Question about True Technogym Excite Run 700 Treadmill
Enter touchscreen menu
Hi. I feel that my treadmill's touchscreen needs re-calibrating as the speed on quick start doesn't work but I cannot seem to enter the menu with the suggested method of restarting it and pressing the screen in multiple places. Am I missing something or is there an easier way to acheive this. Also, does anyone have the manual for the aforementioned treadmill? That would be very handy. Kind regards, Liam
Treadmill E1 Error
Version:1.0 StartHTML:0000000168 EndHTML:0000001348 StartFragment:0000000468 EndFragment:0000001331
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
clean the speed sensor, test for open or faulty. tight the connector very well. RUN the software calibration for easy troubleshooting and fix it.
see the diagram attached. and follow steps.
God bless you
Version:1.0 StartHTML:0000000168 EndHTML:0000003648 StartFragment:0000000468 EndFragment:0000003631
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Mar 29, 2013 | Exercise & Fitness
Horizon treadmill won't incline
Step 1:
Clean the motor, lube the gear+shaft
Adjust the small POT for a little.
RUN the software calibration for troubleshooting. see the diagram
Step 2:
Step 3:
Step 4:
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Feb 07, 2013 | Horizon Fitness Horizon T101 9 Program...
How do I calibrate speed on a Proform 725TL treadmill
follow the steps that i am giving now.
God bless you
Jan 10, 2013 | Proform 725tl Treadmill Drive Motor
Treadmill belt runs too fast and will not power off with control panel
Step 1:
test the speed sensor,m for open or faulty, clean it, and tight the connector. see the diagram attached.
However follow the steps for RUN the.s calibration for fix it.
God bless you
Step 2:
The Steps for Newer Style Console Calibration:
Jan 07, 2013 | Exercise & Fitness
Calibrate
see this steps for calibration. and fix it. God bless you
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step. The Calibration seq
Oct 15, 2012 | Proform 505 CST Treadmill
My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
2.Press the "ENTER" button three times to access the treadmill's error log.
3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
I hope you find it very helpful.
Sep 04, 2011 | Exercise & Fitness
I have a vision T9500 treadmill. My husband was recalibrating and it got stuck in the highest position and is displaying E5 in the window. Any ideas how to get it down?
hi,
Try AUTO-CALIBRATION first. For that do the following.
With the safety key in place, turn the treadmill ON . Press and hold SELECT. Now you can perform auto-calibration by pressing START.
(The treadmill will run through minimum and maximum speed and elevation. This will take 3 to 5 minutes. Let the treadmill perform this complete function. "END" will appear when auto-calibration is complete. When auto-calibration is complete, it will take about 30 seconds for the treadmill to reboot and return to the start-up screen)
If it doesn't help then the motor control module is faulty. You have to replace or repair the motor control module.
OK
Aug 27, 2011 | Dmm Vision Fitness T9500 Treadmill
I hae a Pro Form 540 Iteracive Trainer treadmill. When the key is inserted, the treadmill cuts on but the control panel doesn't seem to work when you touch start. I waited and cut it off and went...
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful."
Aug 08, 2011 | Sport & Outdoor - Others
The treadmill speed is faster than reallife speed. I can easily run 7 minute miles on the roads (not racing, just running) and my wife is an eight minute metronome. But on the treadmill if I set it below...
the speed of treadmills are based on the companies regulations and are machine made. so they might not be 100% accurate. a treadmill is a simulated devise so it is never the same. var fctb_tool=null; function FCTB_Init_c8c9213424bf492d84f2bfaa8e62c574(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_c8c9213424bf492d84f2bfaa8e62c574(document['FCTB_Init_c3525ba5f17e4280b024b96d82d11976']); delete document['FCTB_Init_c3525ba5f17e4280b024b96d82d11976'] var fctb_tool=null; function FCTB_Init_6836227ebca14782a6c9f0284529fff9(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_6836227ebca14782a6c9f0284529fff9(document['FCTB_Init_f3124b0bb88c423dafd62627ed1118bc']); delete document['FCTB_Init_f3124b0bb88c423dafd62627ed1118bc']
May 05, 2011 | NRS Sole S77 Treadmill
My proform treadmill turns on and the inlcline works however the belt does not move. Any suggestions?
Enter calibration mode and do a calibration first.
Press the stop & speed up key, insert the safety key/magnet. Press stop 1 more time. Press speed up, the speed display should start to increase in value. By 30-40, the motor should be running. If not, you either need a motor or motor controller PCB. What model is the treadmill?? PCTL???
Dec 14, 2010 | Proform Exercise & Fitness
True Technogym Excite Run 700 Treadmill Logo
Top True Exercise & Fitness Experts
John Ritchie
Level 1 Expert
Tom Chichester
Sportsmith LLC
Sportsmith LLC
Are you a True Exercise and Fitnes Expert? Answer questions, earn points and help others
