Question about Hitachi StarBoard FX-77
Drivers driver missing, looking for driver.
If i restored my laptop to factory settings an i think im missing drivers is the a program that will look an c if i got all of them an if i dont it will fix them for free?
You don't say how old your laptop is. Some older laptops came with an Operating System Disc and also a Drivers/Apps Disc. Both would need to be installed to recover to factory settings. If you recovered from a recovery partition on the hard drive, then the drivers should already be installed. Yes there are online services that will scan your machine and install drivers.....many are spam and spyware-ridden. You should simply look at the Device Manager and look for errors that indicate missing or improperly installed drivers. There may be an issue if the network driver is missing, because then you won't be able to get to the internet. Once you know what you need, if you go to the manufacturers website, you can almost always download the needed hardware drivers and install them yourself.
Feb 07, 2015 | Computers & Internet
I need driver for Gateway E6610. MOBO Intel oemd975xlag1 aad50908-204. IPMA interface driver missing. PCI serial port driver missing. Where can I procure drivers?
go to your manufacturer site, click on support , than drivers and look for your product . after finding the product you will have multiple drivers to download
Sep 22, 2014 | Gateway Computers & Internet
Missing drivers on reinstall
Go to your computer manufacturers website, there should be a link for "Support" click that then enter your model number, and look for something that says drivers. then you should be able to download all the missing drivers for your operating system. Additionally many computers come with a CD that has the Drivers to reinstall.
Nov 23, 2012 | Computers & Internet
Driver missing
What driver is missing, and what O/S are you using. Windows 7 will find most of them, however sometimes you have to goto the manufacturer of the item missing the driver. If you look in device manager it will assist you better, however i need a bit more info to further help.
Jul 15, 2011 | Computers & Internet
Why won't the driver retract on my pneumatic stapler
Can't be more specific without model number.
Driver not returning to top of cylinder is caused by several issues. Bent driver, piston oring, and check valve. Remove head and pull out driver. The blade should be straight with no missing pieces. Driver piston should fit snugly into cylinder and not drop down cylinder under its own weight. If driver / piston look ok, pull out cylinder and look for check seal in place. It looks like rubber band or one or more orings and fit in groove/s with row of holes (make sure holes are clean). Other problems related to driver not returning is/are lower bumper is missing pieces or cracked and or air exhaust port is restricted, low air pressure. Parts are available at www.toolpartsdirect.com
Mar 28, 2011 | Senco Air Tools & Compressors
IN MY PC SONGS R NOT PLAY SONGS WHICH DRIVER I CAN INSTALL IN MY PC
Your problem is either in the two.
1. Missing Audio Driver
2. Direct X driver missing
To solve Missing Audio Driver you must follow this:
1. Goto http://www.intel.com/p/en_US/support/highlights/dsktpboards/d945gcl
2. Look for the driver that missing in your PC which is the audio, it is available here
3. Install the audio driver
To solve Direct X follow this.
2. Look for utilities the direct x compatible for your motherboard is available here
3. Download and install it.
Dec 25, 2010 | Intel D945GCL Motherboard
Missing network driver
try looking on opendriver.com They may have the correct driver for you. I didn't know your O/S.
http://www.opendrivers.com/driver
Jul 19, 2009 | Everex GA3400 PC Desktop
Aloha missing driver
I have my CD for that missing driver but for accesible and easy download, try this path for a free download of the driver you're looking for.
www.esoft.web.id/search/node/aloha+webcam+installer
Thanks.
Jun 22, 2009 | Logitech Webcam
I am missing two drivers on my Gateway Mx6437
ariawalters, here is a link to all the drivers for your laptop.
Gateway driver page
Good luck!!
Mar 24, 2009 | Gateway MX6437 Notebook
Hitachi StarBoard FX-77 Logo
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
