures. You can also consult all the things with them regarding Liposuction.
Jan 22, 2013 | Health & Beauty
Health & Beauty Logo
69 people viewed this question
Top Beauty Without Cruelty Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Beauty Without Cruelty Health and Beauty Expert? Answer questions, earn points and help others
